06-18-2009, 11:36 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Sep 2006 Age: 42
Member: 354557 Status: Offline Thanks Meter: 595 | How to Enable Carrier Bundle Support in iTunes 8.2 (Windows) These are instructions on how to enable support for carrier bundles in iTunes 8.2 for Windows. You'll notice if you try to update your iPhone carrier settings using the final version of iTunes 8.2 the .ipcc files are greyed out. In order to re-enabled access to these files you will need to follow the simple steps below. DarkRedStep One Quit iTunes Step Two Press Windows Key + R to open the run dialog. Enter in cmd then click OK Step Three Enter the following command into the Command Prompt window. "C:\Program Files\iTunes\iTunes.exe" /setPrefInt carrier-testing 1 Step Four Connect your iPhone and click to launch iTunes from your Start Menu. Step Five Select your iPhone from the list of devices on the left then hold down the Shift key and click the Check for Updates button. Step Six Notice you can now select your .ipcc file as it is not greyed out. Last edited by ...:::JamalMustafa:::...; 06-18-2009 at 11:43. |
The Following 7 Users Say Thank You to ...:::JamalMustafa:::... For This Useful Post: |
f309 how to flash is it supported in z3x | adaki_vishal | Z3X-Team Products | 1 | 12-15-2009 17:47 |
How to Enable RUIM slot provided in Nokia 3125 | waves2d | Nokia CDMA | 6 | 03-12-2007 07:22 |
HOw to enable Caller id menu in GD95 | Elm | Panasonic | 0 | 02-29-2004 17:08 |
