02-28-2017, 11:49 | #5266 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | USB Connection selected. EXE VERSION: NCKBox MTK Tool 3.9 Connect phone in boot mode ... USB\VID_0E8D&PID_0003&REV_0100 Com port ok : COM62 Phone detected...Please wait Conected ok with target ... Reopen comport(COM62) BaseBand CPU : MT6276 SW_VER : 5516_NL242_S03A_V02_M160920_MP HW_VER : SAGETEL76_1G512_11B_HW Meta mode conected ok, start reading phone.... Phone imei[1] : 3516140800AAAAA Phone imei[2] : 3516140800AAAAA UNLOCK SIM[1]: Unlock ok sim[1] SIMLOCK INFO[1]: Block1[N]: Unlocked Block2[NS]: Unlocked Block3[SP] Unlocked Block4[C]: Unlocked META END OK. All done. |
02-28-2017, 11:56 | #5267 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | MobiWire Pictor Direct Unlock Done.... USB Connection selected. EXE VERSION: NCKBox MTK Tool 3.9 Connect phone in boot mode ... USB\VID_0E8D&PID_0003&REV_0100 Com port ok : COM97 Phone detected...Please wait Conected ok with target ... Starting meta mode..... IMEI[1]: 3577170616AAAAA IMEI[2]: 3577170616AAAAA Start read, wait.... Block1[N]: Locked (remain:0) Code : 12345678 Block2[NS]: Unlocked Block3[SP] Unlocked Block4[C]: Unlocked Unlock file done Unlock file done Processing done. Unlock done. Clean tmp directory....wait. Clean tmp directory....done. META END OK. All done. |
The Following User Says Thank You to razib143 For This Useful Post: |
02-28-2017, 12:00 | #5268 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | MTN SMART L860 FRP REMOVE DONE Code: Exe version: NCKBox AndroidMTK 1.8.7.7 Selected model: MT6735M Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM148) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6735M_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) HYNIX 0x483847316505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A48384731 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2c00000 [7.293 GB] Preloader SEC version: 2 Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. |
03-01-2017, 08:20 | #5269 (permalink) |
Freak Poster Join Date: May 2010 Location: phil.
Member: 1301933 Status: Offline Sonork: wynn Thanks Meter: 28 | oppo r1001 hang on logo , flashing done.. Flash files count is :14 Action : Firmware update. Selected Model: 0-By CPU: MT6572_EMMC Exe version: NCKBox AndroidMTK 1.8.7.7 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port (COM10) Boot mode: Brom Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : 00 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 05:00:00:00:00:00:00:00 EMMC CID: 90014A48344731 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Preloader SEC version: 2 Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM (Android) (COM9) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. |
03-01-2017, 09:51 | #5270 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | Conected ok with target ... Reopen comport(COM14) BaseBand CPU : MT6276 SW_VER : V322_01A_CFZZ_QVGA_WGD_YC8_V06 HW_VER : V322_01A Meta mode conected ok, start reading phone.... Phone imei[1] : 359767058004343 Phone imei[2] : 359767058004350 UNLOCK SIM[1]: Unlock ok sim[1] UNLOCK SIM[2]: Unlock ok sim[2] SIMLOCK INFO[1]: Block1[N]: Unlocked Block2[NS]: Unlocked Block3[SP] Unlocked Block4[C]: Unlocked SIMLOCK INFO[2]: Block1[N]: Unlocked Block2[NS]: Unlocked Block3[SP] Unlocked Block4[C]: Unlocked META END OK. All done. |
03-01-2017, 14:50 | #5271 (permalink) |
No Life Poster Join Date: Oct 2013 Location: Cote Ivoire ABJ,tvlle, LBJ.23 Age: 39
Member: 2041210 Status: Offline Thanks Meter: 541 | Infinix Action : Reset to factory default. Selected Model: 0-By CPU:MT6753 Exe version: NCKDongle AndroidMTK 2.5.7.5 Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [55]Detected: MediaTek PreLoader USB VCOM (Android) (COM55) \\?\usb#vid_0e8d&pid_2000#6&61bf49f&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [143]META Port Detected: MediaTek USB VCOM (Android) (COM143) USB\VID_0E8D&PID_2007\6&61BF49F&0&2 Start sync target, waiting responce..... Resetting phone, wait.... Resetting phone step 2, wait.... Reset to factory default ok. All done. |
03-01-2017, 14:51 | #5272 (permalink) |
03-01-2017, 16:33 | #5273 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | alcatel ot355x calcalate code done Exe Version: NCKdongle v18.4 IMEI checksum seems ok Model: OT355 IMEI: 353923049880145 PID: BYFR1(XI46CRB2) NCK : 2760571545 NSCK: 0682218443 SPCK: 2746990366 SIM : 2654711868 CORPORATE: 0927145591 |
03-01-2017, 20:44 | #5274 (permalink) |
No Life Poster Join Date: May 2001 Location: Lazarevac,SRBIJA Age: 48
Member: 4772 Status: Offline Thanks Meter: 556 | Alcatel OT5022x calculate code OK EMMC FW VERSION: 12:00:00:00:00:00:00:00 EMMC CID: FE014E50314A39 : 000000000000000000 EMMC UA SIZE: 0x1d3000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d3600000 [7.303 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM (Android) (COM144) OTP IMEI: 352934071xxxxxx MODEL FROM PROINFO: 5022X-2ATNRS1-2 SECRO FROM PROINFO: XMP15X1YRSTN Reading security, wait... SIM[1]: Block1(N): Locked (remain:4) Code : 6362345144xxxxxx Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Please note, some firmwares can display wrong codes. Some firmwares can be hardlocked. If this happen, perform direct unlock. If direct unlock fail,use reset package from support. If reset package not exist in support,request help in forum. Wait untill phone will start charging. All done. |
03-02-2017, 06:13 | #5275 (permalink) |
Freak Poster Join Date: Jan 2008 Location: philippines
Member: 669596 Status: Offline Sonork: 1657504 Thanks Meter: 136 | Alcatel OT-5045T "Smart Locked" Unlock DONE by Read Codes. Code: Selected connection metod: FLASH Mode Exe version: NCKDongle AndroidMTK 2.5.7.5 Selected model: OT-5045T Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM47) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6735M_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) MICRON 0x50314a39354b EMMC FW VERSION: 12:00:00:00:00:00:00:00 EMMC CID: FE014E50314A39 : 000000000000000000 EMMC UA SIZE: 0x1d3000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d3600000 [7.303 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM (Android) (COM75) OTP IMEI: 35936----------- MODEL FROM PROINFO: 5045T-2ASAPH1 SECRO FROM PROINFO: L7EFSSG0BP20 Reading security, wait... SIM[1]: Block1(N): Locked (remain:10) Code : 1005417501998648 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Please note, some firmwares can display wrong codes. Some firmwares can be hardlocked. If this happen, perform direct unlock. If direct unlock fail,use reset package from support. If reset package not exist in support,request help in forum. Wait untill phone will start charging. All done. |
03-02-2017, 10:45 | #5276 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Zimbabwe
Member: 2100642 Status: Offline Thanks Meter: 46 | Huawei Ascend Y360-U72 Unlock done by selecting Y360-U31,Flash mode selected Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.7.7 Selected model: Ascend Y360-U31 Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM85) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) HYNIX 0x483447326111 EMMC FW VERSION: 02:00:00:00:00:00:00:00 EMMC CID: 90014A48344732 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM Port (COM145) IMEI[1]: 869459022793747 IMEI[2]: 869459022793747 Reading security, wait... SIM[1]: Block1(N): Unlocked (remain:10) Code : Block2(NS): Locked (remain:9) Code : 963a2e737ceede5 Block3(SP): Unlocked Block4(C): Unlocked SIM[2]: Block1(N): Unlocked (remain:5) Code : Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. Thank you team BR |
03-02-2017, 11:08 | #5277 (permalink) |
Member: 2100642 Status: Offline Thanks Meter: 46 | Huawei Ascend Y6 2 Compact LYO-LO2 Unlock done,direct unlock selected Selected connection metod: META Mode Exe version: NCKBox AndroidMTK 1.8.7.7 Selected model: Ascend Y6 II compact[LYO-L02] Action: Unlock Scanning for presents meta ports... Meta ports not detected, starting brom stage. Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [85]Detected: MediaTek PreLoader USB VCOM Port (COM85) \\?\usb#vid_0e8d&pid_2000#5&9f4bf02&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [160]META Port Detected: Android Gadget VCOM Driver (COM160) USB\VID_0E8D&PID_2007\5&9F4BF02&0&1 Start sync target, waiting responce..... [AP]BaseBand CPU : mt6735,S01 [AP]APP_VER: LYO-L02C712B103 Making target channel configuration, wait... Making tunnel configuration, wait... Rebooting to meta, wait.... [META]BaseBand CPU : MT6735, E00 [META]SW_VER : MOLY.LR9.W1444.MD.LWTG.MP.V42.P34 [META]HW_VER : HQ6753_65C_B1N_L1_HW Phone imei[1] : 861947030795033 Start direct unlock[SIM1] Direct unlock done Wrong data reseived from target!!!!! CHK reseived:5a CHK Calculated: 0 Direct unlock done Clean Boot flag ok. All done. Thank you team |
03-02-2017, 11:16 | #5278 (permalink) |
Member: 2041210 Status: Offline Thanks Meter: 541 | Tecno L6 created dump & fortmat user data done Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM7) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6582_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x513758534142 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 15010051375853 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : Miracle DA USB VCOM (Android) (COM34) Build ID: KOT49H Display ID: L6-QP68-20141215 Version: 4.4.2 Build Date: Mon Dec 15 20:04:12 CST 2014 Build Date: 1418645052 Model: TECNO L6 Brand: TECNO Device: TECNO L6 Manufacturer: TECNO Region: US Mediatek Version Release: L6-QP68-20141215 IMEI[1]: 357414060535202 IMEI[2]: 357414060535210 Dumping Preloader. Start dumping flash, this can take up to 1 hour....... Start procesing MBR Reading: BEGIN: 0xc00000 - LEN: 0x200 Start procesing EBR1 Reading: BEGIN: 0xc80000 - LEN: 0x200 Start procesing proinfo Reading: BEGIN: 0xd00000 - LEN: 0x300000 Start procesing nvram IMEI[1] from NVRAM: 357414060535202 IMEI[2] from NVRAM: 357414060535210 Start procesing PROTECT_F ...... Reading: BEGIN: 0x1500000 - LEN: 0xa00000 Start procesing PROTECT_S ...... Reading: BEGIN: 0x1f00000 - LEN: 0xa00000 Start procesing UBOOT ...... Start processing BOOTIMG Start processing RECOVERY Start procesing secro Start procesing LOGO ...... Start procesing system Reading: BEGIN: 0x5d00000 - LEN: 0x82000000 Backup CACHE disabled, we will skip it.... Backup USRDATA disabled, we will skip it.... Saved to : C:\Users\MR ZyKoV Tchaikovsky\Documents\Android_MTK\firmware_backup\ MT6582_S01_EMMC_KOT49H__4.4.2_TECNO L6_TECNO_357414060535202_357414060535210_03_02_201 7_09_56_34 Wait untill phone will start charging. All done. Job canceled! Action : Format UserData. Selected 0-By CPU:MT6582 Exe version: NCKDongle AndroidMTK 2.5.7.5 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM7) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6582_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x513758534142 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 15010051375853 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : Miracle DA USB VCOM (Android) (COM34) Detecting format adress....wait! Starting generic userdata format...! FORMAT EMMC FLASH : BEGIN: 0x87d00000 - LEN: 0x7e00000 FORMAT EMMC FLASH : BEGIN: 0x8fb00000 - LEN: 0x141880000 All done. |
03-02-2017, 12:17 | #5279 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algeria
Member: 574410 Status: Offline Thanks Meter: 93 | alcatel one touch 7041D flash done Flash files count is :16 Action : Firmware update. Selected Model: 0-By CPU: MT6571_EMMC Exe version: NCKBox AndroidMTK 1.8.7.6 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM9) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6582_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) TOSIBA 0x303034473930 EMMC FW VERSION: 10:00:00:00:00:00:00:00 EMMC CID: 11010030303447 : 000000000000000000 EMMC UA SIZE: 0xec000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xec480000 [3.692 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM (Android) (COM18) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader backup already exist, skip saving. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. |
03-02-2017, 21:56 | #5280 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Alcatel OT-5045A(Digicel Trinidad&Tobago) PIXI4_5 UNLOCK DONE Code: Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.7.7 Selected model: OT-5045A Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM37) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6735M_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) MICRON 0x50314a39354b EMMC FW VERSION: 12:00:00:00:00:00:00:00 EMMC CID: FE014E50314A39 : 000000000000000000 EMMC UA SIZE: 0x1d3000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d3600000 [7.303 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM (Android) (COM115) OTP IMEI: 01460300XXXXXX MODEL FROM PROINFO: 5045A-2CC9JMD SECRO FROM PROINFO: X7E0OP00BP10 Reading security, wait... SIM[1]: Block1(N): Locked (remain:10) Code : 0444899745222612 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Please note, some firmwares can display wrong codes. Some firmwares can be hardlocked. If this happen, perform direct unlock. If direct unlock fail,use reset package from support. If reset package not exist in support,request help in forum. Wait untill phone will start charging. All done. |
