Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 12-09-2003, 15:32   #1 (permalink)
    AWAIS's Avatar
    Member: 16520
    Sonork: 1580837
    Thanks Meter: 90
    P800 display problem
    i recieved a phone does not have any colors only grey display, no colors
    what it could be? is this a hardware or software problem?
    Old 12-09-2003, 18:30   #2 (permalink)
    Fre3 Crack3r's Avatar
    Member: 8784
    Sonork: 100.63512
    Thanks Meter: 31
    Hello @LL
    Try change LCD . . i think is LCD problems . .
    Regards . .
    Old 12-10-2003, 06:17   #3 (permalink)
    FATIFLAWR's Avatar
    Member: 24179
    try to flash it by new div
    Old 12-10-2003, 11:07   #4 (permalink)
    paygee's Avatar
    Member: 11742
    had any1 solved this problem??
    it is understood there r 2 options ,flashing or replacing display,may be third one ''replace board''
    Old 12-10-2003, 13:14   #5 (permalink)
    AWAIS's Avatar
    Member: 16520
    Sonork: 1580837
    Thanks Meter: 90
    i am trying to flash it with div 8.4 but always getting error 350c please anyone can tell me what is this??
    @Free Cracker
    the display is working fine but no colors its just black & white
    Old 12-11-2003, 08:49   #6 (permalink)
    AWAIS's Avatar
    Member: 16520
    Sonork: 1580837
    Thanks Meter: 90
    ok, problem solved
    applying a little hotair on pcb solved the problem
    i have wrote the gdf, asuming it was the software problem now mmc's are formated and 0 data in it, only a single bell in the phone, no pics, and etc. but all other things and phone is working fine.
    please tell me which kind of gdf will restore this all stuff
    Old 12-11-2003, 08:52   #7 (permalink)
    AWAIS's Avatar
    Member: 16520
    Sonork: 1580837
    Thanks Meter: 90
    the third option was very difficult for me....
    Old 12-17-2003, 20:47   #8 (permalink)
    Member: 27264
    grey lcd
    All you need to do is inspect the pcb connector for the lcd you will find 1 of the pins is stuck and is not connecting to the lcd half. Very gently using the tip of a scalpel blade and a magnifier you can release the stuck pin.
    Do not apply hot air you will distort the connector and finding a replacement could be difficult.
    Old 12-17-2003, 20:49   #9 (permalink)
    Member: 27264
    grey lcd
    All you need to do is inspect the pcb connector for the lcd you will find 1 of the pins is stuck and is not connecting to the lcd half very gently using the tip of a scalpel blade and a magnifier you can release the stuck pin.
    5800 Display Problem (With Display On FBUS Cable But No Display using Regular Battery eyestrain Nokia Base Band 5 ( BB-5 ) 1 06-21-2009 20:11
    P800 keypad problem eko Sony Ericsson Hardware Repair 6 03-10-2006 17:30
    p800 display problem matrix_hjs Sony Ericsson Hardware Repair 0 12-05-2004 14:52
    P800 display dissassamble. HOWTO? airboy Sony Ericsson Hardware Repair 0 08-31-2004 13:04
    p800 network problem a5hek Sony Ericsson 0 06-18-2003 11:00
    Page generated in 0.20469 seconds with 9 queries
