GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
03-04-2003, 13:40 | #2 (permalink) |
Insane Poster Join Date: Feb 2003 Location: Poland Age: 50
Member: 22528 Status: Offline Thanks Meter: 0 | Check this: http://www.arm.com There it should be all this what do you looking for (I hope). Best regards |
03-07-2003, 20:39 | #5 (permalink) |
Freak Poster Join Date: Jun 2002 Location: Scara Brae
Member: 12623 Status: Offline Thanks Meter: 5 | @OrbiTel: There is a pdf named "ARM instruction set quick referense card" somewhere in docs section of www.arm.com. Big endian commands are the same as little endian - only physical encoding is reversed |
03-08-2003, 20:06 | #6 (permalink) | |
No Life Poster Join Date: Jan 2001 Location: CZ Age: 44
Member: 3041 Status: Offline Thanks Meter: 0 | Quote:
03-13-2003, 10:37 | #7 (permalink) |
Junior Member Join Date: Dec 2002 Location: Russia Age: 47
Member: 18345 Status: Offline Thanks Meter: 0 | big endian and little endian is byte order... in big endian - higher byte value stored first, for example "(int)1" sored in memory with little endian format as 0x01 0x00 0x00 0x00, and int big endian format it's looks like 0x00 0x00 0x00 0x01. it is not a command format it's just byte order in memory |
Need a big big big help... | Defcon01 | Chinese Models & Cloned Phones | 6 | 07-04-2009 16:03 |
J210i russian langpack needed.arm | ccont | Sony Ericsson | 0 | 09-16-2007 17:26 |
need arm for t630 | swand | Sony Ericsson | 1 | 11-11-2004 19:33 |
i need .arm file for SE T610 | Juan Tamad | Sony Ericsson | 2 | 09-11-2003 14:48 |
I NEED EMMIBOX & BIC 43e08 DOCUMENTATION | ANDROID | Motorola Old Legacy (EMMI) | 21 | 09-08-2002 07:09 |
