GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
01-25-2018, 16:58 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | systemless roo to full root Samsung (help) |
01-26-2018, 16:23 | #3 (permalink) |
Insane Poster Join Date: Nov 2008
Member: 896545 Status: Offline Sonork: ? Thanks Meter: 42 | In case u need to repeat ur steps once you full flash your phone with rootable version and make sure everything is latest and compitable .. do not update software to latest if it has not realsed root.. may b u need clean flash.. boot.img |
01-26-2018, 21:58 | #4 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | You did not understand my point. I have root and i am able to have it untill i do factory reset because after that it will go as every systemless root have to. So all i need is a full system root which should stay after reset. |
01-27-2018, 12:18 | #5 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | Reason of boot loop is device detect su bin in system that's why system less root exist. To perform full root you have to check different kernel which disabled root protection. Also if data is still encrypted you will get bootloop on system root,so format data in TWRP and reroot your device. You can try this step by step and see if you get full root. 1) Flash it (for cleanup everything) 2) Install TWRP. 3) Wipe data from TWRP and power on. 3) Reboot to recovery install latest su zip and wait for fully power up and uninstall supersu apk. 4) Reboot to twrp and install su 2.54. Last edited by Rahul_Bhutani; 01-27-2018 at 12:24. |
The Following User Says Thank You to Rahul_Bhutani For This Useful Post: |
01-27-2018, 17:47 | #6 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Thanks for the info , I got an alternate and gona try your procedure too, I will let u know on whats app ,,, thanks again. |
