01-27-2022, 18:09 | #3 (permalink) |
No Life Poster Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 850 | Action : Read Firmware. Selected 0-By CPU:ELBRUS Exe version: NCKDongle AndroidMTK 2.7.7 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(35) : MediaTek USB Port (COM35) [35] \\?\usb#vid_0e8d&pid_0003#5&3831c885&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6765 CPU code: 766 Target config: e7 *********************** Secure boot enabled: true Need serial link authorization: true Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. Error dumping preloader, please use external preloader to boot phone. Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(35) : MediaTek USB Port (COM35) [35] \\?\usb#vid_0e8d&pid_0003#5&3831c885&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Phone is connected in BROM mode No flash definitionj loaded. Please connect phone in preloader mode or load scatter and preloader for this phone. After repeat opperation again. Error[0xffffffff]: ?? BBCHIP MT6765 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. |
01-27-2022, 19:15 | #5 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Exe must dump auto preloader, for some reason it not do this. Code: Error dumping preloader, please use external preloader to boot phone. Code: No flash definitionj loaded. Please connect phone in preloader mode or load scatter and preloader for this phone. After repeat opperation again. Error[0xffffffff]: ?? From some reason exe not read preloader from phone. Can me multiple reasons for this. Exe backup directory can be read only(from settings change backup directory location) or phone have damaged preloader. Also you can use preloader from phone with comatible cpu, if your flash ic is listed in preloader, this will work also. |
