03-16-2022, 14:16 | #1 (permalink) |
Freak Poster Join Date: Mar 2010 Location: ROMANIA
Member: 1273059 Status: Offline Thanks Meter: 10 | NCK-pleas halp xiaomi redmi note 10 pro my accont reset Operation: Reset MI Acount Model selected: Redmi Note 10 Pro Searching for phone..... ComportMessage: Unable to open com port WinMessage: System Error. Code: 2. The system cannot find the file specified ComportMessage: SetupComm function failed WinMessage: System Error. Code: 6. The handle is invalid ComportMessage: SetCommState function failed WinMessage: System Error. Code: 6. The handle is invalid ComportMessage: SetCommTimeouts failed WinMessage: System Error. Code: 6. The handle is invalid ComportMessage: GetCommModemStatus function failed WinMessage: System Error. Code: 6. The handle is invalid ComportMessage: GetCommModemStatus function failed WinMessage: System Error. Code: 6. The handle is invalid ComportMessage: GetCommModemStatus function failed WinMessage: System Error. Code: 6. The handle is invalid Port: H5321 gw Mobile Broadband Geolocation Sensor Rebooting in download mode, wait... ComportMessage: Port Not Open WinMessage: ComportMessage: WriteFile function failed WinMessage: System Error. Code: 6. The handle is invalid ComportMessage: WriteFile function failed WinMessage: System Error. Code: 996. Overlapped I/O event is not in a signaled state ComportMessage: PurgeComm function failed WinMessage: System Error. Code: 6. The handle is invalid Waiting for download mode... Port: Qualcomm HS-USB QDLoader 9008 (COM8) Hello received. HW ID: 00007200E1600E00 PK HASH: 1BEBE3863A6781DB4B01086063007334DE9E5CA14971C7C4F4 358EC9D79CDA46 [xiaomi]using loader: prog_ufs_firehose_sm7150_ddr_redmi_note_10_pro.elf Arhitecture:64 bits [64]Sending loader, please wait.. Readed length: 16 Waiting for loader to start... [0] Send NOP ok, loader start. Requesting offline authentification. Offline authentification fail for this phone, need to use online server. Phone request: AQAAAG0BAAAFro5dOhfKuicCONTZet3tXPOpYw Requesting xiaomi authtentification, please wait. [230]Error read repply xml <?xml version="1.0" encoding="UTF-8" ?> <data> <log value="ERROR: Only nop and sig tag can be recevied before authentication." /></data><?xml version="1.0" encoding="UTF-8" ?> <data> <response value="NAK" rawmode="false" /></data> [UFS][64 loader]Error send config. [2]Error, loader not start. ************************************* Log saved: C:\Users\gsm\Documents\NckDongle\qualcomm_module\q c_module_Logs\reset_mi_acount__00007200E1600E00_1B EBE3863A6781DB4B01086063007334DE9E5CA14971C7C4F435 8EC9D79CDA464.txt Total Time: 00:00:23 Done. |
03-16-2022, 20:32 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | You have 2 problems. First problem is with usb connection, bad usb cable or wrongly testpoint. When you make testpoint, phone must be with disconnected battery. You must make tp, insert usb cable, when exe will show new usb port(will be displayed in status bar), need to disconect testpoint. After you can service phone. If you want to perform multiple opperations, uncheck reboot phone at opperation finish. Second problem, this phone need credits to autorize edl mode. Simple checking use server without credits will get you error. |
The Following User Says Thank You to orbita For This Useful Post: |
03-16-2022, 21:07 | #3 (permalink) |
Member: 1273059 Status: Offline Thanks Meter: 10 | thanks for reply nck. Conecting to server please wait Serial: 103001xxx Date Added: Wednesday 3 of April 2013 Card active!. [YEAR ACTIVATION]Card active until: Wednesday 8 of March 2023 User credits: 10 |
03-16-2022, 21:27 | #5 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
Xiaomi credits you can check in qualcomm module, exe have button for this. In main module, will not be displayed xiaomi credits. | |
