02-23-2009, 04:12 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: uk Age: 44
Member: 163725 Status: Offline Thanks Meter: 137 | iphone 3G 2.2.1 UNLOCKING NOT DONE Using username "root". iPhone:~ root# cd /private/var/root iPhone:/private/var/root root# /bin/launchctl unload /System/Library/LaunchDaemo ns/com.apple.CommCenter.plist iPhone:/private/var/root root# chmod 755 BBUpdaterExtreme iPhone:/private/var/root root# ./BBUpdaterExtreme update -f ICE2_02.28.00.fls -e ICE2_02.28.00.eep Validating parameters...OK Disabling thermal Notifications...OK Disabling sleep...OK Powering radio on through AppleBaseband Opening device path /dev/cu.debug, using initial baud 115200 - Ping failed, trying again, 56 tries left - Ping failed, trying again, 55 tries left - Ping OK Gathering modem information...OK Checking Static EEP backup... - backup is OK Checking Static EEP backup -- All OK Firmware Version: ICE2-02.30.03 EEP Version: EEP_VERSION:526 EEP Revision: EEP_REVISION:0 Boot Loader Version: ICE2_BOOT_05.09_G2M3S2 FLS/EEP Mismatch: Match Configuring Hardware Mux...OK ------------------------------------------------------------------------------- BEGINNING BOOT ------------------------------------------------------------------------------- Sending boot code...OK Reading Reference file ICE2_02.28.00.fls...OK Sending EBL Loader... Sending EBL Loader Length...OK Sending EBL Loader Data...OK Sending EBL Loader Checksum...OK Sending EBL Loader -- All OK Sending EBL... Sending EBL Length...OK Sending EBL Data and Checksum...OK Sending EBL -- All OK Getting EBL Version......OK - Boot Mode 0xCC - EBL Version Major/Minor: 6.2 - EBL Version 'ICE2_RAM_B' - Flashing Compression: 0, CRC Type: 0, CRC Method: 1 Reading Reference file ICE2_02.28.00.fls...OK Sending Protocol configuration...OK Sending Flash ID...OK Doing CFI Stage 1...OK Doing CFI Stage 2...OK ------------------------------------------------------------------------------- DONE BOOT ------------------------------------------------------------------------------- Getting software version of file ICE2_02.28.00.fls...OK Increasing baud rate to 921600...OK Validating EBL Version...OK ------------------------------------------------------------------------------- SENDING FLS FILE: ICE2_02.28.00.fls ------------------------------------------------------------------------------- Loading FLS file ICE2_02.28.00.fls...OK >> Sending Block of type CodeClass(0) from file ICE2_02.28.00.fls... Beginning Dynamic EEP erase at 0x20E40000 to 0x20EBFFFE...Progress: 100 percent, 524286 of 524286. OK Sending Security Block...OK Erasing Load Area from 0x20040000 to 0x2063A01A (this will take some time)...OK Sending data for mapping 0: progress: 100 percent, 6266908 of 6266908. -- OK Checking validation result... - Warning: Validation result code indicates failure, result code = 0x0 OK >> Sending Block of type CodeClass(0) from file ICE2_02.28.00.fls -- All OK ------------------------------------------------------------------------------- DONE SENDING FLS FILE ------------------------------------------------------------------------------- ------------------------------------------------------------------------------- SENDING EEP FILE: ICE2_02.28.00.eep ------------------------------------------------------------------------------- Loading EEP file ICE2_02.28.00.eep...OK >> Sending Block of type StaticEEPClass(0) from file ICE2_02.28.00.eep... Sending Security Block...OK Erasing Load Area from 0x20FC0000 to 0x20FC57FE ...OK Sending EEP Payload...progress: 100 percent, 22528 of 22528. -- OK Checking validation result...OK >> Sending Block of type StaticEEPClass(0) from file ICE2_02.28.00.eep -- All OK ------------------------------------------------------------------------------- DONE SENDING EEP FILE ------------------------------------------------------------------------------- Powering radio down...OK Doing a hardware reset through AppleBaseband Waiting for baseband power-up... - Ping failed, trying again, 56 tries left - Ping failed, trying again, 55 tries left - Ping failed, trying again, 54 tries left - Ping failed, trying again, 53 tries left - Ping failed, trying again, 52 tries left - Ping OK - Baseband took 5.145289 seconds to power up Powering off radio... Powering off radio -- All OK Waiting for baseband power-up -- All OK Re-enabling thermal Notifications...OK Re-enabling sleep...OK iPhone:/private/var/root root# THANKS |
02-23-2009, 04:48 | #2 (permalink) |
No Life Poster Join Date: Jun 2007 Location: E G Y P T Age: 37
Member: 527884 Status: Offline Sonork: 100.1583794 Thanks Meter: 850 | Man No Solution Yet To Unlock 2.2.1 With 2.30 ModeM By S W So Don't Try Fake Solution Only Way To Unlock It By Rebel SIM B.R Shedeed |
