Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Acer
Acer Acer Phones Allegro Betouch E100 Betouch E101 Betouch E200 Betouch E110 Betouch E120 Betouch E210 Betouch E130 Betouch E140 Betouch E400 Betouch T500 CloudMobile S500 DX 900 Dx 650 F900 liquid E Liquid Liquid S1 Liquid E2 Liquid Z2 Liquid C1 Liquid E1 Liquid Z110 Liquid Gallant E350 Liquid Gallent Duo Liquid Glow E330 Liquid express E320 Liquid mini E310 liquid MT Iconia Smart M 900 NeoTouch NeoTouch P400 Neotouch p300 stream X960 Acer Tablets Iconia Tab A100 Iconia Tab A101 Iconia Tab A110 Iconia Tab A1-810 Iconia Tab A200 Iconia Tab A210 Iconia Tab A211 Iconia Tab A501 Iconia Tab A510 Iconia Tab A511 Iconia Tab A700 Iconia Tab A701
Old 11-26-2012, 06:06   #1 (permalink)
amit_gsm's Avatar
Member: 665514
Sonork: 100.1618806
Thanks Meter: 325
[Guide] All the Acer Hard Reset procedures here
Acer m900 hard reset procedures
Old 05-04-2013, 20:29   #2 (permalink)
mikiidan's Avatar
Member: 57577
Thanks Meter: 98
Acer Z2 Liquid hard reset
1.Shutdown the phone
2.Power it on with Power + Vol- (will appear Acer logo and the phone will vibrate)
3.Once it vibrates, release Vol- and push Vol+.
4.The phone will vibrate again, release Vol + it will boot in recovery mode.
5.Use Vol- & Vol+ to highlight "Wipe data/factory reset" and use meniu to select.
6.Confirm "yes - delete all data".
7.Select "reboot"
Here you have video tutorial:
GSM-ABC
Old 05-04-2013, 20:35   #3 (permalink)
mikiidan's Avatar
Member: 57577
Thanks Meter: 98
Acer S500 hard reset
1.Power off the phone
2.Power on with Power + Vol down (Acer logo will appear and the phone will vibrate after 2sec.)
3.Once it vibrates, release Vol down and push Vol up
4.The phone will vibrate again, release Vol up, it will boot in recovery mode.
5.Use Vol down and Vol up to select "Wipe data/factory reset" and then use Power to select it.
6.Confirm "yes"
7.Once done, reboot the "cleaned" phone.
Here you have vide tutorial:
GSM-ABC
The Following User Says Thank You to mikiidan For This Useful Post:
Old 05-22-2013, 10:56   #4 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
acer E130 hard reset procedure
If you want to reset your ACER beTouch E130 you need:
1.Switch off your phone
2.hold on 3 buttons-''volume up''+power+button"answering a call"
3. You will see a menu where select "data reset" or something like that(by the way,you can control a menu by a trackball)
4.Most likely, your phone should reboot itself, if not, pull out the battery
PS If after hard reset,your phone displays black screen with some information about battery and smth else,try a next combination of buttons:turn off your phone >Press and hold the Volume up and Volume down buttons.>press and hold the Power until you feel your smartphone vibrate and/or you see the Acer logo screen.
In that order!
Old 06-19-2013, 06:03   #5 (permalink)
.::GSMLOTFOR::.'s Avatar
Member: 1648232
Sonork: 100.1627232
Thanks Meter: 257
Acer Liquid s100 Hard Reset
A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM.
Caution if you perform a full reset, your Acer Liquid s100 returns to its default settings and looses all information that is not recorded in ROM.
To perform a hard reset:
  1. Turn off your phone, then press and hold the Power until you feel your smartphone vibrate and/or you see the Acer logo screen.
  2. Press and hold theVolume up and Volume down buttons.
  3. Use the Volume up button to select Clean boot:YES.
  4. Press the camera button to confirm.
The Following User Says Thank You to .::GSMLOTFOR::. For This Useful Post:
Old 07-18-2013, 09:47   #6 (permalink)
..::Nokian CareŽ::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
Thanks Meter: 2,266
Acer Iconia A100 Tablet Hard Reset
  • Press & hold down the Volume UP button + Power button
  • when the tablet vibrates release the Power button Only
  • You have to release the power switch in 3 seconds (no more, no less).
  • You have to continue to hold the volume up button after releasing the power button.
  • You have to quickly work the screen lock switch as soon as the tablet vibrates as directed in step 5 (still holding the volume button, but not the power button).
  • At step 6, when you see the following two messages briefly in the upper left corner of the screen, you have been successful:
Erasing user data...
Erasing cache...
If the tablet shows a recovery error or any other unexpected condition, you may have made some mistake in the procedure. For example, if you hold the power button too long this can cause the device to go into a recovery mode. If you encounter this, don't worry. This is a common and correctable mistake. In such a case, just restart the procedure at Step 1. The procedure can take several practice runs to complete successfully. What follows is the step by step procedure.
source: acertabletforum
Br,
azam
The Following User Says Thank You to ..::Nokian CareŽ::.. For This Useful Post:
Old 10-26-2013, 11:02   #7 (permalink)
Member: 193660
Thanks Meter: 3
Acer Liquid Z110
Warning! All data will be deleted!
1. Power off the phone
2. Press together volume up + power button until Acer logo will appear and the phone will vibrate after 2sec.
3. Once it vibrates, release the keys.
4. Use volume buttons to select "Clear flash" and then press the middle button to select it.
5. Wait until the phone restarts
That's it!
Old 12-24-2013, 22:23   #8 (permalink)
kay_pencenk's Avatar
Member: 1380137
Thanks Meter: 122
Unhappy
Erasing cache...
Br,
azam
your vidio not working
Old 04-09-2016, 06:40   #9 (permalink)
Member: 1065218
Sonork: no
accer liquid z205 flash file need
Old 05-02-2016, 07:39   #10 (permalink)
Member: 2287125
acer e39 IMEI invalid aFter write IMEI set on No servise Plz help anybody
Old 04-17-2019, 10:00   #11 (permalink)
Member: 2122242
Thanks Meter: 63
Acer Iconia A3-A20 Hard Reset & FRP Done!!!
Hi guys, this method is if the volume buttons don't work, Done with NCK Box
1.- Select MT8127 in CPU
2.- Press in FRP-PATTERN-PRIVACY and Click in (META) Reset to Factory Default
3.- Connect the tablet off and wait until the job is done.
 Action : Reset to factory default.
 Selected Model: 0-By CPU:MT8127
 Exe version: NCKBox AndroidMTK 1.8.9.8
 Scanning for presents meta ports...
 Phone must be off with battery inside.
 Please insert USB cable now...
 In some phones need to keep VOL- button untill inserting USB cable.
 [4]Detected: MediaTek PreLoader USB VCOM (Android) (COM4)
 \\?\usb#vid_0e8d&pid_2000#5&2e2d6e34&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
 Starting META mode, wait...
 Restarting to meta,wait....
 If drivers missing, please install CDC drivers.
 This can take up to 5 min on slow phones.
 If take too long, check device manager for drivers.
 [57]META Port Detected: MediaTek USB VCOM (Android) (COM57)
 USB\VID_0E8D&PID_2007\5&2E2D6E34&0&3
 Start sync target, waiting responce.....
 ChipID: MT8127,S01
 Using Algo 1.
 Resetting phone step 1, wait....
 Resetting phone step 2, wait....
 ClearValue ok.
 [2]FormatTCard not allowed by phone, aborting.
 All done.
Enjoy and Regards!!!
Old 10-16-2019, 03:35   #12 (permalink)
Member: 2848061
sir i need accer liquid z205 flash file thanks
Old 10-16-2019, 03:35   #13 (permalink)
Member: 2848061
Old 10-16-2019, 03:37   #14 (permalink)
Member: 2848061
Old 04-22-2020, 15:23   #15 (permalink)
Member: 2950243
Sonork: NA
Thanks for the information.
Page generated in 0.26310 seconds with 8 queries
