GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
01-15-2016, 09:23 | #1 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2516053 Status: Offline Thanks Meter: 0 | Hexagon QDSPV5A Reverse Engineering I'm looking to change the way Qualcomm handles read only parts of NV. I've successfully loaded the modemdotelf file into IDA however when I go to my string of interest IDA gets confused and it just shows up incorrectly. If anyone has any input that would be awesome. |
01-15-2016, 18:35 | #2 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Here and there Age: 40
Member: 52560 Status: Offline Thanks Meter: 226 | Things to check: -Did you select the correct core? -Did you correctly identify and define all subs? -Are you familiar with xrefs? -Did you use IDA before? If the answer to any of these is NO, then thats what you need to do. Also, to check strings, you can just use bash and type "strings filename". No need for expensive IDA for that. BR |
