GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2010 Location: Unknown
Member: 1274304 Status: Offline Sonork: 100.1617965 Thanks Meter: 195 | Huawei Modem Virtual Cd Disable Solution How to disable virtual cd in huawei modem Pls it urgent |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2007 Location: CLOUD Age: 40
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | Huawei AT-commands ![]() note: Some devices like the Huawei K3715 seem to require AT-commands to be typed in capital letters! There are a couple of options for disabling and re-enabling the following USB-components of Huawei USB-modems:
AT^U2DIAG=n On some models it is possible to read the present value of the parameter n by sending command: AT^U2DIAG? nMCDSDUINSCremarkssupported bynot supported by0+ + E1750 1++ 3+ + +won't work on devices without SC* 5 + ++ won't work on devices without N* 9 + ++won't work on devices without N & SC* 10++ +won't work on devices without SC* 12 + ++ won't work on devices without N* 255++++??reset to factory defaultsK3715, E160E, K3565E176, E1762, E1750, E173256+ ++ for most devices: everything enabled except the flashmemory; microSD-drive will be available under Windows even without drivers installedK3715, E160E, E1762, K3565, K3765, E1750, E173E176257+++ 259+ ++ +won't work on devices without SC*E176 261 ++ ++won't work on devices without N & SC* 265 ++ ++won't work on devices without N & SC* 266+++ +won't work on devices without SC* 267 ++ + won't work on devices without N* 268++++ won't work on devices without N*E1750, K3565, E173 276+++++?reset to factory defaultsE1762, K3565, K3765, E173, E1750 *) note: smartcard (SC) and network adaptor (N) are not present in most Huawei devices. Using an AT-command, that activates SC or N on a device, which hasn't these components will result in errors and so will be noneffective. Modems supporting AT^U2DIAG? command: E173, E1750 Modems not supporting AT^U2DIAG? command: K3565 Also on some models it is possible to display a list of devices present in a USB-stick, by sending a command |
![]() | #4 (permalink) | |
Junior Member Join Date: Oct 2011
Member: 1673080 Status: Offline Thanks Meter: 1 | Quote:
To disable or re-enable those components run the following AT-command, where n is one of the numbers from the table below: * modem (M) * NAND-flashmemory drive (CD) * microSD-drive (SD) * PC UI interface (UI) * Network adaptor (N) * smartcard (SC) To disable or re-enable those components run the following AT-command, where n is one of the numbers from the table below: AT^U2DIAG=n Sometimes AT-commands will result in an "ERROR" - in this case keep re-entering the AT-command until "OK" is being returned. -------------------------------------------------------------------------------------------------------------- n, | M | CD | SD | UI | N | SC |remarks,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, |supported by ,,,,, | not supported by 0 ,| x | .. |... |... | . |... |....... 1, | x | x, |,,, | ,, |,, |,,, |,,,,, 3, | x |,,, |,,, |, x | , |, x | won't work on devices without SC*,,,, 5, | , | ,, | x ,| x ,| , | ,,,| won't work on devices without N*, ,,, 9, | , | x, | ,,,|,,, | x | x, | won't work on devices without N & SC* 10 | x | x, | ,, | ,, | , | x ,| won't work on devices without SC* ,,, 12 | , | x ,| ,, | x, | x | ,, | won't work on devices without N* 255| x | x, | x, | x, | ? | ? ,| reset factory defaults not recommended|K3715, E160E, K3565|E176, E1762 ---------------------------------------------------------------------------------------------------------------------------------------------------------- 256| x | ,, | x, | x ,| , |,,, | ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,|K3715, E160E, K1762|E176 ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,|K3565 256 = for most devices: everything enabled except for ,,,,,,flashmemory, microSD-drive will be available under ,,,,,,Windows even without drivers installed ----------------------------------------------------------------------------------------------------------------------------------------------------------- ,,n | M | CD | SD | UI | N | SC |remarks,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, |supported by ,,,,, | not supported by 257 | x | x, | x, |,,, |,, |,,, | 259 | x | ,, | x, |, x | , | x ,| won't work on devices without SC*,,,, |E176 261 | , | x, | x, |,,,,| x | x, | won't work on devices without N & SC* 265 |,, | x, | x ,|, , | x | x, | won't work on devices without N & SC* 266 | x | x, | x, |,,, | , | x, | won't work on devices without SC* 267 |,, | x, | x, |,,, | x | x, | won't work on devices without N* 268 |,, | x, | x, | x, | x |,,, | won't work on devices without N* 276 | x | x, | x, | x, | x | ?, | reset to factory defaults ,,,,,,,,,,, |E1762, K3565 -------------------------------------------------------------------------------------------------------------------------------------------------------------- *) note: smartcard (SC) and network adaptor (N) are not present in most Huawei devices. Using an AT-command, that activates SC or N on a device, which hasn't these components will result in errors and so will be noneffective. alexfish | |
The Following User Says Thank You to diepa9k39 For This Useful Post: |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
Pic Solution | jan | Nokia Hardware & Hardware Repair | 8 | 10-11-2010 10:56 |
5110 version 5.24 solution | lampin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-14-1999 07:00 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
