09-19-2018, 00:39 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | infinix x5515 imei failed Exe version: NCKBox AndroidMTK 1.8.9.3 Selected phone: MT6739 Action : IMEI REPAIR. IMEI[1] for write : 357546091703646 IMEI[2] for write : 357546091703653 Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [7]Detected: MediaTek PreLoader USB VCOM (Android) (COM7) \\?\usb#vid_0e8d&pid_2000#6&3a34e632&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [90]META Port Detected: Android Gadget VCOM Driver (COM90) USB\VID_0E8D&PID_202D&MI_01\7&5CFAD15&0&0001 Start sync target, waiting responce..... ChipID: MT6739,S01 Using Algo 1. Brand: INFINIX MOBILITY LIMITED Board: x5515_h398 Model: Infinix X5515 Name: H398 Release: X5515-H398DEG-GO-180810V158 Version: 8.1.0 Platform: MT6739 NVRAM Dumped OK. C:\Users\elpringy\Documents\Android_MTK\nvram_back up\META_MODE_NVRAM_MT6739_Infinix X5515_09_18_2018_19_28_57.zip [OTP?]Warning, imei entry not found, aborting!!!. Error untill process imei!! |
09-19-2018, 01:00 | #2 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | Selected connection metod: Flash Connection Exe version: NCKBox AndroidMTK 1.8.9.3 Selected phone: MT6737T Action : IMEI REPAIR. IMEI[1] for write : 357546091703646 IMEI[2] for write : 357546091703653 Will be used loader: X5515 DA FILE_DA.bin Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM14) Boot mode: Preloader Phone detected...Please wait BBCHIP: 6739 0 ca00 Using Algo 1. Helio MT6739 phone detected, swithing to helio api BBCHIP MT6739 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010046453632 : 000000000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] -Reading GPT Drive OK Dumping data, wait. [3]Warning, nvram posible damaged!!. All done. |
09-24-2018, 18:35 | #4 (permalink) |
Freak Poster Join Date: Mar 2009 Location: morocco Age: 38
Member: 986038 Status: Offline Thanks Meter: 43 | hi team please I need help same model after frp phone deed not accept flash here log please I need same help Exe version: NCKBox AndroidMTK 1.8.9.3 Selected model: ELBRUS [auto]Action: Reset FRP Will be used loader: 6739_MTK_AllInOne_DA.bin Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM117) Boot mode: Preloader Phone detected...Please wait BBCHIP: 6739 0 ca00 Using Algo 1. Helio MT6739 phone detected, swithing to helio api BBCHIP MT6739 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010046453632 : 000000000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] -Reading GPT Drive OK Starting helio frp, not disconnect phone untill done [0]FRP Reset Done. [2]FRP Reset Done. flash logs xe version: NCKBox AndroidMTK 1.8.9.3 Selected model: ELBRUS Action: Read Pattern Will be used loader: 6739_MTK_AllInOne_DA.bin Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port (COM37) Boot mode: Brom BBCHIP: 6739 0 ca00 Using Algo 1. Brom stage DA fail, aborting BBCHIP MT6739 [STATUS_SEC_AUTH_FILE_NEEDED][AUTH]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model Boot Fail.!!!. |
09-24-2018, 20:27 | #6 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Even teoreticly is not posible to happen this. In this phones preloader is in another partition, and even by mistake is not posible to erase preloader. Will be better if you will tell what exactly happen with your phone. |
The Following 3 Users Say Thank You to orbita For This Useful Post: |
01-25-2019, 09:39 | #8 (permalink) |
Freak Poster Join Date: Oct 2014 Location: Arusha,Tanzania
Member: 2267293 Status: Offline Thanks Meter: 79 | Infinix x5515 Successful Imei Repair... Hello guys, Incase anyone is still struggling to repair imei, i MANAGED to repair it using this SN_Write_Tool_v1.1828.00 and the database files Infinix X5515 Smart 2 DB (X5515-H398DEG-GO-180810V158) for my case but you can go here https://forum.hovatek.com/thread-23850.html and choose APDB & BPLGU / MDDB of your Build. Wish everyone Success. |
The Following User Says Thank You to madcom5 For This Useful Post: |
01-28-2019, 01:05 | #9 (permalink) | |
Freak Poster Join Date: Jun 2016
Member: 2592600 Status: Offline Thanks Meter: 19 | Quote:
12-07-2019, 07:15 | #12 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Christianihechi, i'am understand, you want to promote your site, but posible will be better to check exe instead? Exe now load auto auth file for this phone, and this thread is very old and outdated. |
