^CARDLOCK=3,0,0 imei : 863791011367943..give hash keys...it is an new algo modem airtel e173cs-1 what should i have to do now..how to solve this problem...pls help//hanging out for a long time... also help me to calculate the new algo codes..that will be greateful for hekping others.. thx in advance...pls help me.... |
A query is no command AT ^ ..... code for unlocking modems ... There any zte MF190 imei calculator or to remove the hash and all those who are above camandos work with zte modems??? example: IMEI: 867575000137409 as would be the command???? warrantless this or expect any help please ... for this command is as used??? 2) -> AT CARDLOCK ^ = "11111111" where the code is 11111111 |
is there any command AT ^ to calculate IMEI code There any zte MF190 imei calculator or to remove the hash and all those who are above camandos work with zte modems??? example: IMEI: 867575000137409 as would be the command???? warrantless this or expect any help please ... for this command is as used??? 2) -> AT CARDLOCK ^ = "11111111" where the code is 11111111 |
I have calculated MD5 hash from new algo unlock code, but it is not working. It seems that some salt is required for IMEI to calculate correct MD5 hash, but "5e8dd316726b0335" is no longer working. What is the salt for new algo modems? :confused: |
anyone the new algo in php? |
