ipad mini udid fffff in 3utools anybody has an idea with this? error 9 in iTunes after remove the nand try to restore in 3utools but I see in logs that it has blank udid was icloud problem logs in 3utools 07:45:42 Signing firmware 07:45:42 Apple mobile device will connect to DFU mode automatically 07:45:44 Retrieving information from mobile device 07:45:44 Writing AppleLogo 07:45:44 Writing RamDisk 07:45:46 Writing DeviceTree 07:45:46 Writing KernelCache 07:45:47 Apple mobile device will connect to normal mode automatically 07:46:00 Device UDID: [ffffffffffffffffffffffffffffffffffffffff] 07:46:00 Initializing port 07:46:05 Transferring restore configuration file to apple mobile device 07:46:05 Receiving data from apple mobile device 07:46:05 Processing RootTicket 07:46:05 Writing RootTicket 07:46:05 Receiving data from apple mobile device |
anybody here no like this? |
i was also faceing the some problem check if there are any shorted capacitors near nand and check the voltage to the nand press thanks if it works |
yup problem is only connections to the nand..after the nand was detected..udid also comes..problem solved |
