Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 04-06-2010, 12:29   #1 (permalink)
GsmUniversal's Avatar
Member: 649528
Sonork: 100.1590443
Thanks Meter: 6,958
Error Blackra1n ASL.dll is not found Solution Here
1) Blackra1n If you feel the lack of file “ASL.dll”, download the file from this link and place it in the same folder where blackra1n.exe. Then restart the application.
Another reason may ‘be ASL.dll Itunes.
There are 2 ways to solve the problem.
2)Uninstall phase
Head into your “Uninstall a Program” control panel. Uninstall iTunes. Uninstall Apple Application Support.
(From this point on until we reinstall Apple Application Support, neither QuickTime nor Safari 4.0.4 will be able to run.)
Next we’ll remove any leftover program files and folders.
(1) Open “Local Disk (C” or whichever drive your program files are stored on.
(2) Open the “Program Files” folder.
(3) Right-click on the iTunes folder (if it still exists) and select “Delete”.
(4) Go back into “Local Disk (C” or whichever drive your program files are stored on.
(5) Open the “Program Files (x86)” folder.
(6) Right-click on the iTunes folder (if it still exists) and select “Delete”.
(7) Staying in “Program Files (x86)”, open the “Common files” folder.
(8) Open the “Apple” folder.
(9) Right-click on the Apple Application Support folder (if it still exists) and select “Delete”.
Now empty your Recycle Bin and restart the PC.
Reinstall Phase
After the PC restarts, do not open any other applications. Disconnect from your network and/or the internet. Switch off all your security software (firewall, antivirus and antispyware).
Now start the install by doubleclicking the iTunesSetup.exe file you downloaded earlier.
Reenable all security software prior to reconnecting to your network and/or the internet.
3) Another way is to copy and replace the file downloaded ASL.dll as above and replace in this path
“C:\Program Files (x86)\Common Files\Apple\Apple Application Support\ASL.dll
The Following 5 Users Say Thank You to GsmUniversal For This Useful Post:
Old 04-06-2010, 14:31   #2 (permalink)
Member: 149305
Sonork: 100.1612778
Thanks Meter: 804
here is detailed video how to do so
YouTube - How To Fix Your blackra1n RC3 With iTunes 9.1
The Following 3 Users Say Thank You to azhar63 For This Useful Post:
Old 04-07-2010, 02:51   #3 (permalink)
Member: 1278576
http://forum.gsmhosting.com/vbb/f456...-9-1-a-970055/
Old 04-10-2010, 23:56   #4 (permalink)
dapinderjit's Avatar
Member: 145082
Thanks Meter: 798
just copy the blackrain application to the folder where the asl.dll is located
have checked working 100%
The Following 2 Users Say Thank You to dapinderjit For This Useful Post:
Old 04-11-2010, 10:18   #5 (permalink)
tariq_h's Avatar
Member: 896307
Sonork: 0096
Thanks Meter: 231
it is true bro
[QUOTE=dapinderjit;5693821]just copy the blackrain application to the folder where the asl.dll is located
thanx
Old 04-11-2010, 10:32   #6 (permalink)
Vichka Kham's Avatar
Member: 959779
Sonork: 100.1604117
Thanks Meter: 80
copy soft to C:\Program Files\Common Files\Apple\Apple Application Support
and sent soft to desktop
use shortcut
ur solution is solve
The Following 2 Users Say Thank You to Vichka Kham For This Useful Post:
Old 04-12-2010, 14:09   #7 (permalink)
tariq_h's Avatar
Member: 896307
Sonork: 0096
Thanks Meter: 231
[QUOTE=basitmemon786;5674799]1) Blackra1n If you feel the lack of file “ASL.dll”, download the file from this link and place it in the same folder where blackra1n.exe. Then restart the application.
2)Uninstall phase
Reinstall Phase
4)Another easy and tested way1000%.to install a full setup of blackranc3,it will solve this problem very surely,u can download it
from here Blackra1n_for_iTunes_9.1.zip
or from here iPhone Firmware Download - Direct Links Download | iPhone Firmware
IF it works ,say thanks
The Following User Says Thank You to tariq_h For This Useful Post:
BlackRa1n not working ? solution here .. delower10 iPhone 2 / iPhone 3G / iPhone 3GS 9 01-03-2010 02:52
The Application or DLL globalroot\systemroot\system32\gasfkyjdwosttx.dll is not valid Ankit Verma Java, iOS, Android, Symbian development 0 09-18-2009 10:24
NO SERVER FOUND [Solution Here] shahzaadbutt SETool2 3 09-18-2008 00:07
what is meaning of secondry certificate not found, solution? karouk Cruiser Suite 1 08-06-2006 23:54
Page generated in 0.17325 seconds with 9 queries
