10-03-2022, 16:22 | #1 (permalink) |
Freak Poster Join Date: Dec 2013 Location: nador maroc
Member: 2093958 Status: Offline Thanks Meter: 82 | apple iphone 5S disassembly motherboard schematic diagram service ways ic solution up iPhone-5S-Power-On-Off-Key-Button-Switch-Jumper-Ways.jpg IPhone-5s-Speaker-Solution-Jumper-Problem-Ways-Earpeace.jpg iPhone-5s-Wi-Fi-Track-Ways-Wifi-Not-Working-Problem-Jumper-Solution.jpg iPhone-SE-Usb-Charging-Problem-Solution-Jumper-Ways.jpg iPhone 5SE parts placing.png iPhone 5SE parts placing .png iphone-5s-charging-solution.png iPhone-5S-Charging-Solution-Jumper-Problem-Ways-Charging-Not-Supported.png device part iPhone 5S (A1530) Boards _ iPhone 5S (A1530) ICs_files iPhone 5S (A1533) Boards _ iPhone 5S (A1533) ICs_files Other solutions contact softrif photo thermistor iphone 5s r57_files thermistor iphone 5s r90_files thermistor iphone 5s r108_files thermistor iphone 5s r110_files iPhone 5S.html iPhone_5S_(A1530).html iPhone_5S_(A1533).html thermistor iphone 5s r57.html thermistor iphone 5s r90.html thermistor iphone 5s r108.html thermistor iphone 5s r110.html iPhone 5s 3D RF Schematic Diagram.pdf iPhone 5s 3D Schematic Diagram.pdf iPhone 5S 820-3292-A.pdf iphone5s_schematic.pdf iphone5s_schematic2.pdf 338S1202 Small Audio IC for iPad MiniAiriPhone 5s5c6.jpg Apple-iPhone-5s-Earpiece-Speaker-Jumper-Solution-Ways.jpg How-To-Repair-iPhone-5S-Blue-Screen-Problem-Error-9-Solution.jpg iPhone 5s.jpg iPhone 5s .jpg iPhone 5s (2).jpg iPhone 5s (3).jpg iPhone 5s (4).jpg iPhone 5s (5).jpg iPhone 5s (6).jpg iPhone 5S Backlight Ways.jpg iPhone 5S Battery Ways.jpg iPhone 5s Camera Not Working Problem Repair Solution.jpg iphone 5s charging solution.jpg iPhone 5S Charging Ways.jpg iPhone 5S Chrging Solution.jpg iPhone 5S Chrging Solution 1.jpg iPhone 5s Display Light Solution Backlight Ways Lcd Jumper.jpg iphone 5s error 49.jpg iphone 5s error 4013.jpg iPhone 5S Home Button Flat Solution.jpg iphone 5s ic.jpg iphone 5s ic 2.jpg iphone 5s ic 3.jpg iPhone 5S MIC Ways.jpg iPhone 5s Mic Ways Solution Microphone Problem Jumper.jpg iPhone 5s Power Button Not Working Problem Ways Solution.jpg iphone 5s screen error 47.jpg iPhone 5S Teardown.jpg iPhone 5S Teardown 2.jpg iPhone 5s Wifi Not Working Problem Repair Solution.jpg IPhone-2B5s-2Bfinger-2Bscanner-2Bnot-2Bworking-2Bsolution.jpg iphone-5s-battery-draining-solution-tested.jpg iPhone-5s-Blue-Screen-Problem-Repair-Final-Solution.jpg iPhone-5s-Blue-Screen-Problem-Repair-Solution.jpg iPhone-5s-Blue-Screen-Problem-Solution.jpg iPhone-5s-Camera-Not-Working-Problem-Repair-Solution.jpg iPhone-5s-Charging-Problem-Solution-Repair-Ways.jpg iPhone-5S-Display-Light-Solution.jpg iPhone-5s-Display-Light-Solution-Backlight-Ways-Lcd-Jumper.jpg iPhone-5s-Display-Light-Solution-Backlight-Ways-Lcd-Jumper-768x494.jpg iPhone-5s-Front-Camera-Not-Working-Problem-Jumper-Solution.jpg iPhone-5s-Front-Camera-Not-Working-Problem-Repair-Solution.jpg iPhone-5S-LCD-Display-Light-IC-Solution-Jumper-Problem-Ways.jpg iPhone-5S-Mic-Solution-Jumper-Problem-Ways-Microphone.jpg iPhone-5s-Mic-Ways-Solution-Microphone-Problem-Jumper.jpg iPhone-5s-Power-Button-Not-Working-Problem-Ways-Solution.jpg https://www.youtube.com/watch?v=yKuj...hannel=softrif |
The Following User Says Thank You to softrif For This Useful Post: |
