04-20-2010, 11:04 | #1 (permalink) |
Registered User Join Date: Aug 2008
Member: 830204 Status: Offline Thanks Meter: 21 | 3GS Not power On and not connect to PC 3GS Not power On and not connect to PC. please help me where should I check on Logic board of this 3gs. i tried to change battery but not work. thanks |
The Following User Says Thank You to YoungSokattra For This Useful Post: |
04-22-2010, 00:03 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Ireland
Member: 117145 Status: Offline Sonork: 1617520 Thanks Meter: 382 | I have very same problem with 3gs. NOT POWERING AND NO CONNECT TO COMPUTER. I have changed the battery but that wasn’t helpful, then I put original battery back and phone back to life. After that I have switched off and phone wont torn on again. The iPhone doesn’t do to DFU mode. |
04-22-2010, 07:31 | #6 (permalink) |
Freak Poster Join Date: Feb 2004 Age: 45
Member: 55412 Status: Offline Thanks Meter: 20 | 100 % always battery deep discharge... take out battery manually charge put it back.. or solder it to terminal. and test. |
The Following User Says Thank You to cellcare_gujrat For This Useful Post: |
04-23-2010, 03:26 | #9 (permalink) |
No Life Poster Join Date: Mar 2000 Location: next to you ; ) Age: 54
Member: 1133 Status: Offline Thanks Meter: 38 | The phone is hanging now. When connect to USB to PC, it will not detect. You cannot go in to DFU mode. For solution, easiest way is to wait for battery to go Flat COMPLETELY. Otherwise, remove battery and resolder back. Plug USB cable into phone and it will go into Recovery mode. PC will be able to detect the phone again. |
04-23-2010, 03:38 | #10 (permalink) | |
Member: 830204 Status: Offline Thanks Meter: 21 | Quote:
Good Solution is : Press Home button & Power button until it turn off and then start again. | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
