Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
04-13-2009, 09:49 | #1 (permalink) |
Junior Member Join Date: Apr 2007
Member: 490346 Status: Offline Thanks Meter: 2 | t650i problem Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601808808 CERT:N/A FLASH CID:53 COLOR:RED setGDFS_params failed failed to setup GDFS Elapsed: 69 secs. please helpme |
04-14-2009, 05:56 | #4 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dubai, UAE Age: 38
Member: 547967 Status: Offline Thanks Meter: 653 | Hello there are the Instruction. 1. go to emptyboard fill & repair 2. select any db2020 model 3. press "TP STAGE #1". read "instructions" and execute them. or (3a. check the box between the TP STAGE 1 & 2 in order to automatically proceed to tp sage 2 if your TP #1 is ok) 4. press "TP STAGE #2". read "instructions" and execute them. 5. now the the phone is cid49 brown 6. staying on "emptyboard fill and repair" write correct gdfs_in_ssw format === now write db2020gdfs_in_ssw_format_CID49_BROWN.ssw"==== 7. if flashing went fine, flash db2020 erom with needed CID = since my otp cid is 51 so i used "DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw", === Thanxs |
Problem flashing SE T650i | koa | SETool2 | 7 | 10-13-2011 10:45 |
T650i camera problem! | zyx_lexus | Sony Ericsson | 4 | 10-10-2009 05:59 |
SE T650i Mic Problem | nirmalbohara | Sony Ericsson Hardware Repair | 1 | 08-22-2009 09:49 |
sony t650i charging problem | SHABAD TK | Nokia Hardware & Hardware Repair | 1 | 07-25-2009 22:10 |
chinese sony-ericsson T650i phone lock problem | joshlar | Infinity-Box | 1 | 04-01-2008 19:50 |
