Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 03-09-2010, 02:17   #1 (permalink)
Member: 343635
Thanks Meter: 57
iphone 3G problems: no recognized with pc, charge but not shown on display
hello all,
i have a problem with a iphone 3G, if i connect it to pc it's NOT recognized from itunes and pc.. i tryed on 3 pc, it's an hardware fault so i replaced the iphone connector.. but the problem is the same!!
same situation if i put in dfu mode... it's not recognized from pc....
iphone does charge, but its not shown in the battery on the display (i checked the tension on the mainboard with usb plugged in and it's ok)..
but if i turn the iphone off and i connect it to usb it will power ON but still not recognized on pc... and the battery icon still doesn't show it's in charging..
i also tryed to rehot the LTC4088-2.. same problem..
any solution?
Old 03-09-2010, 06:33   #2 (permalink)
Member: 60474
Thanks Meter: 658
hi did u try changing the charging cable???? and try using the wall adaptor.....
Old 03-09-2010, 21:56   #3 (permalink)
Member: 343635
Thanks Meter: 57
yes, also tested with wall charger.... same problem...
i also used another apple original usb cable.. same thing...
Old 03-10-2010, 08:28   #4 (permalink)
miguel_john1975's Avatar
Member: 586346
Thanks Meter: 113
im having same problem change battery still canot detect by the computer phone no sign of life
Old 03-10-2010, 09:59   #5 (permalink)
MPhoneClinic's Avatar
Member: 20639
Thanks Meter: 233
try this out, this was my experienced
The Following User Says Thank You to MPhoneClinic For This Useful Post:
Old 03-11-2010, 14:11   #6 (permalink)
Member: 343635
Thanks Meter: 57
the strange thing is that the battery charges... but it is not showed on the monitor... should i solve my problem with that solution?
Old 03-12-2010, 01:11   #7 (permalink)
Member: 20639
Thanks Meter: 233
first i will check the USB port, the connectors or make sure change from a working usb just to make sure.
and if still not working then looking to those ic on my last post picture.
cheers
Old 03-12-2010, 17:05   #8 (permalink)
Member: 343635
Thanks Meter: 57
usb port ok if i connect another iphone, connectore replaced 2 times..
so i'll check the ic's
Old 03-24-2010, 20:17   #9 (permalink)
Member: 1269506
I have this exact same problem. I'm thinking of changing the linear LTC4088-2 but I don't know if thats going to do anything? Could you update me on the status of your phone? Thanks and good luck!
Old 03-31-2010, 07:51   #10 (permalink)
cyklops's Avatar
Member: 54419
Any Luck with this problem yet i have the same problem , charges full on pc but not show its charging, but pc does not see this phone ?
Old 04-01-2010, 14:44   #11 (permalink)
Member: 343635
Thanks Meter: 57
i didn't find a solution yet
I9+ 3G clone no connection with pc rk1954m Chinese Models & Cloned Phones 0 07-30-2009 16:08
T610 charging but not switch on samanthe Sony Ericsson Hardware Repair 5 06-02-2005 21:45
Alcatel 311 charging but not turning on!!!! agpla BF, BG, TH, BHx Series 3 04-18-2005 11:55
A800 charging but not power on patric Samsung Hardware Repair 0 04-08-2005 11:19
gd35 charging but not power on magnet Panasonic 1 06-05-2003 09:37
Page generated in 0.19614 seconds with 10 queries
