03-14-2013, 10:43 | #2 (permalink) |
No Life Poster Join Date: Jul 2007
Member: 547368 Status: Offline Thanks Meter: 254 | welcome to gsmhosting what is actual problem in your phone ? #1. all key not work #2. some lines not work solution #1.if problem is #1. then try to remove side keys #2.if problem is #2. then you have to trace you phone pcb.and check the lines perfectly. in somecase charging socket also may foulty hope this helps you |
04-30-2014, 09:31 | #3 (permalink) | |
Freak Poster Join Date: Jan 2008
Member: 686500 Status: Offline Thanks Meter: 12 | micromax x235 all keypad not working Quote:
