04-17-2009, 01:51 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: 5180 Age: 41
Member: 161183 Status: Offline Thanks Meter: 95 | Final solution to unlock and downgrade iphone 3g 1)First step check your baseband version: -Press to launch Settings from your Springboard. -Press to select General from the Settings Menu -Press to select About from the General Settings Menu. -From the about screen you can find your firmware version under the Version label. -Scroll down and you can find your baseband version under the Modem Firmware label. 2)second step -If your baseband is 2.30 to contain the next step if baseband is 2.28 pass to Final step 3)third step downgrade your baseband version: *Check Your iPhone Bootloader Version instruction find here *Launch Cydia by pressings its icon on your SpringBoard. *Press to select the Sections tab at the bottom of the screen *Press to select iClariifed from the list of Sections. *Press to select DownBB from the list of Packages. *Press the Install button at the top right of the screen. *Once installation has completed successfully press the large Return to Cydia button. *Press the Home button to return to your SpringBoard then press to launch Terminal *Enter su into the terminal window then enter alpine when prompted for a password. *Enter DownBB into the terminal window to launch the baseband downgrade script. *You will be asked to confirm you would like to continue. Please make sure you are on the 2.30 baseband and have the 5.8 bootloader before entering yes into the window. DownBB will now execute the script which downgrades your baseband. Once the script has completed it will automatically reboot your iPhone *Please note you will now be on the 2.28 baseband. 4)FINAL STEP FOR UNLOCK NETWORK *Press to launch Cydia Installer from your SpringBoard *Press to select the Manage tab at the bottom of the screen. *Press to select the large Sources button *Press the Edit button at the top right of the screen. *Press the Add button at the top left of the screen. *Enter http://apt9.yellowsn0w.com/ as the source url and press the Add Source button. *Press the Done button at the top right of the screen. *Press to select apt9.yellowsn0w.com from the list of user entered sources. *Press to select yellowsn0w from the list of package **GOOD LUCK FOR ALL** |
The Following 9 Users Say Thank You to KHALED_MB008 For This Useful Post: |
04-17-2009, 10:42 | #7 (permalink) |
No Life Poster Join Date: Oct 2004 Location: USA
Member: 85637 Status: Offline Sonork: 100.100.529 Thanks Meter: 139 | yes its work for phones who have boot 5.08 check here http://www.iclarified.com/entry/index.php?enid=3583 thx khaled for info my reg |
04-25-2009, 16:50 | #14 (permalink) |
Major Poster Join Date: Aug 2008
Member: 839723 Status: Offline Sonork: 100.1583856 Thanks Meter: 8 | old news dude u make it easy by providing pics bt old news we r wating 4 bootloader5.9 , 6.02 if u have post bt with out hardware Last edited by malikkk; 04-25-2009 at 17:13. Reason: quote removed |
can i unlock and activate iphone 3G using ziphone3.0 | sameenshah123 | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 03-22-2009 20:40 |
Easy To Unlock And Downgrade Ur Iphone | borndevils81 | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 08-04-2008 14:33 |
Is there any FINAL SOLUTION TO UNLOCK BB5 ?? | parthiv_sk | Nokia Base Band 5 ( BB-5 ) | 8 | 01-15-2007 05:21 |
final solution to unlock samsung X490 | nabildeco@yahoo | SYSOL Platform | 6 | 11-22-2006 10:46 |
final solution to unlock C75 0% risk enjoy | satcomhedi | S-Gold Based Phones | 24 | 07-29-2006 13:03 |
