09-16-2008, 14:14 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Planet Earth
Member: 473763 Status: Offline Thanks Meter: 56 | after upgrading to 1.1.4, shows no service trying to unlock it. previous ver was 1.1.2 upgraded to 1.1.4 using itunes 8.0 now when i restarted the iphone, it says to insert an unlocked and valid sim to activate it. But when i insert an valid sim (O2 in this case), it does nothing. Just shows an image of a cable and CD. And shows no service. itunes also could not connect it. pls help me. |
09-16-2008, 14:49 | #2 (permalink) | |
Crazy Poster Join Date: Jan 2004 Location: philippines Age: 48
Member: 48577 Status: Offline Thanks Meter: 4 | Quote:
09-16-2008, 14:56 | #3 (permalink) |
Member: 473763 Status: Offline Thanks Meter: 56 | as i said its not even connecting with itunes. when i power on the iphone without sim, it asks for the valid sim. when i put a valid sim, it just shows that screen with an image of cable and Cd(recovery mode as i reckon) itunes does not shows anything. it just shows the name of the device in the device list. does not shows any information as it should do. i need urgent help. |
09-16-2008, 14:57 | #4 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: bangladesh
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | Quote:
try again restore by itunes 7.5.firmware 1.1.4 than use ziphone.click do it all. your problem solved. or use winpwn 2.5 with new firmware 2.0.2 and itunes7.7.a lot of post here use search button. | |
09-16-2008, 15:01 | #5 (permalink) | |
Member: 473763 Status: Offline Thanks Meter: 56 | Quote:
its not even connecting with itunes. itunes shows nothing. ..nothing | |
09-16-2008, 15:07 | #6 (permalink) |
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | ofcoures first you go to dfu mode. push power and home button simultoniously. after 9 sec release power button still push home button until your pc show new hardware detected. than relese home button. your phone is now dfu mode. if you restored 1.1.4 than first you remove itunes from your pc.also itunes library(go docoment and seting my document-my music-ituns library delete manualy). restar your pc. install itunes 7.5. now you can easily restored your iphone.after this use ziphone 2.6 or 3 to unlock zailbraik .just click do it all ENJOY |
09-16-2008, 15:34 | #7 (permalink) | |
cheers | |
09-16-2008, 16:43 | #8 (permalink) |
Member: 473763 Status: Offline Thanks Meter: 56 | phone detected in dfu mode. when i click restore button, it asks me to restore to latest version and all of my data will be erased. Can i do Shift+Restore to select desired version to select same 1.1.4 or downgrade to 1.1.2 version? |
09-16-2008, 16:48 | #9 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: HEART BEATS Age: 37
Member: 141675 Status: Offline Thanks Meter: 7,641 | Quote:
Downgrade from 2.0 to 1.1.4 GREATEST WiNpWn 2.5 (BETA )WITH SUPPORTED FIRMWARE ***===All Iphone Firmware + CUSTOM And Software (direct Links)===*** | |
09-16-2008, 17:04 | #12 (permalink) |
Member: 473763 Status: Offline Thanks Meter: 56 | u old grandpa.. only small thing i was asking is CAN I NOW DOWNGRADE THIS PHONE TO 1.1.2 OR SAME 1.1.4 VERSION? thats it.>>> i have already read about downgrading and upgrading to other versions and use winpwn to service the phone. if u really r a good member of this forum, just help me to solve my prob. of else only last option i have got is to upgrade the iphone to 2.0 or higher ver and service it ( in this case i may loose all of my data) |
no carrier on top after upgrading to 3.1.2 custom | RotKT | iPhone 2 / iPhone 3G / iPhone 3GS | 5 | 10-15-2009 18:54 |
Iphone 3G problem after upgrade to 3.1.2 | djkiddrick | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 10-12-2009 22:47 |
no service after upgrade to 2.2 | gorgans | iPhone 2 / iPhone 3G / iPhone 3GS | 6 | 12-22-2008 00:57 |
iphone no wifi no imei no bluetooth after upgrade to 2.0 firmware help?? | dvdaio | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 09-04-2008 12:17 |
purchase date shows ???? after upgrading to 3315 | dheeraj | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 09-30-2002 18:46 |
