GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
12-11-2002, 11:28 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | Access ComPorts directly !! Found this inetresting snippet of info, cause I had problems with a small project of mine with a PIC and I found this, it allows you to access comports directly !! Don't know if this will work on WinXP ?? Somebody can maybe try it out and report Regards --------------------------------------------------- Hi all, Been beating my brain for a couple of days on this. Writing some 'c' code to program a pic microcontroller. Windows was blocking my output on com2. Here's how I fixed it, nowhere on the internet have I found this solution. 1. rename the msports.inf in \windows\inf\msports.inf to msportssave.inf 2. rename the serial.vxd in \windows\system\serial.vxd to serialsave.vxd 3. Go into control panel and delete the serial under port system/device manager/ports 4. Reboot, windows will find the ports but won't be able to find a driver, just continue and the ports will be added to other devices in system/device manager. 5. You can now access the serial ports directly 6 I restored com1 to windows status by renaming the msports.inf file and serial.vxd to original names. Deleted com1 and rebooted, windows finds com1 and loads the windows drivers and I can still use com2 for my program. YEEEHAWWWW Hope this helps others James Luttrell JTL-Consulting [email protected]***.org ---------------------------------------------------------------- |
12-14-2002, 16:49 | #2 (permalink) |
Freak Poster Join Date: Mar 2002 Location: LONDON UK Age: 41
Member: 9857 Status: Offline Thanks Meter: 0 | Hello M8's @GSM Coolhawk Good solution m8, laptop users can do the same method by just disableing all infa red ports/devices thus rebooting and skipping the point driver location. then all ports are accesable and can be mapped to user spec. <Take A Look @ My New Project Tell Me What You Think> http://forum.gsmhosting.com/vbb/show...threadid=66089 Best Regards Adam Rest Vast Gsm Team [email protected] |
12-31-2002, 05:08 | #3 (permalink) |
Junior Member Join Date: Nov 2001 Age: 45
Member: 7237 Status: Offline Thanks Meter: 1 | anyone tried this program to get direct serial port access in win xp? http://www.direct-io.com/Direct-IO/directio.exe |
SFR & Orange Access to Direct unlock server Available | SMS MANIA | Phone Unlocking Codes & Maps | 1 | 01-22-2010 15:33 |
Ufs directcom,dku5 comport,t28 comport cable with chines work? | vipinverma | Various | 0 | 10-23-2007 14:29 |
UFS-3 comport direct help | Temani | UFS2 + UFS3-Tornadoflasher | 1 | 06-19-2007 21:24 |
"unable to access direct port I/O driver to run under Win NT/2000/XP" | SicilianBoy | SagMaster Team OLD Products | 6 | 11-15-2006 17:36 |
Dct-4 calc real-time direct access server wanted | PremierGSM | Wanted Products | 4 | 05-07-2003 11:56 |
