GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
04-14-2009, 20:36 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Inside Blackberry
Member: 288462 Status: Offline Thanks Meter: 87 | Anyone Can Solve Blackberry Bold 9000 Reconnecting To JVM Problem? After the Reconnecting to JVM. Unable to reconnect to the device during multi-stage load operation appear. Then followed by a non valid battery icon. I sense that the phone simply cant boot up during the installation. Hope that someone can help us out in this. Regards GFI |
04-14-2009, 20:55 | #2 (permalink) |
No Life Poster Join Date: Mar 2007 Location: /Fr/Ch\Ro\ Age: 39
Member: 467911 Status: Offline Thanks Meter: 351 | I already posted some part in forum ...or perhaps not in this forum ? don't remember I haved the same problem in 2 phones(9000 and 9530) and sorted out. I don't know exactly what happen but worked the 2 times ! Whats in the screen of the phone ? or phone is just red blink? |
04-14-2009, 21:17 | #3 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Egypt-Alex Age: 42
Member: 56038 Status: Offline Thanks Meter: 171 | when the program tell you Reconnecting to JVM press this in phone S T A R T br ahmed |
The Following User Says Thank You to DeDo Gsm1911 For This Useful Post: |
04-15-2009, 05:21 | #4 (permalink) | |
Member: 288462 Status: Offline Thanks Meter: 87 | Quote:
Regards GFI | |
04-15-2009, 05:22 | #5 (permalink) | |
Regards GFI | |
04-15-2009, 06:49 | #6 (permalink) |
No Life Poster Join Date: Mar 2003 Location: One step before you ;) Age: 42
Member: 23695 Status: Offline Sonork: 100.64383 Thanks Meter: 12 | @GFI for bold you need to erase/flash with original battery inserted or put to phone in the last stage and type start (and no forget after erase to pres ctrl+alt+shift+f12 ) also check is vendor.xml is deleted or try with command prompt CD \ CD PROGRA~1 CD COMMON~1 CD RESEAR~1 CD APPLOA~1 LOADER /NOJVM regards |
04-15-2009, 08:14 | #7 (permalink) | |
This doesnt work. CD \ CD PROGRA~1 CD COMMON~1 CD RESEAR~1 CD APPLOA~1 LOADER /NOJVM Now the main problem is why the invalid battery icon will appear as it stop the phone from been booted during the reconnecting to jvm. Regards GFI | |
07-05-2009, 21:59 | #8 (permalink) |
Freak Poster Join Date: Dec 2003 Location: ALGERIA Age: 45
Member: 46191 Status: Offline Thanks Meter: 30 | The sollution of your prblm is when the software loader try to reconnect to device you'll see battery not installed on the device screen so put the battery back in the phone and the software loader will reconnect again and terminate the installation. Good luck. |
07-06-2009, 00:12 | #9 (permalink) | |
No Life Poster Join Date: May 2005 Location: bridgetown Age: 59
Member: 146939 Status: Offline Sonork: 100.1609615 Thanks Meter: 245 | Quote:
i did everything but did not work | |
07-06-2009, 22:18 | #12 (permalink) |
No Life Poster Join Date: Jun 2005 Location: insane in da mad brain Age: 46
Member: 154522 Status: Offline Thanks Meter: 48 | I think its hardware problem. The batt indicator show cannot change device into flashing operation. Maybe u got to change power management ic on it. In curve series sometimed it happen. So I change the power management ic or I change flash ic and the problem solved. This is just my opinion bro, regards |
Anyone know the meaning of Reconnecting to JVM? | GFI | BlackBerry (RIM) | 67 | 01-20-2011 11:30 |
Blackberry Bold 9000 Dead [SOLVED] | indoponzel | FuriousGold | 8 | 01-13-2010 13:05 |
Blackberry Bold 9000 Rebuild IMEI Problem. | baljitsb | FuriousGold | 7 | 07-10-2009 17:36 |
how to unlock blackberry bold 9000 | turkcellgsm | BlackBerry (RIM) | 0 | 03-13-2009 10:24 |
Blackberry Bold 9000 ROGERS unlock problem IMEI METHOD | speednfuel | BlackBerry (RIM) | 2 | 11-27-2008 09:54 |
