Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
05-13-2006, 18:14 | #1 (permalink) |
Junior Member Join Date: May 2006
Member: 275330 Status: Offline Thanks Meter: 0 | USBsmart SEMC tool problems!!! i flashed my phone yesterday (SE T610) and my computer crashed during the flashing... now, i can no longer turn on the phone, i cant even contact it with SEMC tool anymore. (it has a fully charged battery checked with another phone) anyone does anyone have any insight on to what may have happened? is it possible to burn the chip by flashing it? THANKS in anticipation. -- nighte Last edited by nighte; 05-14-2006 at 13:14. |
05-14-2006, 16:20 | #4 (permalink) |
Member: 275330 Status: Offline Thanks Meter: 0 | is it freeware? i cant afford to spend money on hundreds of different cables and software.. im only trying to fix the one phone. im thinking of taking it to an independant phone repair shop at the moment.. havent decided fully yet tho.. i couldnt find sara soft anywhere... do you have an idea on where i can get it? |
05-16-2006, 18:19 | #6 (permalink) | |
Member: 275330 Status: Offline Thanks Meter: 0 | Quote:
this worked... to begin with... now my phone wont turn on, and the T28 wont contact the phone at all. is it a possibility that i burnt a chip? if i bought a cruiser cable or a terminator or w/e i would be peeved to find out that it wouldnt help. ive already spent and failed £15 on this phone the last thing i want to do is spend more to find out it doesnt help. since its only ~£25 to get a second hand unlocked one. please advise! and thanks for your reply! i had almost given up hope of getting help here | |
05-17-2006, 09:45 | #7 (permalink) |
Freak Poster Join Date: Oct 2003 Location: romania-cluj Age: 41
Member: 41382 Status: Offline Thanks Meter: 8 | @nighte no,you can`t burn the chip by flashing...and don`t need another tool to fix that. 1. clean connector outside and inside (on pcb) 2. t28 cable is not autoignition cable...so if phone have rsa active you should press power once..but if rsa are dissable..you shoult press and release power switch until boot is intializing!! 3. good luck |
05-17-2006, 19:18 | #10 (permalink) |
Member: 41382 Status: Offline Thanks Meter: 8 | @peterbond yes it does..but only avr part...modem part can`t be flash whit it. and if avr is the same version with arm..and arm is ok...phone should work |
05-17-2006, 19:24 | #11 (permalink) | |
Freak Poster Join Date: Nov 2003
Member: 43507 Status: Offline Thanks Meter: 0 | Quote:
...so its better to buy cruisercable or dss-syncstation | |
05-19-2006, 18:30 | #12 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Sweden Age: 42
Member: 58817 Status: Offline Thanks Meter: 0 | Try this: 1. Check recovery, do selected job 2. "please power on phone"...take out battery and put it back, if it doesnt work try to take out cable and put it back. 3. Use terminator dongle and put in and put back battery on phone until you get boot. USB-smart CANT KILL any older version on phone exxept if you flash it with bad gdfs or script. |
Usbsmart Semc Soliution | GAZZUZZ | Sony Ericsson | 1 | 07-08-2007 09:25 |
semc tool problem | venelinchoo | Sony Ericsson | 0 | 09-25-2006 21:48 |
Semc tool problem | aarhusdk | Universal GSM Software | 5 | 08-13-2006 11:18 |
usbsmart SeMc 6.7 news ???? | MicrostarGSM® | SonyEricsson (USB-Smart) | 4 | 03-30-2006 22:46 |
...::: SEMC Tool v4.0 - CHANGE IMEI on ALL new ARM SEMC :::... | zulea | SonyEricsson (USB-Smart) | 114 | 12-09-2005 14:15 |
