Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
03-10-2008, 12:23 | #1 (permalink) |
Insane Poster Join Date: Jan 2008 Location: philippines Age: 37
Member: 671345 Status: Offline Thanks Meter: 7 | W850 still white screen after successful flash.. i successfully flashed it but still same thing happens... |
03-10-2008, 12:33 | #4 (permalink) |
Member: 671345 Status: Offline Thanks Meter: 7 | here is the log: SERVER SUPPORT ENABLED. ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:355*********** CERT:RED FLASH CID:52 COLOR:RED Model:K700 MAPP CXC article: R1KG001 prgCXC1250200_GENERIC_CY MAPP CXC version: R1KG001 Language Package:EUROPE_1 CDA article: CDA102568/10 CDA version: R5A Default article: cxc1250489 Default version: R1KG001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1KG001_CXC1250200_GENERIC_CY" YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK SECURITY UNITS BACKUP CREATED. Elapsed: 4 secs. |
03-10-2008, 12:42 | #5 (permalink) | |
No Life Poster Join Date: May 2007 Location: UK
Member: 503346 Status: Offline Thanks Meter: 2,582 | Quote:
1st, read security units 2nd, write new gdfs 3rd, reflash via boot rom mode 4th, restore security units 5th, all done.......! | |
03-10-2008, 12:59 | #8 (permalink) | |
No Life Poster Join Date: May 2005
Member: 143889 Status: Offline Sonork: 100.1584685 Thanks Meter: 341 | Quote:
no mate. its not software problem. tested few times and flashed thousand times with out luck. just change the upper keyboard p**** with the flex.(sometime u dont even need to change the flex) thats all | |
03-10-2008, 14:42 | #9 (permalink) | |
Trust me, i repair mobile phones all day ! Thanks B.u Mobiles | |
03-10-2008, 15:34 | #10 (permalink) | |
trust me bro. all W850 which r in this problem detects as K700i. i have tested it bro. batter post result when u got exact same problem. till then please trust me | |
03-10-2008, 15:52 | #11 (permalink) | |
and i've repaired all of them my name on this forum says alot about me, just ask anyone they all know me but thanks for your advise too (can never get enough advise) | |
03-10-2008, 16:17 | #12 (permalink) |
Member: 143889 Status: Offline Sonork: 100.1584685 Thanks Meter: 341 | no furhter comments here.. but i wish i could send u atlist 1pcs of them to u.. maybe i could learn something new from u... but did u see anything regarding that exact problem on SE_TOOL support forum. a lot of guy's asking for solution and the answare is on hardware.. even the_laser himself said to repair by hardware... should i advice laser to contact u for this solution????? maybe he missed this part when he was dam busy with his setool... login to their site then see this http://www. m o b il e-f i l e s.c o m/forum/search.php?searchid=2044556 |
03-10-2008, 16:19 | #13 (permalink) | |
but theres a lot of populer guy's there with the same problem. so being populer is not the solution for all and by the way... i m here in this forum more 3 years from u. and didnt recognise u or ur name... i highly apolozige for that............. | |
06-23-2008, 21:36 | #15 (permalink) |
Junior Member Join Date: Sep 2006
Member: 341790 Status: Offline Thanks Meter: 0 | hey guys i have two w850s one i got free of a friend, his contract expired and the phone is blocked :/, but he give me it for free and later i will ring orange and ask about it because he told me the security answer etc i have another one which is my own which has a wsod and calls itself a k700 same as addictz, i tried changing the keypad and it hasn't fixed it i believe its a corrupt gdfs is there anyway to fix this |
w850 still white blink after flash | trio1 | HWK | 15 | 06-23-2008 09:59 |
N70 still white screen after all the solution | uneternity | Nokia Hardware & Hardware Repair | 24 | 08-19-2007 14:49 |
LG C1100 white screen after russian flash? | kasner | VygisToolbox | 5 | 11-23-2005 20:11 |
6600 white screen after tornado flash | ckkckk | WD2 & APE (Symbian Phones) | 1 | 03-25-2005 14:30 |
