Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 12-26-2013, 20:05   #1 (permalink)
blagus's Avatar
Member: 1178861
Sonork: 100.1590268
Thanks Meter: 60
Nokia SL3 with CPLD idea
I have 2 spare CPLDs, originally used for XBox 360 RGH modification.
Both are CoolRunner-II, one XC2C64 (Mtx Infinity 2), and other one XC2C128 (TX DGX v1.1). They have JTAG port and can be reprogrammed without problems.
I saw some ideas about using FPGA or ASIC for SHA1 BF, which reminded me of these two I got. Technically, it is possible to program it to calculate SHA1 hash, but how fast it would be? Did anyone try, to share thoughts and experience?
BR,
Blagus
Old 12-26-2013, 21:30   #2 (permalink)
blagus's Avatar
Member: 1178861
Sonork: 100.1590268
Thanks Meter: 60
I've just made some quick calculations, based on ighashgpu table, bitcoin FPGA experience and simple maths.
Nokia SL3 has a total of 10^15 combinations.
1) When compared to some of the fastest bitcoin FPGA setups, which perform more complex maths - double SHA-256 compared to our SHA1:
Let's say that FPGA has the speed of 60G/sec, at double SHA-256 hash bruteforcing.
60G = 60*10^9/sec
The time required to cycle out every possible SL3 combination:
10^15 / (60*10^9) = 16666,67 sec = 277,77 min = 4,629 h = 4h 37min
I won't get into how faster it would be with SHA1, these numbers are for double SHA-256.
2) Now, let's take a decent, low end PC (for a bruteforcer), for example, overclocked 4870, which would give ~1G/sec:
1000M = 1G = 10^9/sec
Time = 10^15 / 10^9 = 10^6 sec = 16666,67 min = 277,77 h = 11,57 days
3) Goal would be to get close to BF-freaks on this forum who get 10G+/sec with 3x or 4xHD7970.
10 000M = 10G = 10*10^9/sec
Time = 10^15 / (10*10^9) = 100k sec = 1666,67 min = 27,7 h = 1,16 days
Even better - double speed, half time:
20G= 20*10^9/sec
Time= 10^15 / (20*10^9) = 50k sec = 833,33 min = 13,89h = 13h 53min.
Keep in mind the extra low power consumption of CPLD - a couple of watts compared to several hundred watts of a regular PC.
Old 12-26-2013, 21:59   #3 (permalink)
Member: 1214273
Thanks Meter: 136
SL3 isn't SHA-1 mate
Old 12-26-2013, 22:42   #4 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
If you not know what you write then better no answer other users this forum.
SL3 is SHA-1 algorytm 100% sure.
Old 12-26-2013, 23:24   #5 (permalink)
blagus's Avatar
Member: 1178861
Sonork: 100.1590268
Thanks Meter: 60
So, we all have been fooled by the description of SL3 hash being SHA1($pass.$salt). All of the codes calculated and entered to phone are actually fake. This all is just a glitch in the Matrix!
Back to the topic, I think I'll just write some code that will SHA1 all 10^15 combinations and blink the LED on each 10G combos processed just for the performance test.
I took a look at the SL3 FPGA code, it isn't complex at all - store the hash and salt into a few registers, then go through all combos, append salt and compare to the original hash. If it matches, send it to PC via JTAG.
Old 12-28-2013, 06:45   #6 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,119
@blagus
I did this some years ago using virtex 4 and realized that it is still cheaper to just use video cards gpu. Also making PCB for BGA with 400+ pins is a nightmare.
You cannot even fit 1 sha-1 core in your coolrunner cplds, they are too "small" and does not have enough macrocells.
The only way to beat the GPUs is to make custom SL3 asic.
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 12-28-2013, 19:06   #7 (permalink)
blagus's Avatar
Member: 1178861
Sonork: 100.1590268
Thanks Meter: 60
Originally Posted by Advance-Box View Post
@blagus
Thanks a lot for the info.
The PCB itself isn't a problem, XBox360 RGH solution is on a small board, QFP package, with JTAG pin-header.
But, you say that it's too small for SHA1 code, so I'll forget about CPLD.
Can you give me some details about how much macrocells/memory should a CPLD/FPGA have for SL3 calculation? I've actually just started learning about these devices, and SHA1 calculation isn't really a complex task, so I'd like to get something capable of doing it.
I have just two SL3 phones that are just fine now, sim-locked, but if I could unlock them and learn something along, it would be nice.
Of course, I wouldn't ruin (your) SL3 market, something with 2-3G/s (FPGA speed I found on this forum) can't catch up with 4x7970 *******s calculating >14G/s.
Old 12-28-2013, 23:15   #8 (permalink)
..::SuB::..'s Avatar
Member: 833760
Sonork: 100.1597150
Thanks Meter: 114
Application specific chip is the best option for you only need a lot of money and some people with extraordinary knowledge based on mathematics and crypto. Try to google for litecoin or bitcoin asics/fpga research topics. We can't compare LTC scrypt or sha256 with our SHA1 problem but you can clearly see how hard to develop an application specific device.
Old 12-29-2013, 11:56   #9 (permalink)
jodge's Avatar
Member: 61389
Thanks Meter: 193
maybe try with this board, i think it is easier when you only have to focus to the algo not both of them.
https://en.bitcoin.it/wiki/ZTEX_FPGA...Bitcoin_Mining
ohh and almost forgot the ******* is this board not the 4x7970
https://en.bitcoin.it/wiki/Xtreme_Miners_Lion
The Following User Says Thank You to jodge For This Useful Post:
Old 12-29-2013, 11:58   #10 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
BR,
Blagus
Hi,
USB-FPGA Module 1.15x: Spartan 6 LX150 FPGA Board with USB 2.0 Microcontroller
https://github.com/fpgaminer/sha1_collider
Hope this helps.
The Following 2 Users Say Thank You to Bph&co For This Useful Post:
Old 12-30-2013, 17:04   #11 (permalink)
jodge's Avatar
Member: 61389
Thanks Meter: 193
i know the coin mining is more profitable than sl3 but what about the 20digit calculation time with FPGA(1-2TH/s)?
Old 12-30-2013, 20:10   #12 (permalink)
blagus's Avatar
Member: 1178861
Sonork: 100.1590268
Thanks Meter: 60
Thanks for all the input guys.
I took a look at Spartan 6 SHA1 code, and it doesn't fit my pocket - but I won't quit, if I manage to do something on some cheap FPGA board I'll let you know
Simple math: 10^20 / 10^12 = 10^8 seconds = 1,6M minutes = 27,7k hours = 1157 days = too much time.
10TH would be a bit better as it gives you 115,7 days but it's still too much.
To make it reasonable you'd need something capable of 100TH/s to get 11,57 days, and the only thing that could do it would be some very optimized ASIC design.
The Following User Says Thank You to blagus For This Useful Post:
Old 12-30-2013, 20:26   #13 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,797
I think 10 x ZTEX 1.15y boards would be just fine for SL3
... if somebody manage to write some code for it + some Raspberry PI or something, as controller for them ...
And about those "TeraHash" values ... don't dream too much.
In fact, sl3 is not much different than sha-256/double round,
but would require customized ASIC, none of existing cant be used.
b.r.
Alex
Old 01-03-2014, 10:33   #14 (permalink)
Member: 174161
Thanks Meter: 2
I am already managing 22400Mh/s on 10x 1.15y. So nothing special if you look for the price of those boards.
Old 01-03-2014, 18:55   #15 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,797
are you talking about SL3 on ZTEX boards ?
Page generated in 0.30170 seconds with 8 queries
