P800 display problem i recieved a phone does not have any colors only grey display, no colors what it could be? is this a hardware or software problem? |
Hello @LL Try change LCD . . i think is LCD problems . . :) Regards . . :D |
try to flash it by new div:D |
had any1 solved this problem?? it is understood there r 2 options ,flashing or replacing display,may be third one ''replace board'' :D |
i am trying to flash it with div 8.4 but always getting error 350c please anyone can tell me what is this?? @Free Cracker the display is working fine but no colors its just black & white :) |
ok, problem solved applying a little hotair on pcb solved the problem:D i have wrote the gdf, asuming it was the software problem now mmc's are formated and 0 data in it, only a single bell in the phone, no pics, and etc. but all other things and phone is working fine. please tell me which kind of gdf will restore this all stuff:rolleyes: |
the third option was very difficult for me....:D |
grey lcd All you need to do is inspect the pcb connector for the lcd you will find 1 of the pins is stuck and is not connecting to the lcd half. Very gently using the tip of a scalpel blade and a magnifier you can release the stuck pin. Do not apply hot air you will distort the connector and finding a replacement could be difficult. |
grey lcd All you need to do is inspect the pcb connector for the lcd you will find 1 of the pins is stuck and is not connecting to the lcd half very gently using the tip of a scalpel blade and a magnifier you can release the stuck pin. |
