Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box Premium v2
Old 02-21-2018, 12:36   #136 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up Huawei Y3 II (LUA-U22) frp unlock by frp code via nck
Huawei Y3 II (LUA-U22) frp unlock by frp code via nck box
Old 04-10-2018, 11:06   #137 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up Huawei Y3 (2017) CRO-U00 frp done
Action : Boot Info.
Will be used loader: CRO-U00.bin
Reinsert phone battery.
Battery must be charged.
Phone must be off with battery inside.
Please insert USB cable now...
Detected : MediaTek PreLoader USB VCOM Port (COM5)
Boot mode: Preloader
Using Algo 1.
Phone detected...Please wait
Sending DA agent, please wait...
BaseBand CPU :MT6580
BaseBand CPU Secure Version : FF
BaseBand CPU Bootloader Version : 01
INT RAM: 128 KB SDRAM
EXT RAM: 1 GB DRAM
EMMC: (58Gb+8192Mb) HYNIX 0x483847346132
EMMC FW VERSION: d4:00:00:00:00:00:00:00
EMMC CID: 90014A483847346132 : 00000000000000
EMMC UA SIZE: 0x1d2000000
BOOT STYLE: EMMC BOOT
FULL LENGTH: 0x1d2c00000 [7.293 GB]
High speed disabled by user, continue with this settings.
-Reading GPT Drive OK
This phone have FRP partition.
Build ID: HUAWEICRO-U00
Version: 6.0
Build Date: Sat May 13 13:48:07 CST 2017
Model: CRO-U00
Brand: HUAWEI
Device: HWCRO-U6580M
Mediatek Version Release: alps-mp-m0.mp1-V2.39_ot6580.weg.y33.m_P103
Display ID: Cairo-U00C185B102
Model: Cairo-U00C00SMT_
FRP CODE
fastboot oem frp-unlock 10A52EA33CE8BFA7
Power phone in fastboot mode, press button Enter FRP Code and use this code: 10A52EA33CE8BFA7
IMEI[1]: 866800000000000
IMEI[2]: 866800000000000
Wait untill phone will start charging.
All done.
The Following User Says Thank You to dereje For This Useful Post:
Old 04-19-2018, 10:23   #138 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up world first TECNO Phantom6-Plus MT6797 64gb frp done without risk
world first TECNO Phantom6-Plus MT6797 64gb frp done only by nck box without risk
Build ID: NMF26O
Display ID: A9-H971A-N1-170802V76
Version: 7.1.1
Build Date: Wed Aug 2 20:46:24 CST 2017
Model: Phantom6-Plus
Brand: TECNO
Device: Phantom6-Plus
Manufacturer: TECNO
Mediatek Version Release: A9-H971A-N1-170802V76
Exe version: NCKBox AndroidMTK 1.8.8.8
Selected model: MT6797
Action: Reset FRP
Detected : PreLoader USB VCOM (Android) (COM6)
Using Algo 3.
Helio MT6797 phone detected, swithing to helio api
BBCHIP MT6797
EMMC FW VERSION: 00:00:00:00:00:00:00:00
EMMC CID: 150100434A4E42 : 000000000000000000
EMMC UA SIZE: 0xe8f800000
FULL LENGTH: 0xe90400000 [58.254 GB]
Status: USB_HIGH_SPEED
Detecting high speed port, wait......
If driver not installed, install high speed port driver.
If not need high speed port, disable it.
After repeat opperation.
Detected : MediaTek DA USB VCOM (Android) (COM410)
Checking data, wait...
Erasing FRP, wait...
FRP Reset Done.
All done.
Old 04-23-2018, 00:39   #139 (permalink)
Member: 2203321
Thanks Meter: 46
Nck box qualcomm module unlocks alcatel ot-5054o
NCK BOX QUALCOMM UNLOCK ALCATEL OT-5054O
STEPS:
1. Download and install Alcatel Qualcomm Drivers from NCK Support Access
2. Open Diagnostic on the phone (###2324#)
NB. Refer to Help for Diagnostic
(How to enable diagnostic port.
a.Disable usb debugging if enabled
b.Type "###2324#" in dial screen.
c.Can be also "*#2618#" in dial screen.
d.Phone must display "Diag Protector OFF".
e.Some phones will open window with diag setting.
f. Check "diag" checkbox in this window .
g.Install phone drivers if need use "AlcatelQualcomDrivers.rar" from support.
h.Extract arhive and use "DriverInstaller.exe" to install or uninstall drivers.
i.Check if diagnostic drivers is installed in device manager.)
3. Connect your phone (preferably with USB EDL Cable)
4. Open NCK Box Qualcomm Module and refresh ports
5. Select Android HS-USB Diagnostics AF32 ...
6. Select from Model; OT-5054O
7. Finally click on unlock and just wait for your success.
Searching for phone.....
Port: Android HS-USB Diagnostics AF32 (COM56)
Rebooting in download mode, wait...
Waiting for download mode...
Port: Android HS-USB QDLoader 9008
Hello received.
HW ID: 19004200E1009600 MSM8909
PK HASH: 598FB494403B71C36D1B0DFD0F9E24500D767980EF04E5F0A3 A94E28DF1FD901
Arhitecture:32 bits
[32]Sending loader, please wait..
Waiting for loader to start...
MaxPayloadSizeFromTargetInBytes: 4096
MaxPayloadSizeToTargetInBytes: 8192
Reading partition info, wait.
Volume[0] Size: 14.56 GB Partitions count: 41
Userdata Size: 11.81 GB
Manufacturer: TCL
Cpu: armeabi-v7a
Build Id: LMY47V
Model: Alcatel_5054O
Android Release: 5.1.1
Android Version: LMY47V release-keys
Security patch: 2016-02-01
IMEI: 01455600119....
Model: 5054O-2KRKUS3-R
Secro: X8G0UC00BR10
Step 1 ok.
Writing simlock ok.
Restarting phone.....
The Following User Says Thank You to Joel_Baah For This Useful Post:
Old 04-23-2018, 10:12   #140 (permalink)
Crazy Poster
Member: 2578455
Sonork: werw4dw
Thanks Meter: 14
Exe Version: NckBox Qualcomm Module 0.12
Operation: Unlock phone.
Port: Android HS-USB Diagnostics AF08 (COM28)
Port: Android HS-USB QDLoader 9008 (COM27)
Hello received.
Arhitecture:32 bits
CPU: MSM8909
Volume[0] Size: 7.3 GB Partitions count: 43
[008152EF]Userdata Size: 4.04 GB
Manufacturer: TCL
Cpu: armeabi-v7a
Build Id: LMY47V
Model: Alcatel_4060A
Security patch: 2016-05-01
IMEI: 014699005020469
Model: 4060A-2AAQUS3-R1
Secro: X1M0UA02CL10
Step 1 ok.
Processing.
Processing.
Writing simlock.
Writing simlock ok.
Restarting phone
The Following User Says Thank You to mwambela2 For This Useful Post:
Old 06-23-2018, 09:49   #141 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up Vivo Y28L dead repair done
Operation: Upgrade
Qualcomm HS-USB QDLoader 9008 (COM462) detected.
Hello received.
HW ID: 00000000E1507000 MSM8916
PK HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998 421ADAD42A380F
Checking database for suitable loader.....
Arhitecture:32 bits
CPU: MSM8916
Volume[0] Size: 7.28 GB Partitions count: 31
[00400000]Userdata Size: 2 GB
[FLASH][SKIP] name: modem
[0]Writing: sbl1 Start: 262144 length: 497
[0]Writing: sbl1bak Start: 263168 length: 497
[0]Writing: aboot Start: 264192 length: 2705
[0]Writing: abootbak Start: 274432 length: 2705
[0]Writing: rpm Start: 284672 length: 292
[0]Writing: rpmbak Start: 285696 length: 292
[0]Writing: tz Start: 286720 length: 805
[0]Writing: tzbak Start: 287744 length: 805
[0]Writing: hyp Start: 288768 length: 40
[0]Writing: hypbak Start: 289792 length: 40
[0]Writing: sec Start: 396352 length: 1
[0]Writing: boot Start: 396384 length: 20308
[0]Writing: system Start: 429152 length: 262136
[0]Writing: system Start: 692264 length: 262136
[0]Writing: system Start: 696216 length: 262136
[0]Writing: system Start: 953440 length: 262136
[0]Writing: system Start: 957392 length: 262136
[0]Writing: system Start: 1215584 length: 262136
[0]Writing: system Start: 1216552 length: 262136
[0]Writing: system Start: 1220504 length: 262136
[0]Writing: system Start: 1477728 length: 260688
[0]Writing: system Start: 1481680 length: 99632
[0]Writing: system Start: 1739872 length: 3952
[0]Writing: system Start: 1740840 length: 3952
[0]Writing: system Start: 1744792 length: 3952
[0]Writing: system Start: 2002016 length: 3952
[0]Writing: system Start: 2005968 length: 3952
[0]Writing: cache Start: 4269560 length: 13040
[0]Writing: cache Start: 4531704 length: 16
[0]Writing: cache Start: 4531904 length: 16
[0]Writing: cache Start: 4793848 length: 16
[0]Writing: recovery Start: 4883960 length: 22356
[0]Writing: userdata Start: 4916728 length: 179216
[0]Writing: userdata Start: 5178872 length: 5144
[0]Writing: userdata Start: 5179904 length: 4112
[0]Writing: userdata Start: 5184016 length: 5144
[0]Writing: userdata Start: 5441016 length: 4112
[0]Writing: userdata Start: 5445128 length: 5144
[0]Writing: userdata Start: 5703160 length: 4112
[0]Writing: userdata Start: 5704192 length: 5144
[0]Writing: userdata Start: 5708304 length: 4112
[0]Writing: userdata Start: 5965304 length: 5144
[0]Writing: userdata Start: 6227448 length: 4112
[0]Writing: userdata Start: 6228480 length: 4112
[0]Writing: userdata Start: 6489592 length: 4112
[0]Writing: userdata Start: 6751736 length: 4112
[0]Writing: userdata Start: 6752768 length: 4112
[0]Writing: userdata Start: 7013880 length: 4112
[0]Writing: udisk Start: 9236480 length: 8192
[FLASH][SKIP] name: PrimaryGPT
[FLASH][SKIP] name: BackupGPT
Applying patch, wait...
Log saved: C:\Users\d-max\Documents\NckBox\qc_module_Logs\flash_phone_MS M8916_00000000E1507000_CC3153A80293939B90D02D3BF8B 23E0292E452FEF662C74998421ADAD42A380F1.txt
Total Time: 00:05:05
Done.
Old 08-31-2018, 08:23   #142 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up world first Huawei Y3 (2017) CRO-L22 read frp code via meta works perfect
Start Erase FRP using password: 94cb6d7d0e3fae61
(bootloader) frp unlocked successfully!
OKAY [ 0.020s]
finished. total time: 0.020s
Old 09-08-2018, 10:07   #143 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up Techno cx spd frp done
TECHNO CX SPD FRP DONE
Old 01-06-2019, 17:22   #144 (permalink)
gsmgold_10's Avatar
Member: 1085634
Sonork: 1001650032
Thanks Meter: 46
[BExe Version: NckBox Qualcomm Module 0.12.5
Operation: Reset FRP
Qualcomm HS-USB QDLoader 9008 (COM57) detected.
Hello received.
HW ID: 00000400E1507000 MSM8916
PK HASH: FB428087DF560B472C936135FCE9B13CA8447B1A98868AA257 060ECF08A6D9FE
Arhitecture:32 bits
[1] Send NOP ok, loader start.
CPU: MSM8916
Volume[0] Size: 7.22 GB Partitions count: 28
[00888000]Userdata Size: 4.27 GB
Erasing FRP, wait.....
Erasing FRP, finished
Log saved: C:\Users\khorshed\Documents\NckBox\qualcomm_module \qc_module_Logs\reset_frp_MSM8916_00000400E1507000 _FB428087DF560B472C936135FCE9B13CA8447B1A98868AA25 7060ECF08A6D9FE2.txt
Total Time: 00:00:12
Done.
][/B] ZTE Z812 frp is done EDL mode
thanks nck team
Old 03-08-2019, 09:51   #145 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up Lenevo K53a8 frp done by nck qc tool
Exe Version: NckBox Qualcomm Module 0.12.4
Qualcomm HS-USB QDLoader 9008 (COM165) detected.
Hello received.
HW ID: 2A7A0000E1F00400 MSM8937
PK HASH: 99C8C13E374C34D8F9AFB065EA4C733E6B1B21CBC5A78705F0 41EB24ACDD5FE5
Arhitecture:32 bits
CPU: MSM8937
Volume[0] Size: 29.12 GB Partitions count: 54
[030FDFDF]Userdata Size: 24.5 GB
Log saved: C:\Users\d-max\Documents\NckBox\qualcomm_module\qc_module_Log s\reset_frp_MSM8937_2A7A0000E1F00400_99C8C13E374C3 4D8F9AFB065EA4C733E6B1B21CBC5A78705F041EB24ACDD5FE 51.txt
Total Time: 00:00:01
Done.
The Following 2 Users Say Thank You to dereje For This Useful Post:
Old 03-19-2019, 11:13   #146 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up nokia TA-1053 frp remove by nck qc tool
Qualcomm HS-USB QDLoader 9008 (COM215) detected.
Hello received.
HW ID: 00000000E1F00400 MSM8937
PK HASH: F5F4192A33B2830974B400119BAB728CC9FE911011F928625C 2AED0DA441AC97
Arhitecture:32 bits
CPU: MSM8937
Volume[0] Size: 14.56 GB Partitions count: 65
[011DEFDF]Userdata Size: 8.94 GB
Log saved: C:\Users\d-max\Documents\NckBox\qualcomm_module\qc_module_Log s\reset_frp_MSM8937_00000000E1F00400_F5F4192A33B28 30974B400119BAB728CC9FE911011F928625C2AED0DA441AC9 71.txt
Done.
Old 03-24-2019, 07:03   #147 (permalink)
aslam hossain's Avatar
Member: 2179298
Sonork: 100.1660353.Aslam
Thanks Meter: 215
Alcatel OT-5099Y Successfully Unlock
Exe version: NCKBox AndroidMTK 1.8.9.9
 Selected model: Alcatel  OT-5099Y
 Action: Unlock
 Scanning for presents meta ports...
 In some phones need to keep VOL- button untill inserting USB cable.
 [22]Detected: MediaTek USB Port (COM22)
 \\?\usb#vid_0e8d&pid_0003#5&339e9ce1&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
 Starting META mode, wait...
 Restarting to meta,wait....
 If drivers missing, please install CDC drivers.
 This can take up to 5 min on slow phones.
 If take too long, check device manager for drivers.
 [100]META Port Detected: MediaTek USB VCOM (Android) (COM100)
 USB\VID_0E8D&PID_2007\5&21E739F&0&2
 Start sync target, waiting responce.....
 [AP]BaseBand CPU : mt6737t,S01
 [AP]APP_VER: alps-mp-o0.mp1
 Making target channel configuration, wait...
 Making tunnel configuration, wait...
 Rebooting to meta, wait....
 [META]BaseBand CPU : MT6735, E00
 [META]SW_VER : MOLY.LR9.W1444.MD.LWTG.MP.V199.3
 [META]HW_VER : TCL_TB8735AP1_HW
 Phone imei[1] : 353937090598331
 Start direct unlock[SIM1]
 Direct unlock done
 Clean Boot flag ok.
 [0]All done.
Thanks Nck Team
The Following 2 Users Say Thank You to aslam hossain For This Useful Post:
Page generated in 0.35303 seconds with 9 queries
