GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
12-28-2009, 12:31 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: pccomp Age: 42
Member: 59173 Status: Offline Sonork: 100.1585568 Thanks Meter: 225 | rap3gv3_2nd.fg RAP3Gv3_algo.fg - possible edit this loaders ? is it possible edit this loaders ? and can someone explain process of booting bb5 phones ? |
02-05-2010, 16:14 | #4 (permalink) | |
Freak Poster Join Date: Jul 2009
Member: 1082040 Status: Offline Sonork: 100.1583839 Thanks Meter: 47 | Quote:
procedure TForm1.Button1Click(Sender: TObject); var n, i: integer; buf: string; DateTime: TDateTime; strTime: string; begin DateTime := Time; strTime := Timetostr(DateTime); Button1.Enabled := False; Memo1.Lines.Add(strTime + ' | ' + 'Init usb communication...'); if BB5_USB_ScanAndOpenConnection('BB5', '*VID_0421*IF_OTH*', false) then begin Memo1.Lines.Add(strTime + ' | ' + '++++++++++ Found! ++++++++++'); // Current Phone Mode - start SendToUSB(#$1B#$00#$10#$15#$00#$06#$00#$06#$00#$02 #$00#$00); n := ReadUBUSData; if n < 1 then begin Memo1.Lines.Add(strTime + ' | ' + '» Current Phone Mode: null'); end else begin buf := ''; for i := 4 to 5 do begin buf := buf + IntToHex(rxBuf[i], 2); end; if '0101' = buf then begin buf := 'NORMAL'; end; if '0505' = buf then begin buf := 'LOCAL'; end; if '0404' = buf then begin buf := 'TEST'; end; Memo1.Lines.Add(strTime + ' | ' + '» Current Phone Mode: ' + buf); end; // Current Phone Mode - end // MCU Sw Version - start SendToUSB(#$1B#$00#$10#$D1#$00#$05#$00#$01#$00#$03 #$00#$01); n := ReadUBUSData; if n < 1 then begin Memo1.Lines.Add(strTime + ' | ' + '» MCU Sw Version: null'); end else begin buf := ''; for i := 0 to n - 1 do begin if rxBuf[i] > $0F then buf := buf + Chr(rxBuf[i]); end; Memo1.Lines.Add(strTime + ' | ' + '» MCU Sw Version: ' + buf); end; // MCU Sw Version - end // IMEI - start SendToUSB(#$1B#$00#$10#$1B#$00#$09#$00#$04#$00#$00 #$41#$00#$00#$00#$00); n := ReadUBUSData; if n < 1 then begin Memo1.Lines.Add(strTime + ' | ' + '» IMEI: null'); end else begin buf := ''; for i := 10 to n - 1 do begin if rxBuf[i] > $0F then buf := buf + Chr(rxBuf[i]); end; Memo1.Lines.Add(strTime + ' | ' + '» IMEI: ' + buf); end; // IMEI - end // Product code - start SendToUSB(#$1B#$00#$10#$1B#$00#$06#$00#$05#$00#$0B #$00#$02); n := ReadUBUSData; if n < 1 then begin Memo1.Lines.Add(strTime + ' | ' + '» Product code: null'); end else begin buf := ''; for i := 9 to n - 1 do begin if rxBuf[i] > $0F then buf := buf + Chr(rxBuf[i]); end; Memo1.Lines.Add(strTime + ' | ' + '» Product code: ' + buf); end; // Product code - end Memo1.Lines.Add(strTime + ' | ' + '» Done.'); Memo1.Lines.Add(strTime + ' | ' + '+++++++++++++++++++++++++'); Memo1.Lines.Add(''); end else begin Memo1.Lines.Add(strTime + ' | ' + '++++++++++ Not found! ++++++++++'); Memo1.Lines.Add(''); end; Button1.Enabled := True; end; | |
The Following 4 Users Say Thank You to .:Mr.Brain:. For This Useful Post: |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
can ust-pro informe me if possible unlock this mobile???? | ayoub_gsm | UST Pro II | 0 | 03-29-2010 10:23 |
Flash ID not supported for this loader (RAP3Gv3_algo.fg | medie | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-12-2010 16:49 |
RAP3Gv3_algo.fg ??????????? | tasos1971 | UFS2 + UFS3-Tornadoflasher | 15 | 12-24-2009 14:37 |
RAP3Gv3_algo.fg. how do i fix it | GOODNESS | Twisterflasher | 2 | 12-11-2005 18:17 |
