Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • View Poll Results: Cracked Div Working or Not-Working???
    Working Perfectly!!! 70 36.08%
    Working,, But not perfectly.. 79 40.72%
    Not-Working at all !!! 45 23.20%
    Voters: 194. You may not vote on this poll
    Old 06-22-2003, 22:25   #91 (permalink)
    Member: 21572
    Can i unlock r610 or r620? I think, no...
    Old 06-23-2003, 14:15   #92 (permalink)
    Registered User
    Moosani's Avatar
    Member: 15866
    Thanks Meter: 192
    I HAVE T68is could it possible to unlock it
    bcoz when i try to unlock this phone they give me error 3101
    and i unlocked many pcs before it but that was t68i or t68
    any use full suggestion
    Old 06-27-2003, 22:26   #93 (permalink)
    Member: 26886
    t29 is ok
    r520 can't boot.
    Old 06-29-2003, 19:31   #94 (permalink)
    crusher's Avatar
    Member: 8023
    Thanks Meter: 13
    just wait for other boot progz...
    regards
    Old 07-04-2003, 05:26   #95 (permalink)
    Member: 17863
    DIV 6.2 CRACKED
    DIV 6.2 Does THIS PROGRAM WORK FOR THE UNLOCK OF THE SONY ERICSSON T106 AMERICAN 1900MHZ???
    Old 07-04-2003, 17:18   #96 (permalink)
    Member: 22266
    Thanks Meter: 3
    diw 6.2 cr.
    worked with T29 great, but T68i and T300 error 3101.
    Why can help me?
    Old 07-08-2003, 10:32   #97 (permalink)
    Member: 7586
    Thanks Meter: 11
    was working till today !
    today i killed T39 m !!
    and t65 !!!!
    on 99% writes error : 3467 or something like this.
    i tried flash again.
    now cant power on !
    problem with both phones.
    Pali
    need to solve this problem urgently ! Please help
    Old 07-13-2003, 15:56   #98 (permalink)
    Member: 18719
    it works 100% for t39 flashing and read codes.
    Old 07-13-2003, 19:04   #99 (permalink)
    Member: 7586
    Thanks Meter: 11
    box id now is 8363 !!
    2 phones destroyed !
    pali
    Old 07-13-2003, 19:16   #100 (permalink)
    Member: 19764
    for me work flashing t68,t65,t100,a3618,t39 perfectly,but t100 ,a3618 user lock where i can find solution(with terminator dongle
    Old 07-16-2003, 03:11   #101 (permalink)
    Drug_Store's Avatar
    Member: 15312
    Sonork: 100.1576041
    Thanks Meter: 1,097
    When I try Init boot on T300 always get 0102 instead of 0000
    Someone can help?
    Old 07-16-2003, 03:19   #102 (permalink)
    EndlessConnections's Avatar
    Member: 21371
    Thanks Meter: 24
    HEY ITS ME FAHD ,JUST USE TERMINATOR 1.2 ,IT WILL WORK . I KNOW YOURE TRYING TO UNLOCK T68IS FROM AT&T
    Old 07-16-2003, 08:17   #103 (permalink)
    Member: 20594
    I Tested with T100 is notworking, I use Terminator bought from GSM-Technology.com, is this True Terminator or there is other Terminators from Diffrent Manufacturer, The Manufacturer's is Multi-com
    Old 07-17-2003, 11:24   #104 (permalink)
    Member: 22266
    Thanks Meter: 3
    If you have error 3101 you mast:
    1. run Sony ericsson terminator (init boot) v1.0 and DIV 6.2 cr.
    2. Plug phone WITHOUT battery to cable
    3. Put the battery to phone
    4. Select model in Sony ericsson terminator (init boot) v1.0 and press init boot.
    5. Do NOT power ON the phone!!
    6. Programm trying load boot and you have error 0000
    7. Not reconnect phone open DIV 6.2 cr
    8. Select model and make desired operation
    9. Remove battery
    6. Remove cable from phone's bottom connector
    For me working 100%
    P.S. for T100 R600 and 3618 you mast run T100 R600 3618 boot (for flash) and DIV 6.2 cr.
    Old 07-17-2003, 14:19   #105 (permalink)
    crusher's Avatar
    Member: 8023
    Thanks Meter: 13
    if the prog won't even start with your terminator - you might have Softmobile Terminator
    can i flash T100 with cracked div 6.2?? infogsm Sony Ericsson 3 08-01-2003 19:45
    hi cracked div 6.2 a3618 and r600 arm flashing %100 work!!! !!!TaaTTalTi!!! Sony Ericsson 2 05-05-2003 18:28
    Cracked Div 6.2 Free bluelights Sony Ericsson 2 05-02-2003 00:09
    Page generated in 0.21305 seconds with 10 queries
