03-16-2015, 12:37 | #3121 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | Now connect phone to PC Start detect phone. Injecting Loader.. Reconnecting phone, this can take few second.. Start detect phone. Loader started ok. Reading Phone Info, please wait.. Phone Imei : 353026042834117 Phone SN : 7XA7NC1190601833 Phone Firmware : U8500V100R001C00B718_EFS SimLock marker found.. Total markers found : 1 Simlock Status : Locked. Removing SimLocks Please Wait... Read marker : 1 Write marker : 1 All Done. If Phone not have network after unlock, use fix network please. |
03-16-2015, 16:12 | #3123 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Uzbekistan / Bukhara
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | Beeline SMART 3 Read codes done Selected connection metod: META Mode Exe version: NCKDongle AndroidMTK 2.5.4.9 Selected phone: Liquid Z110 Scanning for presents meta ports... Meta ports not detected, starting brom stage. Phone must be off with battery inside. Please insert USB cable now... Detected(0) : MediaTek PreLoader USB VCOM Port (COM53) Starting META mode, wait... If drivers missing, please install CDC drivers. Restarted to meta ok, waiting for meta port.... META Port Detected[55] Android Gadget VCOM Driver (COM55) Start sync target, waiting responce..... BaseBand CPU : MT6572, E01 SW_VER : MOLY.WR8.W1315.MD.WG.MP.V36.P1 HW_VER : ZZTENJ72_WE_72_M536_KK_HSPA_HW Meta mode conected ok, start reading phone.... Phone imei[1] : 865784020244698 Phone imei[2] : 865784020244698 Simlock Info : Sim [1] Block1[N] :Locked [remain:100] Code : 12345678 Block2[NS] :Unlocked Code: 56781234 Block3[SP] :Unlocked Code: 11112222 Block4[C] :Unlocked Code: 33334444 Block5[SIM]:Unlocked Code: 55556666 ************************************** Simlock Info : Sim [2] Block1[N] :Locked [remain:100] Code : 12345678 Block2[NS] :Unlocked Code: 56781234 Block3[SP] :Unlocked Code: 11112222 Block4[C] :Unlocked Code: 33334444 Block5[SIM]:Unlocked Code: 55556666 ************************************** 1.Power phone with unacepted simcard. 2.Type code code when phone ask about. 3.For advansed info power phone with original card. 4.Type *#*#3646633#*#* and from engeneering menu select SIMMELOCK If phone relock after power off, enter unlock code and make wipe. |
03-16-2015, 21:58 | #3125 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Serbia
Member: 1425628 Status: Offline Thanks Meter: 235 | e1050 unlock by read codes in flash mode Code: COMPORT : COM10 Selected : GT-E1050V: SYSOL Press and keep Power ON!!! Boot OK. Loading Preloader, keep press power on. Send Preloader OK. Flash ID: 007A Flash Name: K5N6433ATM_TOP Try Change BaudRate. Loading Mainloader.. Send Mainloader ok. Reading Eeprom Data.. Analyzing Data.. Parsing eeprom, wait. - Firmware : E1050VXXKC2 - Imei : 35911304064xxxx Code[1] Found: 73138530 Master Unfreeze: 24738610 Done. |
03-17-2015, 03:23 | #3126 (permalink) |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | Explay sQuad_7.82 3G Tablet hang on logo solved with flashing via nck dongle ))) Code: Flash files count is :12 Action : Firmware update. Selected Samsung Clone: S5 I9600(MT6582) Exe version: NCKDongle AndroidMTK 2.5.4.9 DA: MTK_AllInOne_DA.bin Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM51) Phone detected...Please wait Sending DA agent, please wait... BBCHIP MT6589_S00 EMMC: (116Gb+8192Mb) SAMSUNG 0x4d4147325741 EMMC FW VERSION: 01:00:00:00:00:00:00:00 BOOT STYLE : EMMC BOOT Detecting high speed port, wait...... If driver not installed, install high speed port driver. Detected : MediaTek DA USB VCOM Port (COM54) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Starting flash. Download firmware to flash now... MBR checksum is executing ... EBR1 checksum is executing ... UBOOT checksum is executing ... BOOTIMG checksum is executing ... RECOVERY checksum is executing ... SEC_RO checksum is executing ... LOGO checksum is executing ... EBR2 checksum is executing ... ANDROID checksum is executing ... CACHE checksum is executing ... USRDATA checksum is executing ... Wait untill phone will start charging. All done. |
03-17-2015, 10:14 | #3128 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | Megafon Login 2 Direct unlock done ... Quote:
The Following User Says Thank You to UzUnlocker For This Useful Post: |
03-17-2015, 10:16 | #3129 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | Megafon M100-4 4G modem code calculated )) Quote:
03-17-2015, 12:18 | #3130 (permalink) |
Member: 1995502 Status: Offline Thanks Meter: 139 | Samsung E1230 Read codes done :) COMPORT : COM3 Selected : GT-E1230: SYSOL Press and keep Power ON!!! Boot OK. Loading Preloader, keep press power on. Send Preloader OK. Flash ID: 007A Flash Name: K5N6433ATM_TOP Try Change BaudRate. Loading Mainloader.. Send Mainloader ok. Reading Eeprom Data.. Analyzing Data.. Parsing eeprom, wait. - Firmware : E1230XXLD2 - Imei : 358735046870688 Code[1] Found: 38380140 Master Unfreeze: 66077390 Done. |
03-17-2015, 15:54 | #3131 (permalink) |
No Life Poster Join Date: Jan 2013 Location: NCK Team
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | ★★★★★ NCK Dongle News & Updates ★★★★★ NCK Dongle Shell v1.0 Making Things Easy for Our Valuable Users Added: - Update Scenario to Update a Particular Module Files Only - Driver Downloader Update Scenario If you wish to update files related to any particular module only, then select that Module Name in Update Scenario List. If you wish to update all as usual, select ---ALL--- which is selected by default. Driver Downloader A simple tool to detect USB devices on your system. No more need to check which driver is needed. Simply find all devices with driver issue, or even device with no driver loaded. Just a few clicks and it will try to identify your device automatically and will allow you to download its driver if found. [x] Find - Click it and it will display list of all USB Device ever connected to your PC. Tick Bad Devices Only Checkbox if you need to find devices only with driver issues or with not drivers. Tick Connected Device Only if you want list of USB Devices which are currently connected to your PC. If you tick both Checkbox then it will list only currently connected devices with driver issues. [x] Detect - Click this button and then connect your USB Device like phone etc and it will try to detect to it and show in list. If Only Bad Devices is ticked then it will list Device only if that device is not properly installed. If Only Bad Devices is not ticked, it will list all devices which it detected. [x] Identify - When device list is populated, you need to click this button. Software will connect to server to fetch information of listed devices. If a device was identified by server, you will see its description and Driver name in Status column. A "Y" in Get column means you can download that driver. If you don not want to download that particular driver, simply double click on that device and "Y" will disappear. [x] Download - When device identification has been completed and Driver name has been populated, you can download driver by click on Download button. All drivers will be downloaded in Drivers folder inside Download Location path (check in Installers page). [x] Save Log - If you find out that some devices were not identified by Server, you can save log and post it our support section so that we can update Identification System and provide you driver. [x] Clear - Clear Device list. [x] Explore - Driver download location will open in Windows Explorer. NOTE: (1) If you are using Auto Updater feature, please keep note that you can update your Installation to latest update when you see Update News page in Shell is updated. (2) Always update Shell Database with Update Database Option in Auto Updater Page. It will help you to find if a Model is supported and if yes, then in which module. Searching in shell before post will save time for both of us. Download NCK Dongle Shell v1.0 Setup from Support Area by NCK Dongle Main Module > Settings > Go Support or Use Shell > Installer Page to download. NCK Dongle Official Website Follow Us on Twitter Like Us on Facebook NO THANKS POSTS OR SPAM POSTS PLEASE, ONLY DISCUSSION REGARDING THIS UPDATE! ANYTHING ELSE WILL BE DELETED. Br, NCK Team |
03-17-2015, 17:49 | #3132 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Uzbekistan/Samarkand))
Member: 1981875 Status: Offline Thanks Meter: 63 | Samsung Clone:Galaxy S4 Clone(MT6572) IMEI REPAIRE DONE WITH ADB MODE. Action : IMEI REPAIR. Selected Samsung Clone:Galaxy S4 Clone(MT6572) IMEI for write : 3552360301***** Repair IMEI Start. Phone lcd must be on and unlocked. If ask for SU acces, accept it. Device have root ---NVRAM IMEI---- PHONE IMEI 1 : PHONE IMEI 2 : --------- WRITING IMEI[1] :3552360301***** --------- Writed OK. IMEI REPAIRE DONE WITH ADB MODE. Thanks TAEM!!! |
03-17-2015, 18:08 | #3133 (permalink) |
No Life Poster Join Date: May 2013
Member: 1930570 Status: Offline Thanks Meter: 82 | UNLOCK DONE WITH NCK BOX BRAND: ALCATEL MODEM MODEL: Y580D IMEI: 86810xxxxxxx NCK : 6250945077 NSCK : 1527203024 SPCK : 5290136448 SIM : 4710256227 C : 2428822937 Other :9456292372 |
