09-13-2012, 03:56 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: On earth
Member: 43032 Status: Offline Sonork: 100.1619349 Thanks Meter: 417 | All abot iPhone 5 Design The first and foremost feature people will notice is the design. The general shape is quite similar to the iPhone 4 / 4S with its metal band, and flat front / back. The biggest noticeable differences are its increased display size and aluminum + glass back. iPhone 5 comes with a widescreen 4-inch Retina display with a resolution of 1136 x 640 with a pixel density 326PPI. This makes the new iPhone the same width as the iPhone 4S, only taller / longer depending on which orientation you’re looking at it. Once apps get updated to support the new display, they will show more content. All apps will benefit from this feature, as games will be more immersive, Reeder / Facebook / Twitter will let users see more items, movies and TV shows will play in widescreen without letterboxing etc. etc. Keeping in line with the rumors, the iPhone 5’s headphone jack has been relocated and is now at the bottom of the device. Display The display has 44% more color saturation than the previous generation iPhone, and features integrated touch technology, which means that the iPhone 5’s display and the touch sensors have been united once and for all. This makes the iPhone 5’s display the most accurate and the most advanced display we’ve ever seen to date. Hardware Following their old tradition of ‘thinner and lighter’, the iPhone 5 weighs in at just 112 grams, is 20% lighter than the iPhone 4S and is the thinnest smartphone to date with a depth of just 7.6mm. Instead of glass and glass only on the back like with the iPhone 4 / 4S, the iPhone 5’s back plate is two-toned: there is glass at the very top and bottom, but other than that it is all metal. This is a welcome design feature, as the weak non-Gorilla-Glass of the 4 and 4S was a rather serious problem. The same old Home button sits at the center, underneath the screen, the volume buttons on the left hand-side, along with the mute/un-mute switch. The iPhone 5 has three microphones, one at the back, one at the front, and one at the bottom, which provides better sound quality, and improved noise cancellation. Internals Let’s talk specifications now: the iPhone 5 is powered by a an A6 processor which is two times faster than the A5, so you can rest assured that everything loads quicker, apps load faster and games look stunning. Android enthusiasts can finally stop claiming that their phones are technically superior as the iPhone is now right up there with them! Last year, it was proved with benchmarks that the iPhone 4S’ 800MHz A5 dual-core chip was faster than the 1.2GHz dual-core Exynos chip on the Galaxy S II and Snapdragon processors on other HTC phones. The same may just happen again this year. We’ll have to wait and see for the first benchmarks to come in. The device’s speaker has shrunk down 20%, and the earpiece now supports noise cancellation for crisp and clear voice calls. Wideband audio has also been introduced, which means that you can hear frequencies which you couldn’t on previous generation iPhones, in short, the lower and higher frequency sound bits are more audible during a voice call. Wireless Another big new feature is the support for 4G LTE. Earlier this year, the iPhone 4S received an update that changed “3G” to “4G” in its status bar when using AT&T’s HSPA+ network, but that was not at all close to the speeds offered by 4G LTE which Windows Phones and Android smartphones have been supporting since late 2010. Having 4G LTE means users will see marked improvements in streaming heavier content like HD videos and high quality audio streams. HSPA+ in the iPhone 4S supported speeds up to 42Mbps, LTE is the next big thing on the iPhone 5. 4G LTE on the iPhone 5 supports speeds up to 100Mbps. Like we said before, your content is now at your finger tips, pages load faster, videos play way too quicker, and images literally pop to your face when you’re going through content on the web. Wi-Fi now supports two bands, 2.4Ghz and 5Ghz, what does that mean for the average Joe? Well, if you have a supporting Wi-Fi router at home, then you can rest easy that dropped signals won’t be an issue at your end. Big win here. Camera Optics receive an improvement, too. Despite having a year to improve their cameras, other smartphone manufacturers (save for Nokia) have still not come up with optics that totally beat the iPhone 4S’. This hasn’t stopped Apple from improving things, though, as the camera on the iPhone 5 gets dynamic low light mode, precision lens alignment, sapphire crystal, so your images come out in far greater quality while maintaining the same image resolution – 8 megapixels. The front-facing camera’s resolution has been increased to 720p HD from VGA on previous phones. Here comes the fun part in the camera, the iPhone 5 comes with Panorama mode, so you can capture wide landscapes with ease, and saves the image at a whooping 28-megapixels resolution. The front facing camera has received a bump as well, and now sits at a respectable 720p resolution, which takes FaceTime to a whole new level, which is: HD! What’s better than an HD FaceTime call? Exactly. Battery The battery has been improved as well, and gives up to 8 hours of battery life on LTE, which quite honestly steamrolls the competition out of the water. Apple has managed to match, and improve upon the iPhone 4S’ battery to take things up a notch while on the go. Dock Connector The iPhone 5 also features the new smaller dock connector, which is USB 3 compatible, making it over 10 times faster than it’s USB 2 30-pin connector counterpart. The new dock connector has been named Lightning, which quite frankly, fits in very well with the speeds it has to offer. The major features of the new Lightning dock connector are: is is 80% smaller than the previous 30-pin connector, it has an adaptive interface, more durable, and can be plugged in to the device in any orientation. Accessories Despite having a small and improved dock connector, older accessories seemingly look out of date, but thankfuly, Apple themselves are offering a dock connector converter for the iPhone – named the Lightning to 30-pin Adapter – which will allow you to use your older accessories with the newer hardware. All older accessories are compatible with the iPhone 5, excluding cases and sleeves. Nano-SIM The iPhone 5 uses a new type of SIM card, which on many occasions have been referred to as Nano-SIM. Those iPhone users who are great with their scissor ninja skills and can cut down a regular SIM to a Micro-SIM will be disappointed to know that the Nano-SIM is completely different from the Micro-SIM and cannot be made at home. Hence, you have to get a new SIM card from your network carrier, which is compatible with the iPhone 5. Price Pricing is the usual we’ve come to expect over the last three years. The 16GB, 32GB, and 64GB models cost $199, $299, and $399 respectively with a two-year contract from AT&T, Verizon or Sprint. The iPhone 5 will be available in two colors – black and white. Availability The new iPhone 5 will go on pre-order on September 14th and will ship on September 21st. From September 14th it is available for pre-order in the following countries: United States, Canada, UK, France, Germany, Australia, Japan, Hong Kong, Singapore. And after 28th September, it will be available in 100 more countries around the globe. Last edited by J@zz; 09-13-2012 at 04:05. |
The Following 8 Users Say Thank You to J@zz For This Useful Post: |
09-13-2012, 04:09 | #2 (permalink) |
Member: 43032 Status: Offline Sonork: 100.1619349 Thanks Meter: 417 | iPhone 5 with New Aluminum Design The design is what has got the people talking about the iPhone 5. Though the basic general shape is kind of similar to the iPhone 4 and iPhone 4S, the eye-catching thing is the aluminum + glass back and a longer 4-inch retina display. [IMG]http://1.bp.********.com/-WCgpL5bUyeE/UFEHevHR48I/AAAAAAAAEpc/-hcx6MGIylI/s640/iPhone-5-design-review.png[/IMG] |
09-13-2012, 04:12 | #3 (permalink) |
Member: 43032 Status: Offline Sonork: 100.1619349 Thanks Meter: 417 | iPhone 5 with 4-inch Retina Display The device features a 4-inch Retina display which has a resolution of 1136 x 640, with a pixel density that comes in at 326PPI. The longer display allows apps to display more content. Videos are played in widescreen without the lettering, etc. The headphone jacks are now at the bottom of the device. iPhone 5 with 4-inch Retina Display [IMG]http://2.bp.********.com/-DA2Jtt6-iMo/UFEIg-jH67I/AAAAAAAAEpk/jRom4gUMg0o/s640/iphone-5-display-review.png[/IMG] The display of the iPhone 5 features 44% more color saturation along with integrated touch technology making the display the most accurate and advanced currently present in the market. |
09-13-2012, 04:16 | #4 (permalink) |
Member: 43032 Status: Offline Sonork: 100.1619349 Thanks Meter: 417 | iPhone 5 Hardware specs The device only weighs 112 grams and that makes it 20% lighter than the iPhone 4S. It's also the thinnest smartphone present in the market because it's only 7.6mm thick. [IMG]http://2.bp.********.com/-b-n6nctwlWY/UFELSn_pjTI/AAAAAAAAEp8/mvNNkur37N8/s1600/iphone-5-hardware-review.png[/IMG] The back is two-toned which means that there is glass at the bottom and top, while everywhere else you will get to see metal. This takes care of the weak non-Gorilla Glass problem faced by the iPhone 4 and iPhone 4S. [IMG]http://4.bp.********.com/-FiQvHM4x8bQ/UFEMVsCxWKI/AAAAAAAAEqE/QPMzTj6kq-w/s640/iPhone-5-review.png[/IMG] The Home button (the same one) is present at the center, underneath the screen. The volume buttons are on the left hand-side and so is the mute and un-mute switch. There are three microphones. One of them is at the back, the other at the front and the third at the bottom. This leads to improved noise cancellation and a better sound quality. [IMG]http://2.bp.********.com/-ecm9zAK8AaA/UFENQhMjW5I/AAAAAAAAEqM/JD65UaIhJ3Q/s640/iPhone-5-home-button.png[/IMG] |
09-13-2012, 04:17 | #5 (permalink) |
Member: 43032 Status: Offline Sonork: 100.1619349 Thanks Meter: 417 | iPhone 5 Specifications Review The device has an A6 processor which is 2x A5. The speakers of the device have been reduced by 20% and noise cancellation is supported by the earpiece. Users are introduced to the Wideband audio which means that lower and higher frequency bits of sound will be more audible during a voice call. [IMG]http://4.bp.********.com/-wtNoAt3wo-c/UFEOaxgPvwI/AAAAAAAAEqU/4O2ptq3YwLg/s640/iPhone-5-features-review.jpg[/IMG] |
The Following User Says Thank You to J@zz For This Useful Post: |
09-13-2012, 04:19 | #6 (permalink) |
Member: 43032 Status: Offline Sonork: 100.1619349 Thanks Meter: 417 | iPhone 5 Camera review There's a dynamic low-light mode, a precision lens alignment, sapphire crystal which leads to better quality images at 8 megapixels. The resolution of the front camera has been increased to 720p HD. [IMG]http://4.bp.********.com/-XdokP1dTmnw/UFEPePj4QkI/AAAAAAAAEqc/IV6jp74nmig/s1600/iPhone-5-iSight-camera-review.png[/IMG] |
09-13-2012, 04:22 | #7 (permalink) |
Member: 43032 Status: Offline Sonork: 100.1619349 Thanks Meter: 417 | Maps designed by Apple. The new Maps app gives you a better way to find your way. Map elements are vector based, which means graphics and text are incredibly sharp, even when you zoom in. Pan around, and you’ll instantly notice how smooth and responsive Maps is. Need directions from Point A to Point B? Maps not only shows you how to get there, it tells you — out loud, turn by turn. Maps also gives you real-time traffic information and reroutes you to avoid delays. For a completely new perspective, switch to Flyover and explore major metro areas from above with photo-realistic, interactive 3D views. |
09-13-2012, 04:23 | #8 (permalink) |
Member: 43032 Status: Offline Sonork: 100.1619349 Thanks Meter: 417 | Just ask Siri. Siri is the intelligent assistant that helps you get things done, just by asking. Talk to Siri as you would to a person: “Do I need an umbrella?” or “Any modern art museums around here?” or “Where’s the closest ATM?” Siri not only understands what you say, it knows what you mean. It figures out the right apps to use to find the right answer. Then, just like a personal assistant, Siri provides you with the information you need. New Siri features. With iOS 6, Siri understands more questions, knows more answers, and gives you a lot more to talk about. Ask Siri about sports scores and stats, where to eat, what movies to see — even ask Siri to make Facebook posts or tweet for you. And Siri is fluent in more languages, so it does more things in more countries. |
09-13-2012, 04:24 | #9 (permalink) |
Member: 43032 Status: Offline Sonork: 100.1619349 Thanks Meter: 417 | . The foundation of iPhone. At the core of every iPhone, iPad, and iPod touch is iOS. It includes all the built-in apps you use every day and all the intuitive technology — like Multi-Touch and Siri — that makes iPhone so advanced. With every free iOS update comes even more capability for your devices. You’ll find the latest version, iOS 6, already installed on iPhone 5. So right out of the box, you get more than 200 new features to make the things you do every day even better. |
09-13-2012, 04:24 | #10 (permalink) |
Member: 43032 Status: Offline Sonork: 100.1619349 Thanks Meter: 417 | Everything you need. Everywhere you go. iCloud is built right into iPhone 5. Just turn it on and you’ll have instant access to all the things you need, whether you’re on your iPhone, iPad, iPod touch, Mac, or PC. New features in iOS 6 let you do even more with iCloud. Share the photos you want with the people you choose using Shared Photo Streams. Locate, lock, and recover your misplaced phone easier than ever with Find My iPhone. Browse a web page on one device and pick up where you left off on another device using iCloud Tabs. And that’s just for starters. |
09-13-2012, 04:27 | #11 (permalink) |
Member: 43032 Status: Offline Sonork: 100.1619349 Thanks Meter: 417 | iPhone 5 is a remarkable device. The same goes for the apps that come with it. Because they achieve the perfect balance of everything you need to do with everything you want to do — from emailing your boss to filming your road trip — on the large, 4-inch Retina display. There are over 700,000 apps available from the App Store — many of them free — to make iPhone more capable, more indispensable, and more fun. Sign in to the App Store with your Apple ID, browse lots of categories, and download any app you want. Put what’s on your iPhone on your HDTV. AirPlay wirelessly streams content from your iPhone to Apple TV, so you can watch it on the big screen.10 Turn on AirPlay Mirroring, and whatever you do on your iPhone — tapping and scrolling, playing a game, even typing — appears on your HDTV at the same time. Print right from your iPhone over Wi-Fi with AirPrint. There’s no software to download, no drivers to install, and no cables to connect. With just a few taps in Mail, Photos, Safari, or iBooks, you can send whatever’s onscreen to an AirPrint-enabled printer. |
09-13-2012, 05:04 | #13 (permalink) |
Crazy Poster Join Date: May 2010 Location: Moldova Chisinau Age: 52
Member: 1306475 Status: Offline Sonork: 12345 Thanks Meter: 52 | Photo of a payment of iPhone 5 Photo of a payment of iPhone 5 While only a payment photo, we will hope that shortly there will be also a scheme. Though from the four not strongly differs, it is possible to understand, what chip for what answers. |
