Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
05-30-2003, 19:52 | #1 (permalink) |
Junior Member Join Date: Oct 2002
Member: 16342 Status: Offline Thanks Meter: 0 | Low standby problem...help~ Can DIV 6.2 fix this problem? I flashed the phone with DIV but standby problem still exist...maybe someone can tell me a solution? Thanks!! |
05-31-2003, 08:36 | #5 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Croatia Age: 48
Member: 9568 Status: Offline Thanks Meter: 209 | I has this problem on R600, after flash in stand-by mode can be only 24h. my problem is been on backlight ( always ON ). In menu I put this option to automatic and phone work OK. Check your backlight options!!!! BR |
06-01-2003, 04:31 | #6 (permalink) |
Member: 16342 Status: Offline Thanks Meter: 0 | Hmm, I think I have some thoughts about my own problem.. It doesn't have to do with dirty hardware or lights on/off... When I flashed with EricClient before, certain area in GDFS(maybe?) is corrupted, because EricClient is not very good at flashing T68m to T68i, anways... So I tried the following, I first turned my BT to ON, then flash my phone to R2B013, then my standby went to 180hours!!! However, we all know the phone does not operate properly when you have R7 arv and R3 arm, so I tried to flash back to R7, but then my standby went to 50 hours again Well, I guess if I can find a GDFS file that can let me flash back to T68m then maybe I can solve this problem.... I will keep trying, thanks for the input guys! |
06-23-2003, 11:02 | #10 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Macedonia Age: 43
Member: 10742 Status: Offline Thanks Meter: 13 | hi it is not hardware problem !!!!!! reset and write GDFS cant help !!!!!!! only EMEA 2 IF SOMEBODY KNOW HOW TO SOLVE THIS PROBLEM PLEASE TELL AS THANKS |
06-23-2003, 11:19 | #11 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Bogatic , RS Age: 56
Member: 4395 Status: Offline Thanks Meter: 159 | Quote:
br | |
Nokia N95 low standby problem!!!! | Byte | Nokia Hardware & Hardware Repair | 0 | 02-29-2008 17:54 |
cxt65 low standby problem | beco | Siemens Hardware Repair Area | 0 | 08-10-2007 12:37 |
3310 low standby TO WILLY | ::.::HITGSM::.:: | Nokia Hardware & Hardware Repair | 2 | 01-25-2004 09:17 |
8210 low standby | .:*CHENNAI GSM*:. | Nokia Hardware & Hardware Repair | 15 | 02-08-2003 11:37 |
3210 low standby time battery easily drain??? | eureka8888 | Nokia Hardware & Hardware Repair | 2 | 05-07-2002 11:01 |
