Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
06-20-2009, 07:59 | #1 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 617840 Status: Offline Thanks Meter: 49 | k610 insert correct sim i have k610 with cid 49 after flashing it shows insert correct sim., i then try to unlock with cruiser but no way. i then upgrade to cid 52 with cruiser but when i try to unlock it shows error. pls help. |
06-21-2009, 12:10 | #6 (permalink) | |
Major Poster Join Date: Nov 2008 Location: Kasur Age: 36
Member: 903931 Status: Offline Thanks Meter: 20 | Quote:
Brother try with SE TOOL and use Test card ur problem will be solved. | |
06-21-2009, 18:56 | #7 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,785 | First off,,, phone was patch unlocked ,,when you flased it you locked it. Cruiser still needs logs for Cid 49 unlock.... Do you Know correct procedure with Cruiser to unlock cid52.. Use java fast unlocker program, you will need a test sim, or use 13.20, and remove RSA, then Flash same Main, then Direct unlock, make sure free cid52 is enabled in settings. |
06-21-2009, 22:07 | #8 (permalink) | |
Registered User Join Date: Apr 2007 Location: ==**Syria**== Age: 44
Member: 493205 Status: Offline Sonork: 100.1581647 Thanks Meter: 526 | Quote:
THATS THE WAY .....THANK alot | |
Z310a, whwn I put test sim card it shows insert correct sim card. | manistar | SETool2 | 6 | 01-21-2009 20:11 |
T28 says insert correct sim card | Eguae | Old Ericsson Phones & Sony Phones | 2 | 07-26-2002 03:56 |
NEC DB500 after 'unlock' insert correct sim !? | brussl | Various | 1 | 03-05-2002 06:48 |
Alcatel Easy DB no network, insert correct sim!!! HHHEEELLLLPPPP! | OncleOh | Alcatel & TCL Old Models | 5 | 09-26-2001 12:46 |
T28s, Insert correct SIM | Larsson | Old Ericsson Phones & Sony Phones | 3 | 09-25-2001 14:33 |
