11-29-2009, 20:07 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: gallerie7-tunis
Member: 211028 Status: Offline Sonork: 100.1587652 Thanks Meter: 23 | iphone 3g no service after unlock serching...... after no service.... |
The Following User Says Thank You to top50gsm For This Useful Post: |
11-30-2009, 01:47 | #3 (permalink) |
Junior Member Join Date: Sep 2004 Age: 38
Member: 82022 Status: Offline Thanks Meter: 1 | put ur sim in a another fone, wait for reception, then take it out and put it back in iphone, will work 100% |
The Following User Says Thank You to shizy For This Useful Post: |
11-30-2009, 04:53 | #4 (permalink) |
Junior Member Join Date: Sep 2006
Member: 359021 Status: Offline Thanks Meter: 1 | please research be4 post...too manyy post..turn off ur 3g opion be4 u try to put any beside at&t sim card... blackrain>>install snow and cydia throug wifi..if u can not find any wifi..reset network>>turn off 3g and reboot>>insert sim..u should be good to go |
The Following User Says Thank You to xboio For This Useful Post: |
12-26-2009, 10:29 | #5 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1190307 Status: Offline Thanks Meter: 4 | Iphone 3G no service fix 1. happen to 'no service' after change LCD/Bat/ parts 2. when no 3G coverage no service happen. 3. toggle off 3G no service happen 4. try software method... 1st suspect 3.1 firmware is the culprit.. try many tools and method 5. mine is factory unlocked version buy from hongkong, running 3.1.2 6. Try to change sim card.. to another phone.. seem okay.. 7. put diffrenet sim card in the iphone.. same problem 8. if all software method failed.. open you iphone 3g.. find the copper pin from logic board to the body on the lower part. I solder the pin to the body frame. Whola.. solve the problem |
iphone 3g no network after unlock | masterprinters | iPhone 2 / iPhone 3G / iPhone 3GS | 14 | 05-12-2010 02:01 |
Iphone 3G no service after all | BigBatica | iPhone 2 / iPhone 3G / iPhone 3GS | 11 | 07-17-2009 01:40 |
iphone 2g no service after unlock - URGENT | khem | iPhone 2 / iPhone 3G / iPhone 3GS | 24 | 05-05-2009 04:40 |
Iphone 3G no service after jailbrake?! | goran124 | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 01-03-2009 11:39 |
iphone 3g no servies after unlock | nofear197979 | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 11-05-2008 10:18 |
