09-19-2014, 10:05 | #2341 (permalink) |
No Life Poster Join Date: Feb 2013 Location: U.P-75 ETAWAH Age: 34
Member: 1889562 Status: Offline Thanks Meter: 617 | b209 phone lock contact servise done Code: Module Ver. : 1.9 Com Port : COM3 : USB Serial Port (COM3) Baud Rate : 9600 (Auto) Device : Samsung B209 Operation : Full Rebuild Setting test mode... Executing full rebuild... Operation finished. Port closed. Elapsed Time: 00:03 Log saved as \!Log\LOG_14_09_19_02_03_53.log |
The Following User Says Thank You to ashish800 For This Useful Post: |
09-19-2014, 10:06 | #2342 (permalink) |
Member: 1889562 Status: Offline Thanks Meter: 617 | b209 unlock done.. Code: Module Ver. : 1.9 Com Port : COM3 : USB Serial Port (COM3) Baud Rate : 9600 (Auto) Device : Samsung B209 Operation : Unlock Port opened. Setting test mode... Step 1... Step 2... Step 3... Resetting phone... Phone must restart if everything OK! Operation finished. Port closed. Elapsed Time: 00:04 Log saved as \!Log\LOG_14_09_19_02_05_23.log |
09-19-2014, 10:08 | #2343 (permalink) |
Member: 1889562 Status: Offline Thanks Meter: 617 | b279 unlock Code: Module Ver. : 1.9 Com Port : COM3 : USB Serial Port (COM3) Baud Rate : 9600 (Auto) Device : Samsung B279 Operation : Unlock Port opened. Setting test mode... Step 1... Step 2... Resetting phone... Phone must restart if everything OK! Operation finished. Port closed. Elapsed Time: 00:07 Log saved as \!Log\LOG_14_09_19_02_07_02.log |
09-19-2014, 10:22 | #2344 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | Huawei G7010 flashing done :) DA version: 5.1316.00.00 USER SELECTION : WRITE FIRMWARE. MODEL SELECTED : G7010 Com port opened...Press power on Download DA now...You can release power on DA download finished...Getting phone info BaseBand CPU:MT6253_S00 BaseBand CPU Secure Version : FF INT RAM: 1Mb EXT RAM NOT ACTIVATED. FLASH TYPE : NOR ID: NOR128Mb+0Kb) [SPANSION] S29VS128R_B size:0x01000000 CHANGE BAUDRATE SUCCES Format FAT area disabled, skip. In some phones need to do auto fat format after flash. If phone stuck on logo after flash, make "AUTO FAT FORMAT". START DOWNLOAD FLASH. MAKE PREFLASH CONFIG, THIS CAN TAKE UP TO 1 MIN. ACTION : PROGRAMMING TARGET. Finalization :S_DONE(0) ALL DONE. |
09-19-2014, 14:36 | #2346 (permalink) |
Member: 1889562 Status: Offline Thanks Meter: 617 | m131 b04 ver write flash Code:
09-19-2014, 14:38 | #2347 (permalink) |
Member: 1889562 Status: Offline Thanks Meter: 617 | m131 weite meid Code: Module Ver. : 1.9 Com Port : COM33 : ZTE CDMA Handset Diagnostics Interface (COM33) Baud Rate : 115200 Device : M131 Operation : Write MEID Port opened. Compile : Apr 24 2014 22:06:45 Release : Apr 24 2009 24:00:00 Hw Ver. : V.MTS.M1 ESN : 00000000 MEID : 00000000000000 MemUnlock : Success. Build : V.MTS.M131.B04 Detected : M131 User Code : 0000 Writing MEID A0000038EABFF7 Write success. New ESN : 807B5BA7 New MEID : A0000038EABFF7 Operation finished. Port closed. Elapsed Time: 00:01 |
09-19-2014, 15:08 | #2348 (permalink) |
Member: 1889562 Status: Offline Thanks Meter: 617 | 2930t weite flash Code: Module Ver. : 1.9 Com Port : COM46 : HUAWEI CDMA Handset - Application Interface (COM46) Baud Rate : 115200 Device : Huawei C2930T Operation : Write APP/EFS Port opened. Preparing phone... Requesting authorization... Authorization accepted. Phone prepared. Continuing... Erasing APP region... Writing APP region... File Name : amss.mbn File Size : 0058E298 Erasing EFS region... Writing EFS region... File Name : cefs_modem.mbn File Size : 001F0000 Resetting phone... Port closed. Operation finished. Elapsed Time: 04:23 Log saved as \!Log\LOG_14_09_19_07_06_33.log |
09-19-2014, 15:09 | #2349 (permalink) |
Member: 1889562 Status: Offline Thanks Meter: 617 | 2930t write flash note- 2856 set after write 2930t file for unlocking show only searching network solve by nck box thx a lot nck team Last edited by ashish800; 09-19-2014 at 15:18. |
09-22-2014, 09:51 | #2353 (permalink) |
Member: 1889562 Status: Offline Thanks Meter: 617 | 1602 unlock Code: Module Ver. : 1.9 Com Port : COM33 : ZTE CDMA Handset Diagnostics Interface (COM33) Baud Rate : 115200 Device : ZTE S1602 Operation : SP UNLOCK Port opened. Compile : Jul 06 2011 11:34:43 Release : Apr 24 2009 24:00:00 Hw Ver. : V.MTS.S1 ESN : 80300EA1 MEID : A1000020DB0010 MemUnlock : Success Build : V.MTS.S1602.B01 Detected : S1602 User Code : 0000 Setting Download mode... Mode change OK. Waiting for reconnect... Initializing Flash Protocol... Flash Chip : NUMONYX M36W0R6050U4ZSd Chip Size : 8 MB Patching security area... Patching success. Resetting phone... Phone successfully unlocked. Port closed. Operation finished. Elapsed Time: 00:14 Log saved as \!Log\LOG_14_09_22_01_44_12.log |
09-22-2014, 14:35 | #2354 (permalink) |
Member: 1889562 Status: Offline Thanks Meter: 617 | b319 phon unloced done Code: Module Ver. : 1.9 Com Port : COM3 : USB Serial Port (COM3) Baud Rate : 9600 (Auto) Device : Samsung B319 Operation : Full Rebuild Setting test mode... Executing full rebuild... Operation finished. Port closed. Elapsed Time: 00:03 Log saved as \!Log\LOG_14_09_22_06_34_13.log |
09-22-2014, 14:36 | #2355 (permalink) |
Member: 1889562 Status: Offline Thanks Meter: 617 | b319 sp unlocked done Code: Module Ver. : 1.9 Com Port : COM3 : USB Serial Port (COM3) Baud Rate : 9600 (Auto) Device : Samsung B319 Operation : Full Rebuild Setting test mode... Executing full rebuild... Operation finished. Port closed. Elapsed Time: 00:03 Log saved as \!Log\LOG_14_09_22_06_34_13.log |
