04-22-2010, 06:38 | #1 (permalink) |
No Life Poster Join Date: May 2002 Location: dont ask!
Member: 12411 Status: Offline Sonork: 100.113572 Thanks Meter: 813 | adriod software running on iphone hardware hope this works on 313 hmmmmm br freddy gsmph.com |
The Following 3 Users Say Thank You to fred For This Useful Post: |
04-22-2010, 21:38 | #6 (permalink) |
Insane Poster Join Date: Jul 2004 Age: 54
Member: 71578 Status: Offline Thanks Meter: 5 | http://rapidshare.com/files/37894968...ase-0.1.tar.bz iDroid: Android on your first-generation iPhone =============================================== These instructions describe how to build an Android system for iPhone 2G from sources. These instructions are currently just notes and are being gradually worked into a more readable form. Please submit questions and suggestions for clarification to #iphonelinux on irc.osx86.hu. The essential pieces for booting Android are: 1. Linux kernel 2. Wi-Fi and touchscreen firmware 3. Boot initrd 4. Android ramdisk.img 5. Android system.img 6. Android userdata.img 7. Android cache.img 8. openiboot Instructions for pre-built images --------------------------------- If you have a prebuilt android.img.gz, ramdisk.img, system.img, userdata.img and cache.img, you still need to follow the directions in the "Firmware" section and add all the firmware files to /lib/firmware in android.img.gz (it's a compressed ext2 image) /etc/firmware in system.img (it's an uncompressed ext2 image) After this, you can skip down to "Installation". Linux kernel ------------ 1. Check out commit e27f17b5318851395a66cbaf1524ea89ff8f0cb9 of the android-2.6.32 branch of git://android.git.kernel.org/kernel/common 2. Apply the patches from android/kernel 3. Fix the Makefile for your system (you may need to use Google's repo to check out your own copy of the Android toolchain). 4. Use something based on android/kernel/.config as your .config 5. Build Firmware -------- These can't be redistributed due to copyright laws. The multitouch firmware will need to be extracted from your ioreg tree. Install iokittools from Cydia and perform ioreg -l -w 0 and pipe the result to some file. Read this file and look for entries under AppleMultitouchSPI for Firmware and A-Speed Firmware. These contain a simple hexadecimal encoding for the bytes of the firmware files. Convert and keep "Firmware" as zephyr_main.bin and "A-Speed Firmware" as zephyr_aspeed.bin. The firmware for the wi-fi can be found on Marvell's site at Marvell: Support Under "Choose a platform", select "Linux 2.6 - Fedora" and click the Search button under the drop down box. The SD-8686-* zip archive will contain the files. Rename helper_sd.bin to sd8686_helper.bin and keep that and sd8686.bin. So, you have zephyr_main.bin, zephyr_aspeed.bin, sd8686_helper.bin, and sd8686.bin. It's also possible to cut a more recent version of the Marvell firmware from the iPhone kernel. Can someone create a firmware cutter utility for this stuff? Boot initrd ----------- The Android initrd was created under a Debian installation of iPhone Linux (which is not currently available) using the create-initrd-android.sh script. However, if you read it, you can figure out generally how it's done. YOU WILL NEED TO COPY ALL THE FIRMWARE *.bins TO /lib/firmware on this ramdisk! You end up with android.img.gz Android images -------------- First, checkout 1.6 (Donut) using Google's repo tool. Copy vendor/apple to vendor/apple in their tree. Rename data/sounds/AudioPackage2.mk to data/sounds/Android.mk (if you want the built-in sounds). Copy all the firmware *.bins to vendor/apple/firmware as well. Then, apply android/android.patch provided. Then, do the following to create a "generic" image: . build/envsetup.sh choosecombo [Select device, debug, generic, engineering] export TARGET_USERIMAGES_USE_EXT2=true make -j4 PRODUCT-generic-eng Now wait forever for Android to build. You'll get ramdisk.img and system.img in out/debug/target/product/generic/. Ignore the other .img files, we won't be using them. Android ramdisk.img ------------------- Create a blank 1 MB file and make a ext2 filesystem on it. Mount it as a loopback device. Rename the ramdisk.img from Android to ramdisk.img.gz. Use gunzip on ramdisk.img.gz. Use cpio -i -F ramdisk.img as root with the current directory in the new ext2 filesystem to extract the ramdisk files onto the ramdisk. Apply android/init.rc.patch to init.rc Make a directory called /cache Unmount and you have your ramdisk.img Android system.img ------------------ You can just use the system.img Android compiled. Android userdata.img -------------------- You can start with a perfectly empty userdata.img (as long as its properly formatted). However, without the Dalvik caches, the boot will hang the first couple of times until those can be generated. This is some strange timeout issue. After the initial boot, you have to do INSERT INTO secure (name, value) VALUES ('device_provisioned', 1); Using sqlite3 in the database /data/data/com.android.providers.settings/databases/settings.db If the device is not "provisioned", it will automatically reject all incoming calls. Very stupid. Can someone please show me how this can be made less aggravating? Android cache.img ----------------- This can just be an empty 50 MB ext2 filesystem. openiboot --------- See the instructions in the openiboot folder in the iphonelinux repo. Installation ------------ 0. Jailbreak your iPhone. 1. Under the jailbroken environment, put ramdisk.img, system.img, ramdisk.img, userdata.img, cache.img, android.img.gz, and zImage in /private/var. 2. Follow the instructions for installing openiboot. - Essentially: 1. sudo ./loadibec openiboot.img3 2. Use Hold button to select Console 3. Push Home button 4. sudo ./oibc 5. Type install - loadibec and oibc are compiled for x86 Linux. - Need libusb, pthreads, readline. Running ------- In the openiboot bootloader, it should be enough to select Console with Hold and hold the Home button for more than two seconds to trigger the boot of Android. |
The Following User Says Thank You to mesut69 For This Useful Post: |
04-23-2010, 20:27 | #8 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: could'nt found yet
Member: 223973 Status: Offline Thanks Meter: 155 | Quote:
BR K@mi | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
