Anyone Can Solve Blackberry Bold 9000 Reconnecting To JVM Problem? Many people encountered this problem but so far almost all of them are unsolved so I posted here and see if there is any guys here who can help us in it. After the Reconnecting to JVM. Unable to reconnect to the device during multi-stage load operation appear. Then followed by a non valid battery icon. I sense that the phone simply cant boot up during the installation. Hope that someone can help us out in this. Regards GFI |
I already posted some part in forum ...or perhaps not in this forum ? don't remember :) I haved the same problem in 2 phones(9000 and 9530) and sorted out. I don't know exactly what happen but worked the 2 times ! Whats in the screen of the phone ? or phone is just red blink? |
when the program tell you Reconnecting to JVM press this in phone S T A R T br ahmed |
Regards GFI |
Regards GFI |
@GFI for bold you need to erase/flash with original battery inserted or put to phone in the last stage and type start (and no forget after erase to pres ctrl+alt+shift+f12 ;) ) also check is vendor.xml is deleted or try with command prompt CD \ CD PROGRA~1 CD COMMON~1 CD RESEAR~1 CD APPLOA~1 LOADER /NOJVM regards |
This doesnt work. CD \ CD PROGRA~1 CD COMMON~1 CD RESEAR~1 CD APPLOA~1 LOADER /NOJVM Now the main problem is why the invalid battery icon will appear as it stop the phone from been booted during the reconnecting to jvm. Regards GFI |
The sollution of your prblm is when the software loader try to reconnect to device you'll see battery not installed on the device screen so put the battery back in the phone and the software loader will reconnect again and terminate the installation. Good luck. |
i did everything but did not work |
Not working too Regards GFI |
any one have sove his problem i have a blackberry 9000 with this problem after killed when trying to unlock |
I think its hardware problem. The batt indicator show cannot change device into flashing operation. Maybe u got to change power management ic on it. In curve series sometimed it happen. So I change the power management ic or I change flash ic and the problem solved. This is just my opinion bro, regards |
and what if we see device error 404 on the screen instead of battry icon????? |
