Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
02-27-2007, 20:41 | #1 (permalink) |
Junior Member Join Date: Apr 2006
Member: 256075 Status: Offline Thanks Meter: 0 | K800 & W850 not working on all networks after nulocking Please guide me what might be the solution to come out of this situation. The fella who unlocked the phone says the phones are bared but to contradict his claim Phones are working wonderfully on originally network i.e Vodafone. Best Regards. |
03-02-2007, 16:10 | #3 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Portmore, Jamaica Age: 52
Member: 160245 Status: Offline Thanks Meter: 19 | Yes i got one of these units also. The solution is in flashing the GDFS however you can't just read the GDFS from one non voda working unlocked phone and the flash it to your voda. It may cause imei problems and all locks closed. I am trying to find from Davinci team if they can modify the GDFS file from the phone to remove the restriction. Will post as soon as i get more info |
03-04-2007, 13:30 | #4 (permalink) |
Member: 160245 Status: Offline Thanks Meter: 19 | Its a well know fact that Vodafone and sometimes other UK and US providers construct their firmware in such a was prevent calls on other networks in their region. (ie no calls on 900/1800 in Europe or no calls on 850/1900 in the US). The solution is usually a generic flash, however with SE phones the feature is in the GDFS section so the flash would have to modify that region. The problem is with W850 and other DB2020 phones i have not seen any generic GDFS flash files. We need the DB2020 unlock servers to implement a GDFS update to remove the restriction. |
05-31-2008, 22:11 | #10 (permalink) |
Registered User Join Date: Apr 2007 Location: ==**Syria**== Age: 44
Member: 493205 Status: Offline Sonork: 100.1581647 Thanks Meter: 526 | hiii men these problem can be solved 100% tested in k800 1- flash your phone by r1ed001 only ms without fs and without pach unlock 2- after that your phone will be locked 3 - flash your phone with same (r1ed001) but with pach to unlock 4 done with full network ------------ these main flash (r1ed001) for repair network and service in k800 k790 (r1eg001) w580(r6bc002) w850(r1ed001) only these main flash can solved network problem after unlock or flash Good luck Eiad Hlal |
The Following User Says Thank You to yarra For This Useful Post: |
N73/6280/N80 locked on all networks after using BB5 unlock | rajSE | HWK | 18 | 05-22-2007 00:11 |
1112 want to make work on all Network | sunny_cool | Nokia Hardware & Hardware Repair | 2 | 04-26-2007 00:17 |
**does p910a work on all network?** | infogsm | Sony Ericsson | 0 | 09-16-2005 23:34 |
Winimei for E700 does not work on all versions??? | Burnt Cobba | SYSOL Platform | 10 | 05-27-2004 16:24 |
