Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 05-26-2009, 13:32   #1 (permalink)
    linekbp's Avatar
    Member: 81697
    Thanks Meter: 149
    w700 no mic ringer and speaker
    i have a W700 which came to me in dead condition , i flashed the phone and retrived it after two days the customer comes back and now all the three the mic , speaker and the ringer are not worhing i flashed it again with the same files but not success, some one help me URGENT
    Old 05-26-2009, 16:07   #2 (permalink)
    Registered User
    Member: 493205
    Sonork: 100.1581647
    Thanks Meter: 526
    write w700gdfs.bin then unlockrepair
    after that press idinify and post log here for more help
    Old 05-26-2009, 16:24   #3 (permalink)
    linekbp's Avatar
    Member: 81697
    Thanks Meter: 149
    v0.915036/UNI
    CARD SERIAL: 000000000
    Loaded 51 flash descriptors
    POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK
    PHONEBOOK NOT DETECTED IN GDFS FILE
    CFG:000000000000000
    Will write GDFS now.
    ChipID:8040,EMP protocol:0301
    PHONE STATE: "RETAIL"
    FLASH CID: 0049
    Speed:921600
    OTP: LOCKED:1 CID:49 PAF:1 IMEI:35167401391521 CERT:RED
    LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B
    Flash ID check:200D
    Flash props sent ok
    REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
    THEN PRESS "READY"
    Starting embedded bootloader...
    INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2
    LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB
    Flash ID check:200D
    Flash props sent ok
    FOUND VERSION "R1DB001_CXC1250514_EU_1_CR"
    Setting up GDFS...
    will write 986 units
    done
    Phone detached
    Elapsed: 95 secs.
    v0.915036/UNI
    CARD SERIAL: 00059786
    CFG:000000000000000
    FLASH CID: 0049
    Speed:921600
    Flash ID check:200D
    Flash props sent ok
    THEN PRESS "READY"
    Flash ID check:200D
    Flash props sent ok
    Setting up GDFS...
    done
    Phone detached
    Elapsed: 95 secs.
    CFG:000000000000000
    OBSOLETE EROM,FORCING COLOR -> RED RED
    OBSOLETE EROM,FORCING CID -> 49 49
    FLASH CID: 0049
    Speed:921600
    Can't load ID loader !
    Elapsed: 15 secs.
    CFG:000000000000000
    FLASH CID: 0049
    Speed:921600
    Flash ID check:200D
    Flash props sent ok
    FLASH CID:49 COLOR:RED
    IMEI MISMATCH ! GDFS IMEI:35167301113412
    Model (from GDFS):W700i
    Brand:Generic
    MAPP CXC article: R1CA021 prgCXC1250514_EU_1_CR
    MAPP CXC version: R1CA021
    Language Package: EMEA_1
    CDA article: CDA102580/1
    CDA version: R1A
    Default article: cxc1250522
    Default version: R1CA021
    PROVIDER: 000-00
    SIMLOCKS NOT DETECTED
    USERCODE:0000
    RESTORATION FILE NOT PRESENT
    "R1CA021_CXC1250514_EU_1_CR"
    YOU MUST PERFORM FULL FLASHING
    WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
    Elapsed: 2 secs.
    Old 05-26-2009, 16:25   #4 (permalink)
    linekbp's Avatar
    Member: 81697
    Thanks Meter: 149
    v0.915036/UNI
    CFG:000000000000000
    FLASH CID: 0049
    Speed:921600
    Flash ID check:200D
    Flash props sent ok
    THEN PRESS "READY"
    Flash ID check:200D
    Flash props sent ok
    Setting up GDFS...
    done
    Phone detached
    Elapsed: 95 secs.
    v0.915036/UNI
    CFG:000000000000000
    FLASH CID: 0049
    Speed:921600
    Flash ID check:200D
    Flash props sent ok
    THEN PRESS "READY"
    Flash ID check:200D
    Flash props sent ok
    Setting up GDFS...
    done
    Phone detached
    Elapsed: 95 secs.
    CFG:000000000000000
    FLASH CID: 0049
    Speed:921600
    Elapsed: 15 secs.
    CFG:000000000000000
    FLASH CID: 0049
    Speed:921600
    Flash ID check:200D
    Flash props sent ok
    Brand:Generic
    CDA version: R1A
    PROVIDER: 000-00
    USERCODE:0000
    Elapsed: 2 secs.
    Old 05-26-2009, 21:56   #5 (permalink)
    Registered User
    Member: 493205
    Sonork: 100.1581647
    Thanks Meter: 526
    your phone is imei mismach IMEI MISMATCH ! GDFS IMEI:35167301113412
    so try to repair imei and it will be ok just press unlockrepair and select
    1-pach otp gdfs chick in firmware
    2-allow to chenge imei when unlocking
    but in first you need to make restoration file
    -search for restoration file with this name (R1CA021 prgCXC1250514_EU_1_CR)
    or
    -add R1CA021 same phone cid and press idintify
    The Following 2 Users Say Thank You to yarra For This Useful Post:
    Old 05-27-2009, 05:21   #6 (permalink)
    linekbp's Avatar
    Member: 81697
    Thanks Meter: 149
    v0.915036/UNI
    THAT ACTION IS ILLEGAL,IF YOU DOING IT
    FOR ANY PURPOSE, OTHER THAN REPAIR PHONE
    CFG:000000011000000
    FLASH CID: 0049
    Speed:921600
    Flash ID check:200D
    Flash props sent ok
    Brand:Generic
    CDA version: R1A
    PROVIDER: 000-00
    USERCODE:0000
    SEARCH:\gsm\Flash Files\W700\R1DB001\R1DB001_1250514_EU_1_CR.ssw.cry
    SEARCH:\gsm\Flash Files\W700\R1DB001\R1DB001_EUROPE_1_fs.ssw.cry
    Elapsed: 39 secs.
    CFG:000000011000000
    FLASH CID: 0049
    Speed:921600
    llbug: blk write fail. fatal
    Elapsed: 7 secs.
    CFG:000000011000000
    FLASH CID: 0049
    Speed:921600
    Flash ID check:200D
    Flash props sent ok
    Brand:Generic
    CDA version: R1A
    PROVIDER: 000-00
    USERCODE:0000
    SEARCH:\gsm\Flash Files\W700\R1CA021\r1ca021_CXC1250514_EU_1_CR.ssw. cry
    "R1CA021_CXC1250514_EU_1_CR" CREATED
    Elapsed: 14 secs.
    CFG:000000011000000
    FLASH CID: 0049
    Speed:921600
    Flash ID check:200D
    Flash props sent ok
    THEN PRESS "READY"
    Flash ID check:200D
    Flash props sent ok
    Searching...
    Firmware OTP check determined.
    Setting up GDFS...
    IMEI MISMATCH !!!! POSSIBLE STOLEN PHONE !!!!!
    ORIGINAL IMEI:35167401391521
    CURRENT IMEI:35167301113412
    "USB" INTERFACE DETECTED AND IMEI IS MISMATCHED
    USE "COM/UFS" INTERFACE TO REPAIR THAT PROBLEM !
    WRITING CLEAR SIMLOCK UNITS...
    SIGNING...
    Unlock DONE
    Elapsed: 93 secs.
    CFG:000000011000000
    FLASH CID: 0049
    Speed:921600
    Flash ID check:200D
    Flash props sent ok
    Brand:Generic
    CDA version: R1A
    PROVIDER: 000-00
    USERCODE:0000
    RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
    Elapsed: 15 secs.
    Old 05-27-2009, 05:35   #7 (permalink)
    linekbp's Avatar
    Member: 81697
    Thanks Meter: 149
    when i try to identifyvia com cable it does not identify please tell which option to tick
    Old 05-27-2009, 08:51   #8 (permalink)
    Registered User
    Member: 493205
    Sonork: 100.1581647
    Thanks Meter: 526
    [QUOTE=linekbp;4505519]when i try to identifyvia com cable it does not identify please tell which option to tick[/QUOT
    don'nt worry its not problem conntinue......
    now you have restoration file so try to repair imei
    Old 05-27-2009, 09:01   #9 (permalink)
    linekbp's Avatar
    Member: 81697
    Thanks Meter: 149
    v0.915036/UNI
    Connecting to UFS...
    Found 2 FTDI device(s).
    UFS #85134 READY
    SIGNED MODE (USING SERVER)
    ALTERNATIVE SECURITY BYPASS ENABLED
    PRELOADER SECURITY BYPASS ENABLED
    CFG:101110000000000
    Unknown ChipID (3F00), RETRY
    Elapsed: 4 secs.
    Old 05-27-2009, 09:27   #10 (permalink)
    linekbp's Avatar
    Member: 81697
    Thanks Meter: 149
    ok i will try and post results
    1202 spekar no sound ringer and mic ok so any body help me no sound spekar alkesh02 Nokia Hardware & Hardware Repair 4 02-02-2009 20:45
    1600 ringer and speaker jumper because i loss ringer ic print pakmobiles Nokia Hardware & Hardware Repair 0 08-27-2008 19:31
    1600 ringer and speaker jumper because i loss ringer ic peint shani72 Nokia Hardware & Hardware Repair 5 08-21-2008 13:45
    LG 8120 ringer and speaker problem Bismillah_mob LG 4 06-08-2005 20:59
    6600 low ringer and speaker goga3000 Nokia Hardware & Hardware Repair 1 03-06-2005 22:24
    Page generated in 0.33698 seconds with 9 queries
