Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box Premium v2
Old 02-05-2019, 00:52   #1 (permalink)
Fast Unlocking's Avatar
Member: 94675
Sonork: 100.8888 QQ3161545070
Thanks Meter: 97,267
NCK Box / NCK PRO Spreadtrum Module v0.7 Update Released - [05/02/2019]
1. Added Basic support for SC6531EFM
- Supported Repair IMEI
-- Factory Reset
--- Read & Write NVRam
---- Write PAC File.
2. Added 2 Methods to service Phones in DIAG Mode.
- Old Method allow only to:
-- Read info (SimLock)/Reset phone/Repair IMEI/BT/Wifi
- New Method allow also to:
-- Perform Direct unlock in diag mode.
--- Usually new method work on phones with android 5.1 and more new.
---- It work also on SC6531EFM, possible on other generic phones too.
3. Added support for Simlock types 2,3,5 and 6 in DIAG Mode.
- For this types will be displayed sim unlock code on read info, and new phones will allow direct unlock.
-- For other types will need Simlock backup and link to phone firmware.
3. Remade PAC files Writer.
-- Now it become more universal and stable.
--- Supported EMMC and NOR phones
---- NAND phones support will be added in incoming updates.
4. Added possibility to select custom backup directory.
5. Added custom loader for wiko sunny 3 in custom folder.
This loader can be used to remove phone FRP.
To perform sim unlock is recommended to use DIAG Mode.
Official Website:
NCK BOX
Download from Support Access Software to Access Download Area
Link:
Download Area
The Following 38 Users Say Thank You to Fast Unlocking For This Useful Post:
Old 02-05-2019, 03:21   #2 (permalink)
Member: 2145475
Thanks Meter: 100
Thanks for you NCK TEAM,Good Update but plz add Android 8.1.0 formate & frp...Thanks in Advance
The Following 2 Users Say Thank You to azaanali For This Useful Post:
Old 02-05-2019, 03:37   #3 (permalink)
Member: 2145475
Thanks Meter: 100
Thanks NCK TEAM & AVENGAR TEAM
The Following 3 Users Say Thank You to azaanali For This Useful Post:
Old 02-05-2019, 03:38   #4 (permalink)
Member: 2145475
Thanks Meter: 100
Waooo verry nice update
Old 02-05-2019, 05:42   #5 (permalink)
Member: 756129
Thanks Meter: 5
Good add frp side load qualcomm
Old 02-05-2019, 06:23   #6 (permalink)
Member: 1450664
Thanks Meter: 168
pl edit ck/nck
CK BOX & Avengers Spreadtrum Module v0.7 Update Released - [05/02/2019]
Old 02-05-2019, 08:34   #7 (permalink)
Member: 2749053
Sonork: Sharif
Thanks Meter: 14
Please team thanks for update but next time 8.1.0 needed to be suppoted too thanks for your best
Old 02-05-2019, 10:56   #8 (permalink)
Member: 2601900
Thanks Meter: 519
android 8.1 format is supported already in diag mode, and More than 60% of 8.1 FRP is supported via custom loader, for example all ITEL A14,A16 8.0 ALL MOBICEL 8.1 supported too.
The Following 2 Users Say Thank You to mmtheo For This Useful Post:
Old 02-05-2019, 12:08   #9 (permalink)
hunter-s's Avatar
Member: 1509218
Thanks Meter: 163
sunny 3 unlock done
ACTION: Unlock Phone.
Detecting phone, wait...
Phone must be off.
Connect usb cable without pressing any key.
Using connection mode 1
Platform Version MOCORTM_17C_W18.23.4_P2_DebugProject Version pike2_pubBASE Version FM_BASE_17C_W18.23.4_P2HW Version sc7731e_modem06-20-2018 111140
Build number: W_K120SUN-user 8.1.0 OPM2.171019.012 153672++++ release-keys
Serial number: LA05184+++++
IMEI 1: 35807409+++++
IMEI 2: 358074095+++++
BT: 44D3AD34+++
WIFI: 44D3AD3++++
Reading simlock, wait....
[0:0][USER]Simlock Status: LOCKED[1] Simlock Counter:[10/10]
[3]Simlock Type: 0 0
Sim 1 Unlock Code: 88190293
Sim 2 Unlock Code: 88191273
Warning, this is factory key, some opperators can modify factory key.
Saved to: C:\Users\hunte\Documents\spreadtrum_module\backup\ spd_simlock_nvram_backup\358074095++++++__W_K120SU N_user_8_1_0_OPM2_171019_012_1536724428_release_ke ys_LA051843004208\
Writing simlock...
Writing simlock ok
Done. Thanks in Advance
The Following 3 Users Say Thank You to hunter-s For This Useful Post:
Old 02-05-2019, 12:56   #10 (permalink)
Member: 816596
Sonork: zinnou
Thanks Meter: 14
sunny 3 unlock done read code done
ACTION: Read Simlock Info.
Phone must be off.
Detected: SPRD U2S Diag (COM27)
Build number: W_K120SUN-user 8.1.0 OPM2.171019.012 1536724428 release-keys
Serial number: LA051842001254
IMEI 1: 358074095******
IMEI 2: 358074095******
BT: 44D3AD3487F1
WIFI: 44D3AD346861
[USER]Simlock Status: UNLOCKED
Sim 1 Unlock Code: 88190963
Sim 2 Unlock Code: 88191843
Done.
The Following 3 Users Say Thank You to zinnou For This Useful Post:
Old 02-05-2019, 13:34   #11 (permalink)
Member: 2669023
Thanks Meter: 17
Most wanted update thanks nck team
Old 02-05-2019, 14:54   #12 (permalink)
Member: 787088
Thanks Meter: 22
Start Detect phone.
With powered off phone, insert usb cable
Detected: SPRD U2S Diag (COM23)
Port opened ok.
Phone must be off.
Making 10 sec timeout..
Done.
I CANT ENTERING TO DIAG MODE PLEASE HEL ME
Old 02-05-2019, 15:59   #13 (permalink)
Member: 787088
Thanks Meter: 22
THANKS NCK BOX I UNLOCK THIS SUNNY3 AND REPAIR IMEI EXE: NckBox Spreadtrum Module 0.7
SELECTED: SC7731C_EMMC
ACTION: SimUnlock
Custom loader: wiko_Sunny3.loader
Sending loader, keep boot key untill loader start.
Loader OK: Spreadtrum Boot Block version 1.1
Changing bautrate OK.
Send Second Loader.
FileSystem: EMMC
Manufacturer: WIKO
Hardware: k120_v1.1.0
Build Id: OPM2.171019.012
Model: Sunny3
Android Release: 8.1.0
Android Version: OPM2.171019.012 release-keys
IMEI 1: 358074095490***
IMEI 2: 358074095570***
Simlock Type: 3
Backup saved to: C:\Users\Flamuri\Documents\spreadtrum_module\backu p\spd_simlock_nvram_backup\358074095497148__W_K120 SUN_user_8_1_0_OPM2_171019_012_1536724428_release_ keys_LA051843002090\spreadtrum_module\simlock_back up_nvram\OPM2.171019.012 release-keys\w_fixnv1.bin
Start write unlock, wait...
Total Time: 00:00:19
Done.
The Following 2 Users Say Thank You to flamuri For This Useful Post:
Old 02-06-2019, 23:42   #14 (permalink)
Member: 10191
Thanks Meter: 21
Please HELP!
with Read Simlock Info I get this:
Phone must be off.
Detected: SCI USB2Serial (COM70)
Serial number: LA051843001456
IMEI 1: 358074095529676
IMEI 2: 358074095610476
BT: 44D3AD348517
WIFI: 44D3AD346587
[0]Simlock Type: 0 0
Done.
BUT!!!
When I use Remove Simlock I get this error
Phone must be off.
BT: 44D3AD348517
WIFI: 44D3AD346587
Saved to: C:\Users\GB\Documents\spreadtrum_module\backup\spd _simlock_nvram_backup\358074095529676__W_K120SUN_u ser_8_1_0_OPM2_171019_012_1536724428_release_keys_ LA051843001456\
This simlock type is not supported yet.
Abort opperation.
Done.
Can You do update please for this version??
Thanks in advance
Goran
Old 02-08-2019, 18:24   #15 (permalink)
Member: 2346573
Thanks Meter: 6
good update we more waiting fast unlocking team
Page generated in 0.33092 seconds with 8 queries
