GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
07-22-2013, 10:29 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | Nokia SL3 Cod 2 NCK Source.. (the last secret for bforcer..) iam not a php expert... but works! PHP Code: call this script like: PHP Code: test: http://ooxtcoo.dyndns.org/sl3code.ph...04030708040805 wbr. hari |
The Following 22 Users Say Thank You to oOXTCOo For This Useful Post: |
07-22-2013, 12:08 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Rome , Italy
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | here on asp.net Code: Imports System.Security.Cryptography Public Class _Default Inherits System.Web.UI.Page Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load End Sub Public Function Hex2Str(ByVal Hex As String) Dim hb((Hex.Length / 2) - 1) As Byte Dim i As Integer = 0 For n = 0 To Hex.Length - 2 Step 2 hb(i) = Val("&H" & Hex.Substring(n, 2)) i += 1 Next Return System.Text.ASCIIEncoding.ASCII.GetString(hb) End Function Public Function Str2Hex(ByVal str As String) Return System.BitConverter.ToString(System.Text.ASCIIEncoding.ASCII.GetBytes(str)).Replace("-", "") End Function Public Function SL3_NCK(ByVal Hash As String, ByVal MasterCode As String) MasterCode = "000000" & MasterCode.Substring(0, 24) Dim levelhash As String = "" For y = 1 To 7 levelhash = "0" & y & Hash levelhash = My_Sha1(levelhash) Dim levelhash_16 As String = levelhash.Substring(0, 32).ToUpper Dim precode_8 As String = MasterCode.Substring(0, 16) Dim precode_7 As String = MasterCode.Substring(16, 14) For magic = 0 To 1 Dim sh As String = My_Sha1("0" & magic & levelhash_16 & precode_8).ToUpper Dim precode As String = SimFeistel(sh, precode_7, 7) precode_7 = precode sh = My_Sha1("0" & magic & levelhash_16 & precode).ToUpper precode = SimFeistel(sh, precode_8, 8) precode_8 = precode Next Dim data As String = "" Dim final As String = precode_8 & precode_7 Dim codice As String = "" For n = 0 To final.Length - 1 If n Mod 2 = 1 Then codice &= final.Substring(n, 1) Next Label1.Text &= "LEVEL" & y & "= #pw+" & codice & "+" & y & "#" & "<br>" Next End Function Public Function SimFeistel(ByVal sh As String, ByVal precode As String, ByVal volte As Integer) Dim result As String = "" For i = 0 To volte - 1 result &= "0" & (Val("&H" & sh.Substring(i * 2, 2)) + Val("&H" & precode.Substring(i * 2, 2))) Mod 10 Next Return result End Function Function My_Sha1(ByVal strToHash As String) As String Dim bytesToHash((strToHash.Length / 2) - 1) As Byte Dim i As Integer = 0 For n = 0 To strToHash.Length - 2 Step 2 bytesToHash(i) = Val("&H" & strToHash.Substring(n, 2)) i += 1 Next Dim sha1Obj As New SHA1CryptoServiceProvider bytesToHash = sha1Obj.ComputeHash(bytesToHash) Dim strResult As String = "" For Each b As Byte In bytesToHash strResult += b.ToString("x2") Next Return strResult End Function Protected Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click Label1.Text = "" If TextBox1.Text <> "" And TextBox2.Text <> "" Then If TextBox1.Text.Length <> &H14 * 2 Then Label1.Text = "BAD HASH FORMAT!" Exit Sub End If If TextBox2.Text.Length <> &HF * 2 Then Label1.Text = "BAD MASTER CODE FORMAT!" Exit Sub End If SL3_NCK(TextBox1.Text, TextBox2.Text) End If End Sub End Class |
The Following 10 Users Say Thank You to fr3nsis For This Useful Post: |
07-23-2013, 19:51 | #5 (permalink) |
No Life Poster Join Date: Aug 2009 Location: Future Age: 30
Member: 1093004 Status: Offline Thanks Meter: 4,382 | All Same just added option Auto Calculate (load cod/txt file) it will generate nck + add nck in cod/txt file (Thx sam for idiea) |
The Following 4 Users Say Thank You to dawood1208 For This Useful Post: |
07-24-2013, 15:43 | #11 (permalink) |
No Life Poster Join Date: Feb 2008 Location: ATI atheeq technical(srilanka)
Member: 709520 Status: Offline Thanks Meter: 275 | 431139832242522431139832242522 nokia 1616 movistar . only get master code from server. any one can convert this to unlock code>??? thanks |
07-24-2013, 16:04 | #12 (permalink) |
Member: 2878 Status: Offline Thanks Meter: 9,123 | you need also your hash... its in your hash file what you uploaded.. then you use this adress: http://ooxtcoo.dyndns.org/sl3code.ph...31139832242522 in hash you enter your hash and in master sp you enter your master sp ( i have done this already for you). so only change the hash (0000000000000000000000000000000000000000) with yours... |
07-24-2013, 16:12 | #13 (permalink) | |
Cheater -Don't Deal with him- Join Date: Dec 2012 Location: bangladesh
Member: 1850093 Status: Offline Sonork: 100.1627469 Thanks Meter: 339 | Quote:
#pw+275503618616486+1# #pw+705362924524085+2# #pw+683401949605753+3# #pw+845513458526921+4# #pw+751617387407037+5# #pw+562441500417174+6# #pw+671220790582951+7# | |
07-24-2013, 17:16 | #15 (permalink) |
Member: 709520 Status: Offline Thanks Meter: 275 | i not used brute force service to to get unlock code for this nokia 1616 . because it its cheap price (movistar spain) than brute force method .but my bad luck server just give master code . any way to calculate nck code without hash file?? thanks all for try to help me |
