NCK Box / NCK PRO Spreadtrum Module v0.7 Update Released - [05/02/2019] 1. Added Basic support for SC6531EFM - Supported Repair IMEI -- Factory Reset --- Read & Write NVRam ---- Write PAC File. 2. Added 2 Methods to service Phones in DIAG Mode. - Old Method allow only to: -- Read info (SimLock)/Reset phone/Repair IMEI/BT/Wifi - New Method allow also to: -- Perform Direct unlock in diag mode. --- Usually new method work on phones with android 5.1 and more new. ---- It work also on SC6531EFM, possible on other generic phones too. 3. Added support for Simlock types 2,3,5 and 6 in DIAG Mode. - For this types will be displayed sim unlock code on read info, and new phones will allow direct unlock. -- For other types will need Simlock backup and link to phone firmware. 3. Remade PAC files Writer. -- Now it become more universal and stable. --- Supported EMMC and NOR phones ---- NAND phones support will be added in incoming updates. 4. Added possibility to select custom backup directory. 5. Added custom loader for wiko sunny 3 in custom folder. This loader can be used to remove phone FRP. To perform sim unlock is recommended to use DIAG Mode. Official Website: NCK BOX Download from Support Access Software to Access Download Area Link: Download Area |
Thanks for you NCK TEAM,Good Update but plz add Android 8.1.0 formate & frp...Thanks in Advance |
Thanks NCK TEAM & AVENGAR TEAM Thanks for you NCK TEAM,Good Update but plz add Android 8.1.0 formate & frp...Thanks in Advance |
Waooo verry nice update |
Good add frp side load qualcomm |
pl edit ck/nck CK BOX & Avengers Spreadtrum Module v0.7 Update Released - [05/02/2019] |
Please team thanks for update but next time 8.1.0 needed to be suppoted too thanks for your best |
sunny 3 unlock done ACTION: Unlock Phone. Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 1 Platform Version MOCORTM_17C_W18.23.4_P2_DebugProject Version pike2_pubBASE Version FM_BASE_17C_W18.23.4_P2HW Version sc7731e_modem06-20-2018 111140 Build number: W_K120SUN-user 8.1.0 OPM2.171019.012 153672++++ release-keys Serial number: LA05184+++++ IMEI 1: 35807409+++++ IMEI 2: 358074095+++++ BT: 44D3AD34+++ WIFI: 44D3AD3++++ Reading simlock, wait.... [0:0][USER]Simlock Status: LOCKED[1] Simlock Counter:[10/10] [3]Simlock Type: 0 0 Sim 1 Unlock Code: 88190293 Sim 2 Unlock Code: 88191273 Warning, this is factory key, some opperators can modify factory key. Saved to: C:\Users\hunte\Documents\spreadtrum_module\backup\ spd_simlock_nvram_backup\358074095++++++__W_K120SU N_user_8_1_0_OPM2_171019_012_1536724428_release_ke ys_LA051843004208\ Writing simlock... Writing simlock ok Done. Thanks in Advance |
sunny 3 unlock done read code done ACTION: Read Simlock Info. Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 1 Detected: SPRD U2S Diag (COM27) Platform Version MOCORTM_17C_W18.23.4_P2_DebugProject Version pike2_pubBASE Version FM_BASE_17C_W18.23.4_P2HW Version sc7731e_modem06-20-2018 111140 Build number: W_K120SUN-user 8.1.0 OPM2.171019.012 1536724428 release-keys Serial number: LA051842001254 IMEI 1: 358074095****** IMEI 2: 358074095****** BT: 44D3AD3487F1 WIFI: 44D3AD346861 Reading simlock, wait.... [USER]Simlock Status: UNLOCKED [3]Simlock Type: 0 0 Sim 1 Unlock Code: 88190963 Sim 2 Unlock Code: 88191843 Warning, this is factory key, some opperators can modify factory key. Done. |
Most wanted update thanks nck team |
Start Detect phone. With powered off phone, insert usb cable Detected: SPRD U2S Diag (COM23) Port opened ok. Phone must be off. Connect usb cable without pressing any key. Using connection mode 1 Making 10 sec timeout.. Done. I CANT ENTERING TO DIAG MODE PLEASE HEL ME |
THANKS NCK BOX I UNLOCK THIS SUNNY3 AND REPAIR IMEI EXE: NckBox Spreadtrum Module 0.7 SELECTED: SC7731C_EMMC ACTION: SimUnlock Custom loader: wiko_Sunny3.loader Detected: SPRD U2S Diag (COM23) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. FileSystem: EMMC Manufacturer: WIKO Hardware: k120_v1.1.0 Build Id: OPM2.171019.012 Model: Sunny3 Android Release: 8.1.0 Android Version: OPM2.171019.012 release-keys IMEI 1: 358074095490*** IMEI 2: 358074095570*** Simlock Type: 3 Backup saved to: C:\Users\Flamuri\Documents\spreadtrum_module\backu p\spd_simlock_nvram_backup\358074095497148__W_K120 SUN_user_8_1_0_OPM2_171019_012_1536724428_release_ keys_LA051843002090\spreadtrum_module\simlock_back up_nvram\OPM2.171019.012 release-keys\w_fixnv1.bin Start write unlock, wait... Total Time: 00:00:19 Done. |
Please HELP! with Read Simlock Info I get this: ACTION: Read Simlock Info. Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 1 Detected: SCI USB2Serial (COM70) Platform Version MOCORTM_17C_W18.23.4_P2_DebugProject Version pike2_pubBASE Version FM_BASE_17C_W18.23.4_P2HW Version sc7731e_modem06-20-2018 111140 Build number: W_K120SUN-user 8.1.0 OPM2.171019.012 1536724428 release-keys Serial number: LA051843001456 IMEI 1: 358074095529676 IMEI 2: 358074095610476 BT: 44D3AD348517 WIFI: 44D3AD346587 Reading simlock, wait.... [0:0][USER]Simlock Status: LOCKED[1] Simlock Counter:[10/10] [0]Simlock Type: 0 0 Done. BUT!!! When I use Remove Simlock I get this error ACTION: Unlock Phone. Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 1 Platform Version MOCORTM_17C_W18.23.4_P2_DebugProject Version pike2_pubBASE Version FM_BASE_17C_W18.23.4_P2HW Version sc7731e_modem06-20-2018 111140 Build number: W_K120SUN-user 8.1.0 OPM2.171019.012 1536724428 release-keys Serial number: LA051843001456 IMEI 1: 358074095529676 IMEI 2: 358074095610476 BT: 44D3AD348517 WIFI: 44D3AD346587 Reading simlock, wait.... [USER]Simlock Status: UNLOCKED [0]Simlock Type: 0 0 Saved to: C:\Users\GB\Documents\spreadtrum_module\backup\spd _simlock_nvram_backup\358074095529676__W_K120SUN_u ser_8_1_0_OPM2_171019_012_1536724428_release_keys_ LA051843001456\ This simlock type is not supported yet. Abort opperation. Done. Can You do update please for this version?? Thanks in advance BR Goran |
good update we more waiting fast unlocking team |
