iphone 3g no service after unlock i have iphone 3g 3.1.2 after unlock with blackra1n i see serching...... after no service.... |
Try to reset your network settings. |
put ur sim in a another fone, wait for reception, then take it out and put it back in iphone, will work 100% |
please research be4 post...too manyy post..turn off ur 3g opion be4 u try to put any beside at&t sim card... blackrain>>install snow and cydia throug wifi..if u can not find any wifi..reset network>>turn off 3g and reboot>>insert sim..u should be good to go |
Iphone 3G no service fix 1. happen to 'no service' after change LCD/Bat/ parts 2. when no 3G coverage no service happen. 3. toggle off 3G no service happen 4. try software method... 1st suspect 3.1 firmware is the culprit.. try many tools and method 5. mine is factory unlocked version buy from hongkong, running 3.1.2 6. Try to change sim card.. to another phone.. seem okay.. 7. put diffrenet sim card in the iphone.. same problem 8. if all software method failed.. open you iphone 3g.. find the copper pin from logic board to the body on the lower part. I solder the pin to the body frame. Whola.. solve the problem |
check the imei it may be corrupted |
