02-18-2018, 15:29 | #6361 (permalink) |
Junior Member Join Date: Mar 2013 Location: Morocco
Member: 1907078 Status: Offline Thanks Meter: 5 | Alcatel OT-4009X unlock done by read code Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) MICRON 0x50314a39344d EMMC FW VERSION: 12:00:00:00:00:00:00:00 EMMC CID: FE014E50314A39 : 000000000000000000 EMMC UA SIZE: 0xe9800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9b00000 [3.651 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED MODEL FROM PROINFO: 4009X-2AAMMA1-3 SECRO FROM PROINFO: L4B1C4Z1AZ10 OTP IMEI: 355749080541827 Reading security, wait... SIM[1]: Block1(N): Locked (remain:5) Code : 5717081279411233 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Please note, some firmwares can display wrong codes. Some firmwares can be hardlocked. If this happen, perform direct unlock. If direct unlock fail,use reset package from support. If reset package not exist in support,request help in forum. Wait untill phone will start charging. All done. thnks nck team |
The Following User Says Thank You to nourpccare For This Useful Post: |
02-20-2018, 09:48 | #6363 (permalink) |
Insane Poster Join Date: Jan 2010
Member: 1198084 Status: Offline Thanks Meter: 42 | mobicel play stuck on logo fix by nck dongle Exe version: NCKDongle AndroidMTK 2.5.8.5 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM7) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) HYNIX 0x483847316505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A48384731 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2c00000 [7.293 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. |
02-20-2018, 11:28 | #6364 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Selected connection metod: Meta Connection Exe version: NCKBox AndroidMTK 1.8.8.7 Selected phone: MT6580 Action : IMEI REPAIR. IMEI[1] for write : 3515510814XXXX3 IMEI[2] for write : 351551081XXXXX8 Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [13]Detected: MediaTek PreLoader USB VCOM (Android) (COM13) \\?\usb#vid_0e8d&pid_2000#5&362688dd&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [59]META Port Detected: MediaTek USB VCOM (Android) (COM59) USB\VID_0E8D&PID_2007\5&362688DD&0&1 Start sync target, waiting responce..... [AP]BaseBand CPU : mt6580,S01 [META]BaseBand CPU : MT6580B, E00 [META]SW_VER : MOLY.WR8.W1449.MD.WG.MP.V57 [META]HW_VER : TINNO6580_WE_M_HSPA_HW Meta mode conected ok, start reading phone.... IMEI to repair: [1] 3515510814XXXX3 Phone imei[1] : 35155108144XXXX3 IMEI to repair: [2] 351551081499XXX Phone imei[2] : 35155108149XXXX8 Clean Boot flag ok. All done. |
The Following User Says Thank You to razib143 For This Useful Post: |
02-20-2018, 12:06 | #6365 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Bangladesh
Member: 821462 Status: Offline Thanks Meter: 833 | Huawei Y3II (LUA-U22) FRP Done Exe version: NCKDongle AndroidMTK 2.5.8.5 Selected model: Ascend Y3 II[LUA-U22] Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM559) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6582 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x464e31324d42 EMMC FW VERSION: 06:00:00:00:00:00:00:00 EMMC CID: 150100464E3132 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. |
02-20-2018, 12:07 | #6366 (permalink) |
02-20-2018, 15:55 | #6367 (permalink) |
No Life Poster Join Date: Jul 2008 Location: H.DALAA Age: 49
Member: 820444 Status: Offline Sonork: 100.1680641 Thanks Meter: 466 | oneplus A0001 imei repair done oneplus A0001 imei repair done PHONE: Qualcomm Generic Exe Version: NckBox Qualcomm Module 0.8 Port: Handset Diagnostic Port (COM87) Build id: MPSS.DI.2.0.1.c7-00020-M8974AAAAANPZM-1 Compile Date: Oct 11 2014 Compile time: 15:04:56 Release date: Apr 24 2014 Release time: 23:00:00 Error read imei... IMEI 1 for repair: 358412659874858 Reading imei. IMEI: 358412659874858 If phone not restart, restart phone manually. Without removing usb. Done. reg |
02-22-2018, 11:33 | #6368 (permalink) |
Member: 1198084 Status: Offline Thanks Meter: 42 | Mobicel Switch white screen fix nck dongle Exe version: NCKDongle AndroidMTK 2.5.8.6 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM8) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (57Gb+4096Mb) KSI 0x454838454134 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 70010045483845 : 000000000000000000 EMMC UA SIZE: 0x1c8000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1c8c00000 [7.137 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. Mobicel Switch white screen fix nck dongle |
02-22-2018, 11:45 | #6369 (permalink) |
No Life Poster Join Date: Jan 2017 Location: Soul Society
Member: 2669319 Status: Offline Thanks Meter: 421 | Selected connection metod: SpMeta Connection Exe version: NCKDongle AndroidMTK 2.5.8.6 Selected phone: MT6571_EMMC Action : IMEI REPAIR. IMEI[1] for write : 352988071194294 IMEI[2] for write : 352988071194292 Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [12]Detected: MediaTek PreLoader USB VCOM (Android) (COM12) \\?\usb#vid_0e8d&pid_2000#6&bea0b3d&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [128]META Port Detected: MediaTek USB VCOM (Android) (COM128) USB\VID_0E8D&PID_2007\6&BEA0B3D&0&2 Start sync target, waiting responce..... ChipID: MT6592,S01 Using Algo 1. Brand: MyPhone Board: ALPS Model: MyPhone MY32L Name: MyPhone MY32L Release: ALPS.L1.MP6.V2.15.2_6592.WET.L Version: 5.1 Platform: MT6592 NVRAM Dumped OK. C:\Users\AppLe\Documents\Android_MTK\nvram_backup\ META_MODE_NVRAM_MT6592_MyPhone MY32L_02_22_2018_16_21_31.zip Reading imei IMEI[1]: fffffffffffffff IMEI[2]: fffffffffffffff Writing imei IMEI[1] TO UPDATE: 352988071194294 IMEI[2] TO UPDATE: 352988071194292 Writing data, wait.... IMEI repair OK. All done. |
02-22-2018, 14:25 | #6370 (permalink) |
Member: 1198084 Status: Offline Thanks Meter: 42 | Mobicel Gem frp done Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM8) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (28Gb+4096Mb) KSI 0x454534454134 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 70010045453445 : 000000000000000000 EMMC UA SIZE: 0xe2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe2480000 [3.536 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. Mobicel Gem frp done by NCK DONGLE |
The Following User Says Thank You to mughal.zahoor For This Useful Post: |
02-23-2018, 10:10 | #6371 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OT-2045X USB Connection selected. EXE VERSION: NCKDongle MTK Tool 1.50 Connect phone in boot mode ... USB\VID_0E8D&PID_0003&REV_0100 Com port ok : COM20 Phone detected...Please wait Conected ok with target ... Reopen comport(COM20) BaseBand CPU : MT6276 SW_VER : 2045X_L2EN_V1.5_160712_CAM30_MCP128_64_FM_BT_AU_OP TUS HW_VER : HW01 Meta mode conected ok, start reading phone.... Phone imei[1] : 351530082738577 User code(64) : 0000 SIMLOCK INFO[1]: Block1[N]: Locked (remain:5) Code : 48705875 Block2[NS]: Unlocked Block3[SP] Unlocked Block4[C]: Unlocked META END OK. All done. |
The Following User Says Thank You to wsmobile For This Useful Post: |
02-24-2018, 05:25 | #6372 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Hangu
Member: 2129557 Status: Offline Thanks Meter: 57 | USB Connection selected. EXE VERSION: NCKBox MTK Tool 4.0 Connect phone in boot mode ... USB\VID_0E8D&PID_0003&REV_0100 Com port ok : COM24 Phone detected...Please wait Conected ok with target ... Starting meta mode..... IMEI[1]: 352441081827768 IMEI[2]: 352441081827768 Clean tmp directory....wait. Start read, wait.... Block1[N]: Locked (remain:0) Code : 12345678 Block2[NS]: Unlocked Block3[SP] Unlocked Block4[C]: Unlocked Unlock file done Unlock file done Processing done. Unlock done. Clean tmp directory....wait. Clean tmp directory....done. META END OK. All done. |
The Following User Says Thank You to luqmanonline For This Useful Post: |
02-24-2018, 11:43 | #6373 (permalink) |
Member: 1198084 Status: Offline Thanks Meter: 42 | Nokia 6 FRP Done with nck donge Operation: Reset FRP Searching for phone..... FlashMode Detected. Hello received. HW ID: 00000000E1F00400 MSM8937 PK HASH: F5F4192A33B2830974B400119BAB728CC9FE911011F928625C 2AED0DA441AC97 Checking database for suitable loader..... Arhitecture:32 bits [32]Sending loader, please wait.. Waiting for loader to start... MaxPayloadSizeFromTargetInBytes: 4096 MaxPayloadSizeToTargetInBytes: 8192 Reading partition info, wait. Volume[0] Size: 29.12 GB Partitions count: 65 Userdata Size: 22.68 GB Erasing FRP, wait..... Erasing FRP, finished Restarting phone..... ************************************* Log saved: C:\Users\Mughal\Documents\NckDongle\qc_module_Logs \reset_frp_MSM8937_00000000E1F00400_F5F4192A33B283 0974B400119BAB728CC9FE911011F928625C2AED0DA441AC97 1.txt Total Time: 00:00:03 Done. Screenshot saved: C:\Users\Mughal\Documents\NckDongle\Screenshots\sc reenshot_1.jpg Nokia 6 FRP Done with nck donge |
02-25-2018, 15:14 | #6374 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | Huawei g610-u20 dead recover done HUAWEI G610-U20 DEAD RECOVER DONE Code: Flash files count is :14 Action : Firmware update. Selected Model: Huawei: Ascend G610-U20 Exe version: NCKDongle AndroidMTK 2.5.8.6 Scenario: [0]Safe Flash Parsing firmware, wait. [22]Rom Count. Connecting phone. Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM348) Phone detected...Please wait Sending DA agent, please wait... BBCHIP MT6589_S00 Using Algo 1. EMMC FW VERSION: 86:00:00:00:00:00:00:00 EMMC CID: 90014A4834473164048601A45385B1ED EMMC UA SIZE: 0xe7000000 BOOT STYLE: EMMC BOOT Dumping preloader. Preloader backup already exist, skip saving. Start Flashing. Send preloader... Download firmware to flash now... MBR checksum is executing ... EBR1 checksum is executing ... UBOOT checksum is executing ... BOOTIMG checksum is executing ... RECOVERY checksum is executing ... SEC_RO checksum is executing ... LOGO checksum is executing ... EBR2 checksum is executing ... ANDROID checksum is executing ... CUST checksum is executing ... CACHE checksum is executing ... USRDATA checksum is executing ... Wait untill phone start charging. All done. |
The Following User Says Thank You to taimur-ahmad For This Useful Post: |
02-26-2018, 11:43 | #6375 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algeria
Member: 574410 Status: Offline Thanks Meter: 93 | lenovo K10A40 FRP done Exe version: NCKBox AndroidMTK 1.8.8.7 Selected model: K10A40 Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM14) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 2. ---------------------------------------------------- BaseBand CPU :MT6735M BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x463732324d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010046373232 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED -Reading GPT Drive OK Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. Thanks nck team |
