09-13-2014, 11:47 | #1 (permalink) |
Junior Member Join Date: Jun 2011
Member: 1593776 Status: Offline Thanks Meter: 2 | iphone 5 touch sensitivity poor on 1st boot i have tried 3 screens and even my own apple screen with same results its worse on the right side scrolling down shows dead spots and pings back up on the keyboard (p) is a pain to work etc but after 5mins its fine also i have cleaned and cleanded the pins and even used a black pad from a 3gs digitzer to make sure its fitted snug updated it to ios8 gold master incase it was a bug in ios7 but nothing helped is this just a common thing with the iphone5? i guess if its dead so you charge it the chance is you wouldnt even know unless you try and txt p within 5mins of it being on |
09-13-2014, 13:23 | #3 (permalink) |
Member: 1593776 Status: Offline Thanks Meter: 2 | i dont think its the touch screen as ive had the same results with 3 screens plus my own 100% apple screen that i know is good! it seems pointless to keep opening it up and swapping screens cleaning pins etc i have done this so many times now all it will lead to is damage to the flex and a waste of a perfectly good screen i just wanted to know if this is a bug that others have had when the phone is first turned on from being off along time... its weird once its on i can reboot it over and over again and the touch stays fine plus it will stay fine unless its been turned off for many hours like over night! even then the error is only really noticeable if you use the keyboard as soon as its turned on as it only effects small keys on the right side like (p) so yh if i was to turn this phone on put it in my pocket then reply to a txt 5mins later with pppppppppppppppppp i wouldnt even know it had a problem but now i have noticed it its buging me |
