06-07-2019, 05:30 | #1 (permalink) |
Junior Member Join Date: Jun 2018
Member: 2844140 Status: Offline Thanks Meter: 2 | How To Root Android Lollipop With 360 Root One-Click Most of Android users have a dream to have their Android devices rooted successfully. But they come across complications when selecting the right rooting tool for their devices. As you know, there are a number of one-click rooting tools and each tool has various success rates. Some of the tools working successfully while some of them fail to root Android.360 Root is one of sucessful rooting tool and you can give it a try if you are searching for a sucessful rooting tool Download 360 Root 360 Root application is a one-click rooting tool and users are able to download it on their PCs and Android smartphones. The app is totally free and compatible with a number of Android smartphone models. If you are looking forward to rooting Android device you check this tool. You can download it from their official website Compatibility As same as most of the one-click rooting tools, 360 Root is also only compatible up to Android Lollipop. You can Android Lollipop smartphones come from popular smartphone brands such as Samsung, LG, HTC, Huawei and etc. Weaknesses of 360 Root Not compatible with higher Android versions Available in the Chinese language No update for about year Can not root some devices 100% due to manufactures restrictions Android version has less success rate when compared to the PC version How To Use As mo0 Root comes as a one-click rooting tool it is very easy to use. If you are going to download the 360 Root Android version, you can directly download and run it on your device after enabling "Unknown Sources" in your device setting. If you are going to use PC version you can download the app as usual PC application use it after connecting your device to the computer Common Issues In 360 Root Root Fails when device restarted You may face this complication if you run the app without unlocking the bootloader of your device. So, you need to unlock the device bootloader Root Fails After OTA update As updates come with security patches 360 Root cannot adapt to the changes. So, it fails Unroot With 360 Root You can unroot your device using the same app by going to Settings > Remove Root Final Word As 360 Root is a Chinese application there will be some issues when using the application. But you will be able to solve them since this is a simple application. However, do not proceed if you are not sure about it. |
