04-12-2022, 18:05 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 850 | metamode Action : Skip boot mode auth. Exe version: NCKDongle AndroidMTK 2.7.7 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(3) : MediaTek USB Port (COM3) [3] \\?\usb#vid_0e8d&pid_0003#6&29d0fe13&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6739 CPU code: 699 Target config: e7 *********************** Secure boot enabled: true Need serial link authorization: true Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. flash mode Exe version: NCKDongle AndroidMTK 2.7.7 Selected model: Alcatel OT-V720[MT6739] Action: Unlock Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(3) : MediaTek USB Port (COM3) [3] \\?\usb#vid_0e8d&pid_0003#6&29d0fe13&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6739 CPU code: 699 Target config: e7 *********************** Secure boot enabled: true Need serial link authorization: true Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. [1e200]Dumping phone preloader. Preloader: C:\ProgramData\Android_MTK_Backup_Folder\preloader _backup\preloader_easytab84gtmo.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(3) : MediaTek USB Port (COM3) [3] \\?\usb#vid_0e8d&pid_0003#6&29d0fe13&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6739 2 cb00 Using Algo 1. Helio MT6739 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6739 [1]Storage EMMC Block size: 512 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051443633 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x749400000 [29.145 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(30) : MediaTek DA USB VCOM (Android) (COM30) [30] \\?\usb#vid_0e8d&pid_2001#6&29d0fe13&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Phone have OTP partition. MODEL FROM PROINFO: 9029Z-2ATBUS7 SECRO FROM PROINFO: X5F0UP02CZ00 OTP IMEI: 015608003421214 Modem version: MOLY.LR12A.R3.MP.V65.2.P2 Starting alcatel helio Simlock, not disconnect phone untill done Error[0xc003000c]: STATUS_UNKNOWN_STORAGE_SECTION_TYPE Error[0xc0030007]: STATUS_INVALID_PARAMETERS [helio]Wait untill phone will start charging. [0]All done. |
04-12-2022, 18:18 | #3 (permalink) |
Member: 138781 Status: Offline Thanks Meter: 850 | full unlock meta mode version 2.7.5, version 2.7.7 dont work, very bad Exe version: NCKDongle AndroidMTK 2.7.5 Selected model: Alcatel OT-V720[MT6739] Action: Unlock Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(3) : MediaTek USB Port (COM3) [3] \\?\usb#vid_0e8d&pid_0003#6&29d0fe13&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6739 CPU code: 699 Target config: e7 Secure boot enabled: true Need serial link authorization: true Need download agent authorization true Executing exploit, do not disconnect phone Exploit has been executed successfully. Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(3) : MediaTek USB Port (COM3) USB\VID_0E8D&PID_0003\6&29D0FE13&0&3 Detected(3) : MediaTek USB Port (COM3) [3] \\?\usb#vid_0e8d&pid_0003#6&29d0fe13&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [24]META Port Detected: MediaTek USB VCOM (Android) (COM24) USB\VID_0E8D&PID_200E&MI_01\7&18C601D8&0&0001 Start sync target, waiting responce..... ChipID: MT6739 [MT6739]Using Algo 5 Start sync target, waiting responce..... [META]BaseBand CPU : MT6739 [META]SW_VER : MOLY.LR12A.R3.MP.V65.2.P2 [META]HW_VER : TK_MD_BASIC_HW [helio]Read simlock info. IMEI Location: OTP Phone imei[1] : 01560800 Start direct unlock[SIM1] Simlock checksum is ok. Direct unlock done [0]All done. |
The Following User Says Thank You to cellcarcol For This Useful Post: |
