02-09-2008, 09:33 | #1 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 18262 Status: Offline Thanks Meter: 160 | Easy Way To Unlock Iphone Without Turbo Sim http://iphone.unlock.no/OTB112unlock.htm This method is developed by George Hotz, as you can see in his blog. You can send him a donation by paypal to [email protected]. Works on any phone that shown this image first time you started it (meaning it had 1.1.2/3 and bootloader 4.6). If your phone had a picture of the earth when you started it first time, follow instructions here instead. Step 1: Install 1.1.1 firmware If your phone is already activated on any other firmware you can skip this and the next step. But you would need to add http://i.unlock.no/ as a source in Installer manually. To get 1.1.1 firmware installed, you must get the phone enter recovery mode. Here's how: 1. Connect the phone to the computer and press and hold the Power button (on top) and the Home button (on bottom front) simultaneously. 2. After about 15 seconds phone will appear to turn off, release the Power button but keep holding the Home button. 3. After about 15 seconds the computer and iTunes will detect the phone in recovery mode. 4. Download the following two files to your computer if you havent alread: 1.1.1 firmware and 1.1.2 firmware 5. Hold down SHIFT key (Windows) or Option/ALT-key (Mac) when clicking the Restore button in iTunes, and it will let you choose firmware file. Select the 1.1.1 firmware file you downloaded in previous step. 6. iTunes will give give a 1015 error, and you phone will get stuck in recovery mode. 7. To get it into normal mode, run AppTapInstaller.exe (or iNdependence if your're on a Mac). If you are downgrading from 1.1.3 you might have problems getting it started in normal mode. The solution is simple, just restore your phone to 1.1.1 again, and this time it will work 8. Now your phone should be at the activation screen. Step 2: Jailbreak and activate 1. Make sure you have a SIM-card with PIN turned off (the supplied AT&T card works fine). 2. On the activation screen, slide for emergency and dial: *#301# to make the phone call itself. (If the incoming call dialog quickly disappears but it keeps ringing, just dial 0 (remove *#301# first), and it will call itself) 3. Answer the call, and tap on Hold 4. Phone will call it self again, tap Decline. You will now be returned to the normal dialer. 5. Tap on contacts, and tap the + icon to add a new. The only info you are going to add to this contact are two URL's. To add a URL, tap Add new URL. The first URL is prefs followed by a colon: prefs: and the second is i.unlock.no. Tap Save. 6. Your contact now has two "web pages" - tap on the first one (prefs. This will take you to the settings dialog. The reason you want this, is because you need to connect to a Wi-Fi network, so tap on Wi-Fi, and get connected to a network, and make sure the icon on top of the screen is indicating that you are connected. While you are in the settings dialog, you should also set: General → Auto-Lock → Never. 7. Now, press the home button, and again, slide for emergency dial 0, Answer the call, Hold and Decline the new call so that you get to the contacts. Tap on your contact (No Name), and this time tap on the other home page, i.unlock.no 8. Safari will launch and show you a webpage. Tap on Tap here to jailbreak your iPhone 9. Phone will return to activation screen and after a few seconds the phone should restart. 10. If the phone does not restart after waiting a full minute, please make sure that you have your phone connected to the computer and try again. 11. When the phone starts again, it should no longer say slide for emergency, but rather Slide to unlock It means it was successfull! Activation is now bypassed, and phone prepared for software installation! (If you are going to use an AT&T SIM, you won't need to do the next step.) Step 3: Performing the unlock Add http://i.unlock.no/ to Installer sources if you didn't follow this tutorial 1. Tap on the Installer icon, and wait for it to refresh the sources 2. Tap on Install at the bottom 3. Scroll down to Unlocking Tools and install 1.1.2/1.1.3 OTB Unlock 4. The process will take a few minutes, before you get a message that it completed successfully Step 4: Upgrade to 1.1.2 Even though the phone is already unlocked, it will not get a signal. To fix this upgrade to 1.1.2: 1. Open iTunes again and hold down the SHIFT key (Windows) or Option/ALT-key (Mac) on your keyboard while clicking on the Upgrade button (not the restore button!). A file browsing dialog should appear, and you must select the 1.1.2 firmware file you downloaded previously. 2. While the phone is upgrading, download the 1.1.2 jailbreak archive and extract the files to your computer. 3. If you don't already have Java on your computer, you need to download and install Java runtime first. If you are unsure, check the jailbreak.jar file in the archive you extracted previously - it should have an icon with a coffee cup 4. When your phone is done upgrading, and shows the Slide for emergency screen, you need to launch the jailbreak java application on your computer. Windows users double click on the windows.bat file, while Mac users can double click on jailbreak.jar file. 5. An application should appear, with a "Jailbreak" button - click on it and wait while it's jailbreaking. This will take a few minutes, and your phone will restart a few times at the end. 6. Your phone should now show "Slide to unlock" instead of emergency. If it does, everything was successfull Step 5: Finishing the unlock Now your phone will accept any SIM-card and you will get signal. Congratulations! But if you are using your phone in a forreign country, the Phone/SMS application will just crash. Open Installer and install iWorld found in the Tweaks 1.1.2 category. Start iWorld and select your country and it will fix the crashing problem. If you want to upgrade to 1.1.3, there's a package called Official 1.1.3 Upgrader located in the System category. Installing it will upgrade your phone to a jailbroken 1.1.3. Be aware that it will take some time (25-40 minutes). THANKS Rakesh Behrani |
02-09-2008, 10:14 | #2 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 661887 Status: Offline Thanks Meter: 9 | Step 3 Hello, I dont understand step3....where do i add http://i.unlock.no/ to the iphone installer? I havent used iphone so i dont understand... |
02-09-2008, 10:59 | #4 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: pakistan Age: 50
Member: 20646 Status: Offline Thanks Meter: 100 | Quote:
try this link u will get all http://www.hackthatphone.com/112/iph..._112_46bl.html regards mahmood shad | |
<<<:: Easy Guide to Unlock Iphone 3.1.2 without Wifi ::>>>> | faisal_sherry | iPhone 2 / iPhone 3G / iPhone 3GS | 54 | 04-27-2010 00:44 |
<<:: Easy Guide to Unlock Iphone 3.1.2 without Wifi ::>> | alternative | iPhone 2 / iPhone 3G / iPhone 3GS | 13 | 11-05-2009 11:16 |
help...please explane easy way to unlock iphone 3g ver 3.1.2 MOD F 05.11.07 | CHAPRAN | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 11-05-2009 02:23 |
Easy way to unlock all Iphones by Ziphone | snsoftkiller | iPhone 2 / iPhone 3G / iPhone 3GS | 73 | 09-21-2008 03:21 |
Easy way to unlock Iphone 1.1.2 and 1.1.3 | tito millo | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 02-08-2008 19:40 |
